Results 581 to 590 of 3575
June 26th, 2011 11:27 AM #581
June 28th, 2011 02:00 PM #583
True. Singilin kaya natin sila sa suspension repairs ng mga oto natin, haha.
- Oct 2006
- 261
June 28th, 2011 09:12 PM #584Haaay more than 2 months na wala pa rin plaka namin from Toyota Alabang....may officemate ako kakahuha lang ng Honda City 2 weeks ago, may plate na ngayon! Kudos to Honda Cars Kalookan!
June 28th, 2011 09:17 PM #585
June 30th, 2011 04:08 PM #586
Have your guys tried turning off the ECO feature? I turned off mine and the car seemed to run lighter and faster. I'm still checking on fuel consumption with this feature turned off.
- Feb 2011
- 10
July 1st, 2011 05:36 PM #587I have on my 1.6g at. Its just the indicator light that you could switch off and not the eco feature itself which built into the engine.
On drive mode, the eco light indicates if you are stepping right on the accelerator for optimal fuel efficiency, which equates better fuel consumption and more environment friendly.
Stepping hard and sudden and if you down shift to lower gears, eco light is off and altis will deliver the power and speed desired with normal fuel consumption.
July 2nd, 2011 01:20 AM #588
July 2nd, 2011 01:24 AM #589
I turned it off immediately after getting the car. Have it on again now, as recent info I have was it's only an indicator light when one is driving economically. In theory, there should be no difference, and it feels like no difference so far, but have never done a full comparison with fuel consumption. Open still to possibilities, and will await your findings on your test.
July 2nd, 2011 09:55 PM #590
sir autobeat, if insinuating foam or rubber doesn't work, you can actually remove the A-pillar trim by pulling it towards the center, and add foam more liberally. just a gentle tug so as not to break the clips. good luck sir.
Nissan PH Boss: We're not going anywhere | Autoindustriya...
Nissan Philippines
