^The fronts are heavier therefore the tyre will bulge more. That's normal. You may want to try also placing around 32-33psi instead of 30.
the past month, my AC blower sometimes gets stuck up and gets noisy, na minsan kailangan ko pa pukpukin yung ilalim bago tumakbo.
may instances na naka on na yung blower ng auto AC pero walang hangin na lumalabas, until pukpukin ko yung ilalim ng gloves compartment.
i have tried having that checked with Ceejays, sinabi malamang blower nga.. nung nagtanong ako kung magkano, its around 6.5k....
meron pa kaya akong makukuhanan neto na mas mura?
I don't think blower ang may problema boss.. This problem is same with our Toyota Revo.. The culprit on this problem is the coil under the dashboard.. It is usually located under the passenger seat in front.. Minsan kailangan mo syang pukpukin para gumana.. You need to replace this which cost 3-4K.. Have it check sir, i had this problem also in my 99 corolla..
[QUOTE=vinj;2621931]Replaced the front shocks of my Gen 10.5 (55,000kms). KYB Excel G's cost P 3,250.00 per piece at Toyorama. I forgot how smooth the Altis can be. :D
Sir Vinj, shocks lang po ba pinalitan niyo at dapat may iba pang mga parts ang sinasabay kapag papalit ng shocks? At sa Toyorama niyo rin po ba pinalitan ng shocks?
Pasensya na po sa mga newbie questions. Salamat.
try mo sir sa Cool drive. kahilera ng southville international school.
kung galing kang casimiro, papuntang CAA road, siya una mong makikita bago mag southville. nasa right side siya.
Palit ko sa AC blower ng pang 2nd gen vios P1.5K (surplus unit; kasama na labor sa installation), 2 years ago, hanggang ngayon ok pa din. baka same lang sila ng pang altis.
meron ding mga taiwan replacement.
[QUOTE=cocoy_g;2636259]Shocks lang pinalitan. All other parts are a-okay. I had the work done at Motech in Pampanga as that's where i go for general service of all our rides. You can try Wheelers Suspension Haus in Banawe (N. Roxas St.).
We're selling our Gen 10.5 so i'll be replacing the rear shocks too, before the car finds a new owner.
Hi ask ko lang po sa mga naka 10.5 gen na altis nagkaroon po ba ng problem yun steering nyo? yun kapag kinakabig mo me tunog at kapag rough road e me kalampag sound? pinacheck ko kasi dati steering shaft daw problem then dinala ko sa toyota quezon ave kasi nakita ko me recall pero ayaw nila aminin kelangan pa daw investigation etc..
ngaun balak ko na sana ipagawa kasi bebenta ko na.. me alam po kayo nagaayos or saang toyota ko dapat dalhin pare irepair nila?
thanks!
thanks!
Madami possible causes, yung sakin pinalitan ko muna mga ball joint, tie rod end at stab link. Nung andun pa din pinalitan ko naman ng cv joint at rack & pinion (mahal na). Dun nawala yung kalampag.
The common issue is the rack and pinion, and possibly busted/weak shock absorbers. If you unit is still under warranty then have it replaced as that part costs 24K out of the CASA (and around 18K in Banawe for brand new original). Surplus is around 8K including installation but you wont be sure how long it will last. Try another dealer beside TQA as i hear not-so-good stories before about their service. I personally went to Toyota North EDSA and Shaw before and was satisfied with their service.
In the case of my 2012 GEn 10.5, the problem came out after 50,000kms. As i was out of warranty, i decided to try first a surplus unit. It got lessened (particularly the tok sound when turning) but the light "thug" sound on uneven pavement went away completely when i changed to new KYB gas shocks.
Sold my unit just last week and the new owner found the suspension to be very solid when he tested it, as compared to the other Gen 10.5's they checked out (with even lower mileage).
hmmm san ko po pwd i pa repair if ever? and pwd ko ba sya ibenta din ng as is? or walang bibili pag nadiscover nila na me prob?
lumalabas lang kasi sya kapag rough road pag smooth naman un kalsada wala ako naririnig..
Finally gonna have my 40k oil change!
Anybody here who experienced their ALTIS not starting? I experienced it this morning and it's kind of weird, parang walang redondo, tried it I think more than 5 times, the lights are flickering in the cabin. I tried it again a couple of times and until such time na parang na discharge na battery, afterwards dun pa nag start. the MID reading was reset, except the radio.
Went to casa afterwards to have it checked, but unfortunately the problem was gone or should I say the car would start in just one click. Hayyyyyyyyyy ano kaya problem nito? Anybody here who has experienced the same thing and what was the real problem and solution would be greatly appreciated. TIA
