Results 2,221 to 2,230 of 13229
August 31st, 2005 04:41 PM #2221
Seems G owners are not getting the price for their money. Never heard J-variant owners having the same problems like G's. No offense here guys, just an observation.
August 31st, 2005 04:47 PM #2222Originally Posted by themann
You might find it helpful for your query.
August 31st, 2005 04:55 PM #2223Originally Posted by czar_ethan
Mga Innova G owners, i just accidentally discovered that G models indeed have sensitivity sensors. Naka-arm kasi ride ko while i was cleaning the car. Nung nililinis ko na mga wiper blade sa harap eh bigla kong nabitawan ang isang wiper blade at sumalpok sa windshield...result, nag-alarm po sya. So meron nga siyang impact sensors pero naka set na hindi masyado sensitive para hindi mag false alarm.
August 31st, 2005 05:23 PM #2224
Regarding shock sensors, its sensitivity can be adjusted by plain screw driver only. Shock sensors are connected from the main unit which is inconspicuously located most likely near the doors or beside the panel. Wait up, will post later the wire connection diagram.
August 31st, 2005 10:31 PM #2225Originally Posted by leinahtan
September 1st, 2005 11:09 AM #2226Originally Posted by leinahtan
- Jun 2005
- 325
September 1st, 2005 11:27 AM #2227Try opening the driver's side kick panel. This is the usual place the car manufacturers put it. The impact sensor is like a small brick 2x2x1 that's attached to bottom of the A-pillar. They put it here since very often, the point of entry of the theives is the driver's door. Itong area ang unang na-aalog ng magnanakaw.
The headunit of the alarm should be around that area too, maybe under dash left of steering wheel (just a hunch).
September 1st, 2005 03:05 PM #2228
TRIED to move or lift my ride thru the front fender and no alarm whatsoever was triggered..
I checked the driver side steering colun and saw a gadget thing colored blue on the left side of steering wheel but DIDN'T see any thing on it that you can adjust with a screwdriver...
WBR,
September 1st, 2005 03:13 PM #2229Originally Posted by jaeger
the original TVSS for the 2003 Revo and up is made by fujitsu (sabi lang po), the shock sensor is BUILT-IN on the main alarm module itself and you can adjust it using a small screw driver, I know it's location on the Revo and it is very far from the driver's door hehe, nasa passenger area sya..
sa 2003 revo and up, it's very easy to adjust the shock sensor sensivity, and it will be also very easy for the thief to remove the alarm module.. lintek na toyota yan hehe..Last edited by revoGSX; September 1st, 2005 at 03:26 PM.
September 1st, 2005 03:23 PM #2230Originally Posted by Innova_Boy
i'm not sure if this is applicable sa Innova, here's some tip to locate your Innova alarm module, arm or dis-arm your innova while you are inside the vehicle, you will hear a clicking sound (relay to light up the left and right signal lights)..Last edited by revoGSX; September 1st, 2005 at 03:42 PM.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
