Page 140 of 179 FirstFirst ... 4090130136137138139140141142143144150 ... LastLast
Results 2,781 to 2,800 of 3575
    Feb 2012
    #2781
    I have an Atis 2003 at the moment, and I feel it's a very good all-rounder. The look is a classic, spacious, and I haven't found it really lacking in power. That's why after looking around for all sorts of vehicle that is to my liking - the Tucsons, Ecosports for the crossovers, the Mirages, Accents, Picantos, Celerios, Fiestas for the hatchs, and the Teana, Almera, Ciaz and Vios for the sedans - I have come back full circle to the Altises. My interest in them though is basically focused in the 2011 to 2012 models only. My brother has the Altis 1.6V 2016 and I've decided I don't need all the features and gizmos that comes with it. Also, the 2011/2012 models are in a sweet spot right now ranging from P350k to P450k. Just two years ago that I was looking at these same models they're still at the P550k to P675k range for the "V" variant.
    #2782
    Quote Originally Posted by gearhead000 View Post
    akurin! 2003 E AT ako. but i find it a little cramped inside.
    would you know, if the 2011-13 model is more spacious?
    #2783
    Masikip din 10th gen. Barely better than the similarly aged Mazda 3.
    Front seats are too thick and not sculpted to increase rear legroom, unlike the Vios. Shoulder room is good though and at least flat floor.
    11th gen ang super luwag na Altis. Beats everyone in its class especially because of its flat floor which the Civic and Sylphy don't have.
    #2784
    My 2010 Altis 1.6 G M/T is due for 45k PMS. I called speedyfix, labor is P200 only! That's it. Nothing else to be done daw. They will just check the spark plug and brake.
    BTW, this is the oil and oil filter I bought in 2015 pa. It was never opened. Tama ba? Can you please recommend a good brand of spark plug (please give name and model/part number)
    What else can I ask them to check (aside from battery health)? I never check under the hood btw
    original spark plugs are probably platinum, it will last long. they inspect if it really needs changing. have them clean the ac filter.
    Feb 2012
    #2786
    Spark plug brand? Most likely Toyota branded but actually NGK.
    I have had only good experience with the Toyota 5W-40 fully synthetic oil. Could be had relatively cheap from alternative sources. I also use the largest Toyota oil filter that would fit in the space allotted for it. Usually for Camry yung mga malalaking oil filters na ginagamit ko. Almost same price lang naman nung sa Altis '03. Yung sa Altis kasi ang liit lang talaga and at most probably good for 6 months only. Since fully synth gamit ko I do extended oil change of 8,000 to 10,000 kms. Yun nga lang isang nabili ko hindi talaga kumasya kaya ayun naka-stock lang.
    #2787
    Your manual indicates everything that needs to be checked at 45,000 km.
    #2788
    kaunti na lang... at baka na ako kumuha..
    sineseyls talk ako ni SA. baka mag-taas na raw sa hunyo.
    #2789
    Why not the Civic? Same level of space sans the flat floor.
    #2790
    it's an idea.
    but blind loyalty is difficult to set aside.
    i'm still thinking about it...
    #2791
    it's an idea.
    Advantage of the Altis is a slightly more spacious rear and a more cosseting ride.
    The Civic has an obvious advantage in terms of power without a big hit in fuel economy. This is supplemented by sharper handling that makes the Civic more fun to toss around corners. The current Altis is a big improvement over its predecessors in terms of handling, but the Civic has always been the more athletic car. Not to mention, the Civic has a much more responsive CVT.
    The design and execution of the Civic looks very modern both inside and out, making the Altis suddenly feel old. If there's any chink in the Civic's armor, it's the awful steering wheel with cheap control buttons. It doesn't even come with leather! However, the Altis also mucks it up with the interior as the facelifted version comes with yellower seats and side trim, it looks like it has hepatitis.
    In terms of toys, they are both pretty well-loaded - Bluetooth, automatic climate control, keyless entry, and so on. The Civic just feels more high tech with the space-age head unit and instrument panel.
    Overall, order is back in the compact car world. While 2014-2016 saw the Altis being better than the FB Civic in almost every way (including handling *gasp*), the FC Civic has struck back. Hard.
