Page 111 of 179 FirstFirst ... 1161101107108109110111112113114115121161 ... LastLast
Results 2,201 to 2,220 of 3575
    #2201
    ^ Unfortunately the 2.0L CVT seems to be quite rare but so far, i have not heard of any problems. How about the previous gen Lancer CVT? Any reported issues?
    Ah I see. No news is good news, I guess. So far, the only issues I've heard are from the previous Gen City/Jazz. Not much on the other CVTs. I'm supposing the other manufacturers did their homework. Subaru's also using CVT, if i'm not mistaken.
    #2202
    ^ So i'd assume that with Subbie, Toyota and Nissan going for CVTs, the technology is more promising and should eventually be more reliable.
    Nov 2011
    #2203
    What do you usually ask your SA during or after PMS checkup (e.g. battery, tires, aircon?) ? Will be having my 25K checkup this week probably in Toyota Makati or Bicutan.
    Aug 2010
    #2204
    Quote Originally Posted by kiamoyman View Post
    Ask first what their routine is: what parts are usually replaced, etc. That way you have an idea if may sinisingit sila extra sa PMS bill slip mo. Then if you're not knowledgeable on your car, ask for its condition: how's my battery voltage, how's the tire treads, any part that needs my heightened attention?, etc.
    #2205
    I certainly hope so, bro. No news is good news. Unless you've got an inside track on some problems that Toyota is not divulging to the public.
    Dec 2013
    #2206
    Hi Tanong ko lang po yung toyota altis 1.8g 2005 model Automatic Transmission ok po ba hindi po ba matakaw sa gas? hindi kasi ako makapag post ng new thread eh. comment naman po kasi im planning to buy yung mileage nya asa 60k+
    #2207
    Quote Originally Posted by mcar View Post
    there are many internet addresses that publish car reviews of various brands and year models. many of them are local. i suggest you "let your fingers do the walking". i-google mo lang po. you may be surprised at the variety. i was.
    Jun 2010
    #2208
    Guys,
    I've been experiencing this lately: RPM going too low that engine trembles. It mostly happens after braking to a full stop and occurs for 1-2 secs. The thing is, it happens intermittently. What could be the cause of this? Does it need idling adjustment?
    #2209
    ^ Try cleaning the MAF sensor first, perhaps? Or check the IACV/AAC (the part that controls the idle)? Seems to be related to something that regulates or controls the idle. Is it consistent with the A/C on and off? Have you changed spark plugs recently?
    Jun 2010
    #2210
    Thanks Vinj for the reply. I'm actually clueless about that MAF sensor. Does it need regular cleaning? I'll research about it then and check it tomorrow. About the IACV/AAC, that's my main guess also. Maybe the idling is too low?
    I noticed that it's more consistent when the A/C is off. But nonetheless, I also experience it when turned on specially on heavy traffic. Spark plugs were changed 2 PMS's ago (10,000kms).
    #2211
    The MAF (Mass Air Flow) sensor is located right after the air filter/airbox. That's the part with the wire connected to it; you can disconnect the wire and (carefully) unscrew the MAF sensor housing. When you remove it, you spray electric contact cleaner into the sensor (don't touch the hotwire inside, just spray as it's a sensitive part). Install the sensor again after cleaning it and you can also unplug the battery to reset the ECU overnight then see in the morning if there's any improvement.
    The MAF takes into account the air flow intake of the car so the ECU can determine the proper A/F mix. This gets dirty over time and can affect performance and idling a bit.
    What's the mileage of your ZZ by the way? If it persists after cleaning the MAF then you'll have to check and clean the IACV and perhaps the intake manifold na rin. A competent shop/mechanic can do the job if you're not familiar with the DIY work involved.
    Jun 2010
    #2212
    Okay, I did catch sight of that part already. I just didn't know what it is for. Cool, now I get the picture. I believe I can DIY this MAF for now and see if it solves the issue. If not, then I have no choice but to bring it to a mechanic. I'll keep in mind IACV and intake manifold. ZZ is 50,000kms old. Is it a candidate already for those defects?
    #2213
    ^ Should not be, IMO. Our 2007 ZZ is running at 92,000kms and it still idles well; Linis MAF lang every 10,000kms. This is even using a K&N filter.
    Jun 2010
    #2214
    Oh btw, I just switched to K&N filter this last PMS. Could it be a culprit? haha Okay, I'll try cleaning it and hope it turns out successful. Thanks again!
    PS: Where can I find this electric contact cleaner? What's the exact brand and label?
    #2215
    ^ I'm using K&N on both my Gen 9.5 and Gen 10.5 and they're quite okay. As for the electric contact cleaner, meron sa mga True Value and Ace Hardware; just check out the automotive shelf (LPS, CRC, Hardex, etc.)
    Nov 2011
    #2216
    Had my 25K PMS last Thursday * TGC. Total bill was around ~5.8K (change oil fully synth). Is it reasonable?
    #2217
    How much is the charge per L of the oil? At Toyota Shaw i was charged 1.4K for my 25K PMS but this was because i brought my own oil... So if FS oil is around 800++ then that's 4K+ for 5 litres of oil (make sure they return the leftover oil to you because the engine only needs 4.2L-4.3L; you can use the extra oil in your next PMS).
    Nov 2011
    #2218
    According sa receipt:
    Element Kit, Oil: 327.67
    TGFS Gallon: 2555.97
    TGFS Liter SM 5W40: 638.99
    Gasket: 31.42
    Misc B: 435.71
    I/A Braking Lining & Drums: 627.20
    Total Labor: 1058.4
    Grand Total: 5675.36 PHP
    Oohh. I didn't know na pede pla hingin yun extra oil. I'll know better next time. Btw, where do you buy your oil and how much? Is it better than the oil used by toyota?
    Thanks sir vinj.
    Nov 2013
    #2219
    Ang mura ng sa inyo boss vinj. nag 20,000 km PMS ako last saturday. topup lang ng 1 Liter fully synthetic na oil, inabot ng 4,600 (Air filter lang ang pinalitan)
    #2220
    Gasket: 31.42
    Misc B: 435.71
    Total Labor: 1058.4
    Thanks sir vinj.
    Ang hindi ko lang ma-reconcile is the inspect/adjust of the brakes and drums which had a separate charge as this should be part of the labor charge for that service stop. Did they use any brake cleaner?
    Quote Originally Posted by cornelius035 View Post
    I buy my oil now from an online seller (Jard at sulit) or from Doc Otep (ZIC brand); the 10W-40 ZIC A (semi-synthetic) is around P220 per litre and i change this every 5,000kms.
    Here's the breakdown of my 25,000kms service at Toyota Shaw last October:
    Perform 25,000km check-up (replace engine oil/filter, inspect air filter, inspect brake pads and disks, inspect steering wheel linkage)
    Labor - P 862.40
    Oil filter element - P 327.68
    Gasket - P 31.43
    Misc. - 250
    Total: P 1,471.50
    i brought my own oil here. So far Toyota Shaw/Ortigas accepts owners who bring their own oils. Other Toyota CASAs do not (as was my experience with Toyota North EDSA).
    Normally the service intervals na 5,000, 15,000, 25,000, 35,000, etc. are "light" service stops. Mas mabigat yung mga every 10K and 20K. Yung heavy service stops are the 40K, 80K as these usually include flushing all the fluids...
Toyota Corolla 10th Generation Altis Owners [continued]
