Page 38 of 81 FirstFirst ... 2834353637383940414248 ... LastLast
Results 741 to 760 of 1613
    May 2011
    #741
    Good Day po sa lahat ng FX owners!
    Nadiscover ko po ang forum na ito while I am trying to find solution to my FXgl model 95 and I hope makuha po ako ng idea or answer sa experienced owner in this forum:
    1. Need ko po mag palit ng power steering pump (shafting type) para sa 5K ko, meron po ba kayong marecommend na place to buy or repair? taga San Mateo po ako nakatira.
    2. Pa recommend naman po ng mahusay na shop for Top overhauling, wala na pong power yung FX ko, gumagapang na po paakyat. Pinacheck ko yung clutch disk at Ok naman...
    Thanks in advance .....
    Apr 2011
    #742
    standard toyota 2c engine...
    help naman po.... 2 weeks na or 14days na engine ko sa mekaniko...pina overhaul ko na engine ko per advise niya. changed piston ring, conrod, gaskets, pins, liners/sleeves...even rephase/reface ng cylinder head and etc...now, i have a problem, hind pa rin umaandar/start engine....dati, b4 ko pinagawa ok pa andar ng fx ko...sabi ng mekaniko ko nag aadjiust lang daw cya ng timing, tried buying more diesel, recharging the batteries, pumps, tubes replaced, other parts and many more... then explain na naman cya na sa valve clearance, hindi daw bumubukas... d nya ata alam ang exact valve clearance... any help on this matter is greatly appreciated...4x na po na baklas ang cylinder head assembly...grindin na nya ata bukas ang iba pang parts sa cylinder head...sa may parang cups...
    Last edited by mcoy2k; May 9th, 2011 at 11:56 PM. Reason: texting style....edited words to be more readable...thanks!
    Aug 2010
    #743
    *greg2 - sir, regarding sa concern mo.. sagutin ko nalang po para makatulong. sad to say pero baka blow by na nga po engine mo. kasi sir dapat di mag release ng blue na color na smoke. kahit na stock pa yan ng 1 month hindi pa din dapat ganun. yung blue smoke po ay sign ng blow by. ano pa po ba experience ninyo sir? hard starting po ba pag umaga? pag mainit na po?
    Aug 2010
    #744
    Quote Originally Posted by mcoy2k View Post
    sir, saan ba location ninyo? naku sir mukhang palpak yang mekaniko ninyo ah.. napapagstos na kayo ng malaki sa kanya.. suggest ko palit na kayo ng makaniko.. pero wag niyo ipaalam sa kanya. baka babuyin ang makina ninyo.. sa qc marami akong kilalang magaling na mekaniko
    Aug 2010
    #745
    Quote Originally Posted by FX95GL View Post
    paakyat lang po ba gumagapang sir? baka naman po timing belt na problem. pacheck niyo po timing belt. minsan kasi yun ang major cause ng lack of power ng engine naten
    Aug 2010
    #746
    Quote Originally Posted by rrdanas View Post
    Hi mga sir! tanong ko lang sana, gusto ko kasi salpakan ng turbo ung original 2C engine ko for tam fx. anong advisable brand and configuration para dto?
    TIA
    sir, wag mo na salpakan ng turbo.. malaking problem lang yan pag yung nabili mo hindi okay.. suggestion lang naman po sir.
    Aug 2010
    #747
    Quote Originally Posted by Rhome View Post
    mga sir, gusto ko po sana palitan un body ng tamaraw fx ko. standard/ base model po ito '96 diesel 2C. pareho lang po ba ito ng sukat ng ibang model ng tamaraw fx (deluxe) o un base model lang ang pwedeng ipalit sa kanya? salamat po sa mga makakapag advise.
    sor, standard model po is deluxe din. ang gagawin mo po is gagawin mo siyang gl..
    pwede po yun.. palit ng grill, headlights, signal lights, bumper, stepboard. voila!
