Results 661 to 670 of 13229
- Mar 2005
- 192
April 15th, 2005 06:22 PM #661Originally Posted by Innova_Boy
- Mar 2005
- 192
April 15th, 2005 06:29 PM #662Originally Posted by busy road
April 15th, 2005 06:34 PM #663
About the battery, sealed type pala ang naka-installed. I don't have to bring my hydrometer anymore. That's the only problem with sealed type. We can't measure the state of charge using hydometer for all 6-cells. So, the only way is to measure the total voltage accross the terminals while disconnected.
For all who are interested, these are the values that represents the condition of our battery:
- Condition--Sp. Gravity---Total Voltage
---100%----------1.265-------------12.7
----75%----------1.225-------------12.4
----50%----------1.190-------------12.2
----25%----------1.155-------------12.0
--Discharge-------1.120-------------11.9Last edited by busy road; April 15th, 2005 at 06:38 PM.
April 15th, 2005 07:10 PM #664
Originally Posted by geebunny
Do you know that the life span can be increased to 3 to 4 years? Yes, it's possible.
Normally when we replaced battery, we directly installed without proper charging. We just rely on our alternator...Right? First battery charging is VERY IMPORTANT. Parang eggplant na kapag hindi tama ang pagkaluto, tumitigas iyan. Then, kahit anong gawin mung luto after, sira na iyan. Same with our batteries. So, be sure to charge your battery using portable charger.
If you are using constant current charger, try this:
Example:
1. Battery is 50Ampere-Hour. Charge it with constant 5 amperes until the voltage reached 14.4V. Then decrease the charging current to 2.5 amperes. Complete charge battery can be noticed when the voltage reached a voltage of 15.6 to 16.2 without further increase for the next 2 hours. Additional information can be achieved if your battery is flooded type were you can measure the specific gravity of all cells at maximum 1.265 to 1.270.
2. Once every month, charge your battery using portable charger at 13.8 volts overnight even it is known to be good.
3. (For flooded type battery)Never let your plates exposed to air. Always add distilled or deionized water to top up to maximum.
I can assure you, following the above tips will lengthen the life of you batteries.
April 16th, 2005 12:01 PM #665
Re: thermocooler..
just want to ask kung how low temp ( say 15 degree celsius ba ) ang kaya niya i-maintain inside the cooler?? so how effective is this to properly cooll your drinks or whatever..
SO ibig sabihin, dapat frozen na coke in cans mo bago mo ilagay dun sa thermocooler??
WBR,
April 16th, 2005 12:51 PM #667
- Apr 2005
- 55
April 16th, 2005 01:16 PM #668Hello once again fellow INNOVA fans! just want to know if any of you had their sound system upgraded na... para kasing napaka plain naman ng HU natin , any head unit na pwede dun or pwede din kaya yung 1 dinna pioneer? how about the speakers? how about AMPs and SubS? thanks!
- Mar 2005
- 39
April 16th, 2005 05:18 PM #669about car batteries, i had this good experience of buying this obscure battery brand about 3 and a half years ago for my old car. the brand is incoe. bought it somewhere in paco, manila. it is 2SM in size and packaged in translucent white plastic casing, kind of you can see the electrolyte level . when i bought it i was surprised to see it has no electrolyte yet in it. the store owner told me he would fill it w/ electrolyte and have it electrically charged for at least 30minutes. so there it went. It was installed in my car and I paid something like PHP1,300 back then. The thing is THAT BATTERY is still working up to now, going on its 4th straight year!!! I can't believe that obscure and rather inexpensive battery can outlast my previous car batteries which cost way above !!! in the past 3.5 years i just topped it up w/ distilled water whenever i see the electrolyte level slightly dip from the prescribed level. I recommend you try it. or at least find a battery and battery store where they only pour the electrolyte upon purchase. I guess that partly explains the long life of the battery.
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
