Results 1,121 to 1,130 of 3575
August 7th, 2012 10:00 PM #1121
August 9th, 2012 09:15 PM #1122
yesterday my rear sonars are acting up. when i shift to reverse, the beeping sound of the sensors goes rapid like its detecting something at close range even though there's none. i turned the sensors off and on again this evening and its back to normal. hope it does not recurr.
grounded due to rains?
August 9th, 2012 09:22 PM #1123
- Apr 2010
- 201
August 9th, 2012 09:36 PM #1124same experience here...basta tuloy tuloy buhos ng ulan nagkakaganun yung front and rear na sonar ko...after few days e normal na ulit...im not sure kung normal yung ganun pero sa manual nakalagay na normal lang.
Tsikot Member Rank 3
- Jul 2004
- 1,540
August 9th, 2012 11:20 PM #1126Has anyone here installed door lamps?
Hassle lang even the 2.0V doesn't have door lamps. And ask ko lang, baduy ba if I install rear fogs without changing the
brake lamps to the red lens type?
So far ours is at 1,100 kms and is due for service already. hehehe wala pa din plate. Itong kotse namin pinakamatagal makuha yun plate.
Thanks!
August 9th, 2012 11:47 PM #1127
Door lamps? Our 2.0V has:
Looks complicated to have them installed outside. Magbubutas ka pa, then you're gonna have to tie up the wiring to the dome lamp.
- Jul 2004
- 1,540
August 9th, 2012 11:59 PM #1128
August 10th, 2012 09:27 AM #1129
Buti nalang low end yung model ko... Walang sonar sonaran all around (aftermarket rear back up sensor lang) :D
Walang kaso yan. Mine is like that as well. I thought of changing it to the red lens brake lamp however i changed my mind when i saw that the ones being sold were not LED type.
Gash, 5,000km na ako so i have to go in for service in a week or two. Why can't Toyota come up with service intervals like Honda (every 10,000kms)?
- Oct 2010
- 77
August 10th, 2012 12:33 PM #1130Re door lamps, 10.5 doesn't have it anymore, 10th gen has it starting from the G model. You can buy the lamps from the casa, costs around 500 each. Though the wiring was omitted by Toyota so you have to do the wiring as well.
Re the rear fog lamps, for me its better to change the brake lamps to red as well, to complement the euro set-up. but having the brake lamps stock with the rear fog doesn't make it baduy for me. actually, i have a rear fog but my brake lamps are still the stock ones.
Is it true na may recall ang yaris cross hev recently regarding sunroof issue? Lol.
China cars
