Results 11 to 20 of 560
February 15th, 2010 04:08 PM #12
Update on our meeting :
Met with a senior executive of TMP and her group manager at 10am today. Meeting was very cordial as they are very much willing to listen. Showed them the posts here in FCP and in Tsikot and have agreed that they will seriously look into it. They will take this up with senior management so positive action will be planned and executed.
Couple of suggestions that I made which they will seriously consider :
1. Setting up of a quick action center or hotline to address the D4D problem
a. I will be forwarding to them the numbers of those who are affected and they should get in touch with these owners for possible remedies
b. Instead of the dealership calling, it will be TMP customer service who will be dedicated to solve the issues
2. Extension of warranty for those beyond three years (just for the supply pump) until they can say that the D4d problem is close to zero
3. They will generate the database from their dealerships of owners who have complained and possibly still awaiting actions
4. Possible Focus Group Discussion with concerned owners and TMP to address common issues
5. They will monitor both FCP and tsikot for other concerns that I have not raised. (btw , I also included the issue on the Innova gas tank)
Meeting adjourned at 1120am
I will keep you posted as they have given me numbers if nothing has been done.
Thank you for your support.
February 15th, 2010 05:31 PM #14
i had this problem also. just after my PMS and when Im about to start my car I smelled gasoline. I look underneath to check if that smell is comming from my car, lo and behold! my gas tank is leaking. I told TPT that i brought my unit for PMS and after being serviced nabutas yung tank!!! I have no choice but to leave my unit sa TPT. The next afternoon nakuha ko na sya. thet replaced the canister, cap and the tank. Buti na lang at under warranty! and I need not argue my case with TPT. hopefully di na ito maulit. Imagine the gas tank costs around 20K!
I had owned many cars before (80 corolla, 83 & 87 lancer, 80 & 81 gemini, 88 l300, 89 corolla, 2000 revo pero sa INNOVA lang ako nakaranas ng ganito!
February 15th, 2010 05:44 PM #15
Good for us that we noticed the leaking fuel, but what if we did not notice it?, that it would make us part of the statics with car catching fire while on the road.
If I remember correctly here in tsikot, there are 2 Innova's that went on fire while on the road, one in Ortigas road and one in Bago Bantay.
February 15th, 2010 07:32 PM #18
nuts. it seems that petrol innovas are the ones prone to this.
am definitely checking our diesel innova this weekend.
February 19th, 2010 01:23 PM #19
Yesterday, after ng ilan hours ng nakapark ang avanza ko sa shade, I opened the filler cover. narinig ko ang pasok ng air, so parang may partial vacuum sa loob ng gas tank.
Parang same lang ang filler cover ng avanza at innova.
But the filter is clean w/o the black soot as illustrated.
February 19th, 2010 04:48 PM #20
According to the owner's manual, it is normal to hear escaping gas when you release the filler cap. What's not normal is when you hear metal popping sound coming from the gas tank.
When I did my 2nd tank replacement, there were also another Innova on the service bay with leaking gas tank. Notably the dent portion and the leak portion is identical to mine. The other Innova on the service bay was also Gasoline variant, I could smell the gasoline fumes and the service crew pull it down and gave it away to a sub con man that I interviewed and the sub con man says it was a backup job and they would seal again the leaky portion
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
