Page 45 of 81 FirstFirst ... 3541424344454647484955 ... LastLast
Results 881 to 900 of 1613
    Sep 2011
    #881
    Quote Originally Posted by zap.FREEDOM View Post
    ^ ah parkspring, malapit sa may TAT's FILIPINAS GOLF CLUB, tiyaga-tiyaga muna saka ipon, hindi naman talaga mabibigla ang pagawa niyan e, at least wala naman ibang problema (aside from that na mausok nga), just practice enough maintenance, try mo din ibabahin yun mga gas station na pinagpapakargahan mo, dyan kasi sa Total yung malapit na sa may United, medyo may kadumihan ang krudo dyan (bunker fuel ika nga), go for shell or petron.
    yup dun nga. di ako nagpapakarga dun sa TOTAL, plage ako sa shell. thanks
    Mar 2004
    #882
    anybody have tried the hyundai d4bx (? ata, the same engine powering their hyundai grace vans). at first I was a bit skeptical pero ng ipinakabit ko sa PUJ ko sa probinsya, it performs well. then I learned that it was the Korean counterpart of the Mistubishi's 4D56 engine, the same engine powering their pajeros, L200s and adventures.The internal parts were interchageable with the 4D56.
    Ang concern ko lang ng umpisa, bumabawas ang langis after a week's running. Then our driver noticed that kung i-fill up mo sya ng langis a little bit over the full indicator mark ng dipstick (about 1/4 liter over), di sya nagbabawas.
    It has the power and the plus side, mura lang compared mo sa 2CT and L series ng toyota
    Apr 2011
    #883
    hello
    tanong ko lang po sa mga nakapagpalit na ng door sidings ng tam. fx gl kung anong ginamit nyong pang sidings kung ung lawanet pa rin o plywood na kc sa lawanet parang karton na ang quality kung plywood po anong size at anong klaseng tela po tnx sa mga inputs
    Apr 2011
    #884
    huhuhu wala man lang inputs ito nalang ung cause ng hard starting sa diesel kahit warm up na ang engine=)
    Jan 2011
    #885
    Pacheck mo na yung valve clearance mo sir, kaya hard starting kahit na warm up na, regarding naman po sa door sidings mas ok pa din kung lawanet, mas flexible lalo na pag mga door siding, huwag lang mabasa
    Apr 2011
    #886
    tnx sir kiantothindi ko nabangit diesel pala ang tam ko
    Apr 2011
    #887
    hello po
    tanong ko lang po kung ano ang original psi ng radiator cap ng tam.fx diesel pang 3 rows radiator po salamat po
    May 2009
    #888
    Mga tol, inquire lang ako.
    Nagpalit na kasi ako ng Pressure Plate, Clutch Lining, Release Bearing, Gear Oils pati na din ang Clutch master. Pinalitan ko nadin dalawang cross joint sa ilalim, pero di ko talaga mapinpoint kung saan nanggagaling yung grinding sound sa ilalim. Lumaos na kasi mekaniko ko, sa ngayon naghahanap pa ng ipapalit. Maaari niyo ba ako tulongan? Sana mabigyan niyo ako ng bagong theories. Salamat.
    Apr 2011
    #889
    tnx
    Sep 2011
    #890
    Quote Originally Posted by burjegol View Post
    sir, ano daw ang dahilan bakit pag pinasobrahan mo sa full ay di na nagbabawas?
    yung tamaraw fx ko kasi ay ka ka change oil ko lang nung august pero last week lang ay nagpakarga ulit ako ng engine oil kasi mauubos na naman. is this normal? sabe kasi ng ka opisina ko senyales na yun na kailangan ng ipa calibrate yung makina kasi baka daw may diperensya na. di raw kasi basta basta mauubos ang engine oil unless may problema na ang makina. thanks
    Mar 2004
    #891
    Quote Originally Posted by chito2011 View Post
    Yan sir ang di ko kayang ipaliwananag. but the driver (PUJ kasi ito) kas kept on doing this till the time na ibinenta ko na ang sasakyan, with no ill effects whatsoever to the engine
    Aug 2010
    #892
    ^pag-ganon nagbabawas ng langis sa diesel engine, it's either may leak pero if there's no possible leakage in the engine, ibig sabihin, nagsusunog na ng langis ang 2c engine nyo sir,
    Apr 2011
    #893
    goooooood sunday to ol
    simple question lang ako sa mga experts,nagpalit kasi ako ng steering wheel at may trade name ung s.wheel ask ko lang kung papaano igitna ung manibela kapag naka steering lock po ba o kapag in motion salamat po
    #894
    Mga boss question po san po kayo nag papagawa ng Tamarraw ninyo? carb po kasi siya eh. may mga recommendations po kayo sa may bandang paco or binondo area? nangingig kasi siya after i tune-up
    Apr 2011
    #895
    wala nang gaanong aktib sa mga gurus naten
    anyway magtatanong parin ako baka bc sila, kc magpapasko.....brummmm..ask ko lang po kung bakit pagka start ko ng fx ko ay bigla nalang siyang manginginig nawawala din. baka kako may problema na eh hindi naman cxa dating ganun
    Oct 2011
    #896
    Very rugged vehicle. This is my ride before.
    Jan 2011
    #897
    Quote Originally Posted by greg2 View Post
    Bka hindi accurate yung flow ng diesel sa engine
    Apr 2011
    #898
    halo gud day
    ask ko lang sa mga nakakaalam kung ano ang disposable engine sa 2c.tnx sa inputs mga gurus
    Jan 2009
    #899
    Quote Originally Posted by midasproject View Post
    baka po e sa mga bearing na po yan
    Jan 2009
    #900
    sir i plug ko lang po ang GRUPO TAMARAW FX
    visit nalang po kayo dito sa site at mag register lahat po nang tanong nyo sa tamaraw ay masasagot salamat
    - Home
Tamaraw FX Owners
