I believe isolated case yan, 2 months ago naiwan ko nabukas headlight ko sa parking for more than 3 hours, battery is almost dead engine would not start pero gumagana pa power door locks, pinagpahinga ko lang ng mga 10 minutes then tried the ignition again and broom ok na uli.
salamat po sa mga nagreply regarding sa LPG conversion... seriously thinking about it.. :D
mga ka ACP,
WHile the use of LPG offers a relief, our car in the philippines are not design for that. Marami na ako nabalitaan na nagpaconvert. I am not sure of the safety aspect-whether nasa loob or nasa labas. I have some foreign friends from Asia who uses LPG on their car. The good thing I heard from them is that, Their cars are engineered/designed for LPG. Meaning the leak test and other safety aspects were considered by the car maker. My 2-cents...
LPG conversion nowadays is not Totally complicated, I think for Newer Car SGI is the best conversion so farJapanese Cars can be easily converted to LPG according to some LPG converting Shops unlike other Car brands
Good day!
Re: sa NOise level...dami pa pala factor.. pwede tires and road condition (rough,asphalt, etc)Thanks po sa mga nagreply!
I would just like to know the relationship of avanza kph and rpm. have you observed the rpms at certain speeds (for the last gear 5th MT, 4th? AT)... let's say, for the car i'm driving (1.6L A/T) it usually CAN shift at 2000rpm and at 4th gear, (fortunately the rpm gauge has small increments) 70kph is slighlty above 2000rpm. 80kph ~ 2300rpm, 88-90kph ~ 2500rpm. etc. I usually cruise control (manually staying at a speed) at 70-80kph (if i'm not in a hurry). minimum at 4th gear could be at 65kph, but will have a tendency to downshift. Is it 3000rpm~80 or 100kph for avanza?
1a)
So i could ask if what observed rpms are there for a MT/AT last gear:
60kph (if applicable)
70kph
80kph
90kph
100kph
some have posted 120kph
etc (if applicable)
1b) at highest gear what speed(kph) is at 2000rpm (if not indicated above)
2) Also at top speeds, have you experienced any vibration due to high speed on the avanza? My tires are nearing replacement (one factor probably) and i experience on a sedan at 100-110kph the vibration... OR at what speed have you experience this on your Rides (any ride)
TIA!
More Power! God Bless!![]()
A/T * STAR
80kph = 2,500rpm (very stable)
100kph = 3,000rpm (ok pa din)
120kph = 3,750 rpm (medyo matagtag na)
140kph = 4,250 rpm (todo kapit na sa manibela)
Sa Avanza G A/T ko:
60kph - 1925rpm (?)
70kph ?
80kph ?
90kph ?
100kph - 3125rpm. This one's from _Qwerty_ (naka G A/T din siya): _Qwerty_, pahiram, ha. hehe.
During our trip to Subic last May 30, I managed to capture some stills. Educated estimates lang ito, analog kasi ang speedometer natin:
114kph - 3575rpm
119kph - 3740rpm
121kph - 3800rpm
128kph - 4000rpm
132kph - 4125rpm
145kph - 4500rpm
I think 2000rpm will get you around 65kph.1b) at highest gear what speed(kph) is at 2000rpm (if not indicated above)
I have observed no abnormal vibrations at all. Even at 130kph with only 3 adults on board (average weight 155lbs).2) Also at top speeds, have you experienced any vibration due to high speed on the avanza? My tires are nearing replacement (one factor probably) and i experience on a sedan at 100-110kph the vibration... OR at what speed have you experience this on your Rides (any ride)
Heto ang sabi ni theveed, sir:
http://tsikot.yehey.com/forums/showp...8&postcount=33
Hope this helps...
Wow! sobrang haba na ng thread. Dami pating info, hirap humabol. Ang gagaling din ng mga DIY.
Question ko lng. Nung isang araw bigalng ayaw ng mag-on ng stereo ko. Busted kaya fuse nito?
Hello po.......
Bro, kung mahigit na one year na avanza mo, malamang battery na yan. I had the same problem last week. akala ko grounded lang sa body. Kasi every morning ayaw na mag start(Tulak lagi), ginawa ko tinanggal ko yung cable sa battery para sure na maraming karga.. the next morning, ayaw na naman... Sabi sa battery shop, mahina na yung battery.. at exactly 14 months. Sabi ng toyota, 12 months lang ang warranty or 20K sa odometer which ever comes first. Sa nagpalit na ko ng baterya to 1SM, swak pa rin dun sa holder, also have to replace the terminal. Cost me P2,100 swapped na rin yung old battery, non free maintenance. After that... okey na ulit.
Btw, sabi dun sa battery shop, may tendency daw na m self discharge ang battery pag luma na.... which i agree afterwards.
HTH..
Originally Posted by rv_flores![]()
Thank you po sa lahat ng contributors ng avanza forum, very helpful. Congratulations!
Last week, I had to jumpstart my Avanza G after not using it for 5 days. Yesterday, pinatulak ko nanaman po para makauwi from office. Looks like my battery is busted. Mukhang nag chcharge nman ang [COLOR=blue! important][COLOR=blue! important]alternator[/COLOR][/COLOR] kc nawawala nman yung battery lamp indicator kapag nka start na. Nevertheless, dalin ko sa Toyota Pasong Tamo sa monday para ma-check ang electrical. Sakto nman 15Km Chang oil na din.
Has anyone here experienced this? Or is this an isolated Avanza issue?
Baka may advice din kayo mga guru...I'm all ears.
Cheers!
Hey! kamusta na mga Avanzers? Haven't been posting and attending EBs... dami gawa sa office...
Regarding RPM vs Speed, how much difference po ba sa J engine (1.3)?
Thanks po!
Sa mga nag-reply sa inquiry ko. maraming maraming salamat sa inyo, lalo na sa iyo, Sir woohoo sa pag attach mo ng comment ni sir theeved.
sus, talagang binugbog ng husto ni frank ang iloilo. first time na nangyari iyan.
Btw, sir woohoo, regarding doon sa diehard battery, achu-chu mo, mga magkano ba ito?
