mamaya na ba yan?? ay sya!!! what time??
Sir RCastro,
May email ako sa iyo. Re: sticker.
Sir Jaspi,
Thanks for mailing the stuff. I will let you know as soon as I get hold
of them.![]()
FYI, nakapag install na ko a/c switch, pics to follow. Maghapon ako naghanap ng switch sa banawe sa surplusan hangga narating ko yung isang drawer na puro switch. Unfortunately wala nag fit kahit isa. May nakita ko maliit pang hi-ace nung tinest ko di uubra iba ang circuit nya high resistance.
Punta ko toyota 2500 pesos daw, by order pa 3 weeks pa dating fog lamp switch pa yun wala daw sila a/c sw.Punta din ako SM kasi may nakita ako fog lamp switch, di parin nag kasya, para mag fit kelangan kaltasan yung mounting hole. Sigh....
So I ended up buying push pull switch nalang yung pang motor. Saka nalang palitan pag may nahanap na si marfin.
good pm po... newbee ..... ask ko lang kung cno may alam na murang central lock and alarm. thanks![]()
Nakita ko na yung source ni eabanilla re:removing center panel. Di ko lang sure kung mavi-view ninyo kung hindi kayo member... Heto siya.
Marami ngang useful DIY's doon, kaso medyo eyesore yung formatting ng posts. Or maybe it's just me, spoiled sa formatting ng tsikot. Hehe.
Eto mga pics nung installation ng A/C switch:
Dyan ako nag insert ng switch (series connection dyan sa thermostat yung square), di maganda kiha nag reflect yung white plastic
Nag abang na ko ng linya (pinadaan ko sa flex conduit plus tape sa maga dulo para safe, although walang power dumadaan dyan signal lang in mA)
Eto na yung temporary switch
*woohoo: similar sir sa switch ng L2 mo, Pull to on, push to off.
Good day po sa inyo... a newbie here but an old avid reader of this forum, although trying to catch up dahil ang dami na ng posts... anyway, a few questions lang po regarding the third row seats:
1) Would a wheelchair fit at the back with the third row folded, so if the width of the inside fit a folded wheelchair?
2) What things/baggage would fit at the back if the third row is positioned (seatable).
3) What configuration/s is/are there that could maximize cargo space with 7 passengers (eg adding roof rack) are there other options? And has anyone seen or experienced or reconfigured their third row space to be side facing (2 pax on each side)? Pros and cons of this set-up. [[SIZE=1]I think i have seen one plying the route of ayala (fx style).] [/SIZE]
Tia for the info.
More power!![]()
A regular-sized wheelchair should have no problem fitting in there.
Not much... It's too narrow.2) What things/baggage would fit at the back if the third row is positioned (seatable).
Aside from installing a roofrack, you can ask the passengers to occupy the 2nd and 3rd rows, leaving the front passenger seat and foot room free for cargo.3) What configuration/s is/are there that could maximize cargo space with 7 passengers (eg adding roof rack) are there other options? And has anyone seen or experienced or reconfigured their third row space to be side facing (2 pax on each side)? Pros and cons of this set-up. [[SIZE=1]I think i have seen one plying the route of ayala (fx style).] [/SIZE]
This was our configuration when we went to Subic last May 30. The bags/knapsacks that contained clothes and other small packages were behind the 3rd row seat, while the food and the rest of our cargo occupied the front passenger space.
HTH...
1. With the 3rd seat folded, it may be posible to fit 2 unfolded, standing wheel chairs.
2. instead of using 1 or 2 big bags, we use small bags so that we can easiy fit stuff behind the third row seat.
In this configuration, a folded wheel chair might not fit.
3. for more cargo space, the roof rack is the final option.
changing the 3rd row to 2x2 facing each other might not be a good option since you will be limited to a low seat height. Since the avanza is narrower than an AUV, knees might be touching. I am always not comfortable seating at the back of an AUV with the seat facing each other. This is due to the low seat height.
wow ngayon lang ako nakasilip uli dito sa thread natin.. di ko na iaatempt na mag-back read kasi sobrang dami na hindi ko nabasa.. :D heehee..
question lang po... :D
maganda bang ipa-convert sa lpg ang avanza? with the continuous price increase of gas, naisipan nyo na po ba magpa-convert din sa lpg? TIA po..