    Apr 2011
    #748
    yup, dinala ko nalang sa bahay... its been 3+ weeks na d pa rin nagawa 2c ko, now with a new mechanic, hope na magawa nato engine ko perwisyo na masyado... d2 lang me pre sa negros....
    Apr 2011
    #749
    yup, dinala ko nalang sa bahay... its been 3+ weeks na d pa rin nagawa 2c ko, now with a new mechanic, hope na magawa nato engine ko perwisyo na masyado, new valves, new sleeves, starter checked, pumps and nozzles checked, glow plug 2x nag palit ng bago. d2 lang me pre sa negros....
    Jan 2011
    #750
    *FXGL95...Boss Try mo dun sa Guinayang, pangalan ng talyer " ALL IN ONE SHOP" kanto mismo pagliko Hanapin mo si Roger yung mekaniko dun, cya kse ang gumgawa ng ride ko, banggitin mo na lng "Ian Revo" thanks
    Jan 2011
    #751
    Ok nga din mga bossing kung skali magpalit kau makina ilagay nyo 3C, malaks cya humatak, halos d magpaiwan sa Revo diesel
    May 2011
    #752
    Mga sir, salamat sa lahat ng nag reply, it will be a big help...
    Apr 2011
    #753
    hello po mga gurus
    tanong ko lang po kung ano ang normal temperature sa gauge ng fx natin ung sakin kc naka point sa 3/4 ng half normal po ba ito?salamat po...at saka po katatop overhaul po cxa nagpalit ng piston ring c.h.gasket vavlve seal pero ang kinalabasan ay blowby parin ano po kaya ang kulang sa ginawa ng mechanic salamat po ulit....
    Apr 2011
    #754
    sir kuligligko good evening po ask ko lang idea mo kung bakit blowby parin ung fx ko samantalang natop overhaul na..change piston ring napo cxa c.h.gasket valve seal,valve guide....tapos ano po ang normal pointer ng temperature gauge sakin kc sa half ng gauge ay 3/4 cxa...salamat po
    Apr 2011
    #755
    sir baguio din ako pwd malaman no.mo regarding my fx problimatic po ako eh he...he...09274603000 no. ko tnx
    Apr 2011
    #756
    mga master enlighten din u po ako fx owner din po ako...naka free wheel ung hand break ko kasi kapag nakakabit umiinit/dumidikit ung 2 preno ko sa likod......ngayon na hindi nakakabit ang handbrake kapag tumatakbo naman mataas cya kapag nakahinto mga after 5 mins mababa na ano kaya ang dahilan kung bakit ganito....nagpalit naako ng rubber cap na overhaul na din at ilang beses na din pong naaadjust......ung clutch fluid ko din nagbabawas normal kaya ito maraming salamat god speed
    Apr 2011
    #757
    mga gurus help pls ung fx ko pag start ko parang kinakapos up/down ang rpm nya tapos todo ko na ung gas ayaw magalit....
    Apr 2011
    #758
    *seanrock pna top overhaul ko pero ganun pa rin...change valve seal.piston ring,c.h.gasket,piston guide pero walang pinagbago ano pa kaya ang d ginalaw ng mechanic....tas ung preno sa likod overhaul,change rubber cup and plenty of adjustment pero ayun kapag inilagay ang hand break dumidikit/mainit ung breakdrum kapag free wheel naman mataas ang preno habang tumatakbo bumababa in 3 mins kapag nakahinto ano kaya ang problema pa...ung clutch fluid ko nagbabawas normal kaya ito?tnx bro
    Jan 2011
    #759
    Boss regarding dun s RPM m ayaw kamo tumaas, eh marami din pwedeng pangalingan, p check m din sa calibration ung injection pump, at dun sa handbreak, check m ung spring at plagyan m din oil ung cable ng handbreak bka stock up na din un kse ung handbreak, cable lng nman din un
    Jan 2011
    #760
    sa clutch mo naman sir d normal na magbawas yun ng fluid check mo yung master nya at secondary sa ilalim kung may lek na cya, kailngn na palitan ng repair kit
Tamaraw FX Owners
