*MAXBUWAYA,
Congrats on your new ride. You really made a very good comparison and decision based upon your needs.![]()
*MAXBUWAYA,
Max, Thanks for a very informative reply.
Galing ako sa Suzuki Caloocan nag test drive ako with wife and my youngest daughter. Ako nag drive and I notice that my left feet has no place to rest because of the wheel well. BTW test drive unit is A/T. Ride is very much improved because of the coil spring. Power for me is just enough but I notice that shifting is almost 3k RPM w/c stressfull for the engine. I estimate worst consumption is 6.5km/lt and Best maybe will be around 8km/lt. One more concern of mine is the flat nose of the APV it is very unsafe if accident may occur. Generally it is great but looking around the showroom I saw this beautiful 2door Jeep The Jimny. Ang pogi cute sabi ko kay kumander yan na lang bilin natin Im sure better FC yan compare with APV.But it doesn't serve the purpose.
Anyway we will probably will get the APV. and The Jimny (I wish)
sir larshell looks may be deceiving, pero the nose is intended to act as a buffer for additional frontal collision. i suggest 50% discount dun sa dealer na pagbibilhan mo ng jimny and apv ;)
Max, Nice bike! I guess I need to bikes also para I can join you in your biking session.![]()
share ko lang experience ko sa APV. manual/1.6/dual aircon.(brand new-wala pang plaka.)
dagdag ko lang sa mga good comments nila:
makalas ang hatak/arangkada.
madaling makigulo sa traffic dahil nga sa igsi ng nguso.
ok lang sa likuan kahit around 80kph.
napatakbo ko na ng 120kph pero parang hanggang doon lang. anyway subukan ko sa hi-way yun one of this days.
FC nya ok. its averaging sa 8kpl after 4th full tank.
.... 1st 7.8kpl.... 2nd 6.9kpl.... 3rd 9.4kpl....
-always in the same pump- shell super unleaded.
-always naka aircon yun.
-35psi tire pres.
-stop and go halos lalo na sa busy hour.
-mostly 7pax. 3 is the least.
at masasabi kong hindi ako light-footed driver. just ok lang, oovertake, lulusot at aarangkada kung kinakailangan.
yeah, bike is good and good is bike hehehehe
Update ko lang\\\
notice that the ride harap parang ramdam mo ang pagup and down ng sasakyan reminds me whenever I drive an L300 van.
Ok naman power mukhang adequate naman. (D pako mastado nalampas ng 3000rpm)
Gas consupmtion is still the same allthough i manage to achieve 12.5km perliter nuong nagtagaytay ulit kami.
Walang pala siyang child safety door lock, which i think mas kailangan since this is mailny for the use of family. ngayon lang kami nagkasasakyan na wala nito. How expensive can that be to put on anyway?
Wala din siyang beeping sound when you left the headlights open. again, how expensive can that be??
Sa loob ng hood sa may radiator bay parang may mga part na kinapos ang pintura.! ARGH!!! hehehehe
Yung ibang plastic part sa loob parang may mga sobra, like them cheap toys from china!.
Unloading from the trunk is quite tricky because king mabigat binababa mo like a mineral water container malaki chance mo na magsgasan bumper mo kung hindi ka malakas. yung dalwang tindera manin parehong nagsgasan rear bumper.. Grrrr!!
Well so far so good at nearly 1000km
To all owner of suzuki APV did you know that..
The Mitsubishi Maven is an MPV sold by Mitsubishi Motors in Indonesia since September 15, 2005.[1] It is a rebadged Suzuki APV with minor exterior cosmetic changes, and is built locally by a subsidiary of Suzuki Motor Corporation.
It is available in two trims, GLX and GLS, both with a 1468 cc gasoline four cylinder engine producing 87 PS (86 hp/64 kW) at 5,500 rpm, supplied by Mitsubishi's Indonesian engine production partner, P.T. Mitsubishi Krama Yudha Motors and Manufacturing.
http://en.wikipedia.org/wiki/Mitsubishi_Maven
yup sir alanthanks for the info. patay yan pag dumating sa pinas yung maven. malalaman nila san nanggaling ang design. ask ko lang sir do you know what mitsu engine the maven uses? its 1.4 compared to the 1.6 g16a engine of suzuki.
tanong lang po sana sa aircon ng APV. Malakas po ba? kaya po bang palamigin ang sasakyan after parking during HOT day? thanks!
[quote=MAXBUWAYA;1133568]yeah, bike is good and good is bike hehehehe
had the same problem at first bt all i did was to buy a 3M non slip tape ( about 600-700 pesos). positioned it on top of the bumper area..............problem solved.........you just have to use a brush to clean it since it is rough.
no problem with APVs dual aircon................malamig. it doesn't take too long to cool the interior even left under the sun for a long time. even also if the car is full..........
never had a problem with the cooling effect..............more than enough. i seldom maximize the thermostat.............the normal thermostat position is only at the start of the blue mark.![]()
i discovered recently something about the battery of the APV.........it is a lot smaller than a 1SM battery. according to the APV casa, it can only be bought from them at around 8-9k.............another revelation is that it is not maintenance free.........so you better make sure you check the water level every now and then.............. this was my mistake...........i am used to having maintenance free batteries in my cars so when my wife noticed that the APV doen't want to crank, i immediately checked the battery and to my surprise, the battery is soooooooo dry!
my mistake! i thought it was maintenance free! i immediately bought battery H2O and used it for about an hour without turning off the engine. it happened about 3 months ago and until now, the battery seems to be ok............have not tried checking with the local motolite store if they have a battery similar to that of the the APV. but i regularly check the water levels now........
I think its reverse polarity with small post same with Jimny
Naging problem ko iyan with my Jimny. Wala akong mahanap with local brands (Sabi ng iba meron daw motolite) Ginamit ko muna yung sa APV hehehehe pareho sila. I ended up buying GS brand Battery d tubig. P2600
in Banawe
Tinging ko yun sa APV mukhang puede naman bumili ng hindi reverse polatrity
Dahil mukhang aabot naman sa kabilang side mga terminal both positive and negative
and the aircon is cold. hindi ko na masyado binubuksan 2nd aircon.
My only concern is na pag kinailangan iservice 2nd row aircon is mukhang malaking trabaho. Lalo na ceiling mukhang dumihin pag binaba ang aircon sa 2nd row
gud pm! ask ko lang po kung anong magiging problema ng APV in the long term yung engine ay nasa ilalim ng driver seat? hindi po ba sisingaw ang init sa loob. sabi nila naka 7 layer insulation. paano po yun... thanks!
sir max,
i plan to get an mpv glx type 2, 8 seater, m/t before the year end and i'd like to get the best deal i can get from different dealerships as well as the best after sales service. i'm acquiring it thru a car loan scheme and i'd very much appreciate your inputs and if its not too much to ask, may i also ask the freebies you got. thanks in advance!
daycode, we seem to have the same time table for acquiring an apv, if its ok with you, lets exchange infos about the offers we will get from different dealerships and we can also negotiate together so we can have stronger bargaining power. this is just a suggestion, i would understand if you turn it down.
