Boss Chito musta na? I already replaced my Tamaraw FX with a Tamaraw FX RevoI really wasn't really planning on replacing her as we've been thru a lot ups and downs, Bine-baby ko pa nga eh, and truly enjoyed her performance. But my brother kept on insisting that its about time to upgrade, and since he'll be the one to assist on the financials, I agreed. Yes its an upgrade, but all I can say is that, its still worth, in owning an FX! Swerte nga nung matanda na nakabile, para daw kotse kung manakbo, napaka swabe daw
For sale:tamaraw fx gl model 1995 2c turbo,general overhauled may2014 standard piston ring,in prestine condition body and interior,registered2014,never become a hired vehicle,contact 09228440599 baguio city area![]()
hello mga katamtam...
ask ko lang po kung anong magandang radiator cap para sa tamaraw naten diesel po tnx![]()
Mga sir.
Ano po kayang possible cause nito, bago po yung mga tubo ng exhaust at muffler ng FX 5k engine ko pero amoy gasolina sa loob...
TIA po
Mga sir.
TIA po
Check your engine Sir. Does it consumes too much fuel? Probably your engine (or carb) ejects too much gas causing unburnt fuel, thus creating or leaving a somewhat gas smell along your exhaust pipes.
If your existing ignition system works properly, then the Electronic igniter won't do as much as the cause of problem still exist. I suggest you bring your car to a Carb specialist and let him see if the carb is still suitable for an overhaul or replacement. Usually, it just needs cleaning and replacement of several parts such as gaskets, jets, floater valve, etc. The technician should also make sure that the floater is calibrated / leveled properly to eliminate fuel starvation or excessive fuel supply. Make sure also that all your vacuum lines within the carb is working properly.
helopo mgakatamaraw
pa share naman po kung anong klaseng engine oil ang gamit ninyo sa tam. fx diesel ninyo... ung subok na po baguio city area po maraming salamat![]()
I already tried Caltex Delo Gold and Castrol GTX Diesel oils. So far good results.
For Toyota fx with 5k engine.
Pls see the test results of a '96 fx on 'ito ang nuvitron thread' and see how to enhance the fx. however, we will not be answering your technical queries about the test. Address all questions to: Dr. Edgar N. Quiros, VRTL, College of Engineering, UP, Dilliman, QC.