    If you want a sporty all-rounder, get the Civic. If you want a more conservative option, get the Altis. If you want all-out handling, Mazda 3.
    Feb 2012
    #2792
    You may probably call me conservative, so I like the 10.5 gen Altises. Hehe. The 11th gen not so much, as it has that Vios feel (and look).
    Have also searched around for Mazda 3's and wow, they can be had for Php250k or so now. That's for 2008 or so models though. Are they any good?
    #2793
    I agree that the 10.5 gen V Altises look rather timeless. Interior looks clean also, but really feels like 2008. No hint of Bluetooth or even USB connectivity in this 2011 facelift. Heck, the FD Civic had aux in 2006, it only became standard for the Altis after the facelift.
    Drive is also boring. Slow steering, soft suspension. Although it does feel more communicative than the equally dull Civic FB.
    As for the gen 1 Mazda 3, it's a truly timeless car that was way ahead of its class when it was first launched in 2004. I'm referring to the 2-liter of course - the 1.6 was underpowered and thirsty. They both go for the same price in the secondhand market, so it's a no-brainer to go for the 2.0R.
    My 2004 Mazda 3 has better steering and handling than all the other compacts I've had (10th, 10.5, 11th gen Altis, and FB Civic). It's a blast to drive down mountain roads.
    Engine power is good, but the 4-speed transmission and 1340 kg curb weight bog down an otherwise sprightly performer. I was surprised to discover that my 10.5 gen Altis actually has better performance despite having 19 hp less, most likely due to the being 100 kg lighter and having slightly closer gear ratios. Because it's such a heavy car, the brakes also feel insufficient under hard braking despite having 4-wheel discs all around.
    To be fair though, these performance nitpicks only apply to hard driving. In typical city or highway cruising, there's nothing to complain about with the Mazda 3 except the dismal 6 km/L fuel consumption.
    The Mazda 3 (2005 onwards, 2004 wasn't as well-kitted) also comes with a lot of features, more than its contemporaries:
    ✔ Sunroof
    ✔ Leather seats
    ✔ Leather steering wheel
    ✔ Automatic climate control
    ✔ Aux connectivity
    ✔ Steering wheel audio controls
    ✔ Flip key
    Ride quality is also better than any subcompact in the market right now, although of course the benchmark for compacts has been raised. Space is adequate, almost the same level as the 10th gen Altis.
    Parts are actually quite abundant, both in Banawe and in Mazda dealerships. I've replaced quite a number of parts in the 2 years I've had the car, and I haven't really had a hard time finding them.
    All in all, the Mazda 3 2.0R is the best compact you can get under 250k. The next compact I'd recommend is an '09-'11 Civic FD 1.8S or 2.0S, but those cost over 100k more.
    Feb 2012
    #2794
    Wow, that's carb territory already. That's really quite a bummer. My '03 Altis still gives me 8.5 to 9kms/L in city driving. I'll be going to Batangas tomorrow and will re-test the FC for highway driving. Highest I got previously was 14kms/L pure highway.
    #2795
    My city driving is lower than most because it's purely heavy traffic. I live in a CBD and work in a different CBD and the traffic in between is horrendous.
    With the same route, my 2015 Altis MT is lucky to get 8 km/L.
    But yes, 6 km/L is the norm for most 4AT 2-liter compacts. We also had a 2.0V 10th gen Altis and consumption was similar in that kind of traffic.
    Jun 2009
    #2796
    I have a 10th Gen Altis. My next PMS would be 40K kms. Do you have an idea how much would l spend at CASA for my next PMS?
    1. What parts are to be replaced?
    2. How much is the labor cost?
    Thanks!
    #2797
    Anyone have an idea how much wipers are? Mas mahal ba sa casa o sa speedyfix na lang ako bibili?
    #2798
    ano problema ng wipers mo?
    try mo muna linisin with denatured alcohol. wala pa 1 year yun wipers ko noon pero nag-skip/streaks na sya.
    heto ginawa ko, ok na sya ulit ngayon;
    #2799
    It's definitely over 2 yrs old na :P Mga magkano ba wiper? 1k? I forgot already
    #2800
    i have no idea sa price ng wipers ngayon.
    pero sigurado taga sa casa iyan, better call them first then compare sa labas.
Toyota Corolla 10th Generation Altis Owners [continued]
