Page 71 of 81 FirstFirst ... 2161676869707172737475 ... LastLast
Results 1,401 to 1,420 of 1613
    Oct 2004
    #1401
    Maraming lowered sa Grupo Tamaraw FX... https://www.facebook.com/groups/OfficialGTFX/
    Sep 2011
    #1402
    Quote Originally Posted by EssB View Post
    di ko alam bakit dinelete ako sa group na to, ang OA ng admin he he he
    Oct 2004
    #1403
    Quote Originally Posted by chito2011 View Post
    Baka sir nung nag-revamp ng membership/gumawa ng bagong FB group page dahil dun sa isang nag-breakaway na admin na pasaway?
    Sep 2011
    #1404
    dahil yata sa di ako nakapag submit ng picture w/ my tamaraw fx. yun lang he he he.. OA di ba?
    Oct 2004
    #1405
    Join ka na lang ulit sir... ^_^
    Sep 2011
    #1406
    Di na bro... D ko makuha logic nung ganun eh... Parang masyadong mababaw he he he
    Oct 2004
    #1407
    Simple lang yung logic nun... The admin wanted to eliminate bogus members (na wala naman talagang Tamaraw FX) especially yung mga nandun lang to post advertisements, etc.
    Sep 2011
    #1408
    i have a tamaraw fx... they can look at my attendance nung sumali ako sa EB
    i have a tamaraw fx... they can look at the attendance sheet nung sumali ako sa EB, andun pa nga cp no. ko he he he
    #1409
    but if that is the requirement, and you did not fulfil it...
    Feb 2015
    #1410
    May aircon filter poba ang toyota revo glx 1.8efimodel 2002? Denso type,,, kung meron man san ko pde makita ... Pakipost nman pix o any idea jan,, tnx po, newbie lang..
    Apr 2011
    #1411
    helo po
    pashare naman po ung nakafreeflow muffler diyan kung ano ang benefit...tam fx diesel 2ct... marami pong salamat sa mga inputs:bowako
    Apr 2011
    #1412
    sori po double post hindi ko na ma edit
    #1413
    Quote Originally Posted by greg2 View Post
    helo po
    Benefits? Irritating noise. No offense here Sir, but the very minimal to non HP gain is not worth it compared to the hilarious sound it may project specially if its a diesel. Also, in a free-flow setup, the added HP can only be obtained at least during high RPM's which you wouldn't normally do in a diesel. I once had a bigbody Corolla with a 1300cc engine and had a free-flow set-up which is already there when I bought it. The sound is pretty "fast", it felt you're running at about 120kph... But in reality, I was doing only 60kph. Very hilarious and shameful indeed!
    helo po
    Apr 2011
    #1414
    tnx sir jvnj
    May 2012
    #1415
    Δ tunog 120kph takbo 20kph minsan nauunahan pa ng nag jogging.
    Aug 2012
    #1416
    Mga sir, Ano po ba advantage at dis advantage ng centerbearing vs yung diretsong propeller (Transmission to differential na agad)? thanks
    Mar 2015
    #1417
    Hi! Bago lang ako d2 sa tsikot.. Tanong ko kung ano pagkakaiba ng differential na 9:41 sa 10:43.. ung fx ko kasi 10:43 ang differential eh dto ako sa baguio nakabase.. mabagal ung fx ko pag sa akyatan kaya sabi ng kaibigan ko, palitan ko ng 9:41 ung differential para lumakas.. san po kaya pwedeng makabili ng 9:41 differential. pls reply mga sir.. salamat.. 2c turbo pla ung makina ng fx ko mga sir..
    #1418
    helo po
    For a Tamaraw FX, diesel man o gas, walang benefit sa performance or fuel economy. Pang porma, pwede pa.
    May 2009
    #1419
    Quote Originally Posted by ric25 View Post
    tama brad dahil 41/9 = 4.55 gear ratio vs. 43/10 = 4.10 gear ratio....dapat yung quotient ang tignan mo dahil "the higher the number, the lower the gear"...mas maganda itong pang-akyatan.
    #1420
    Quote Originally Posted by kjkarl View Post
    Difference nung dalawa? Flexibility. Mas flexible yung with center bearing. Straight propeller is usually applied to RWD cars whose distance between the front and rear wheels are shorter.
Tamaraw FX Owners
