Good AM. Tanong ko lang ano bang engine coolant nilalagay sa APV natin na check ko kanina sa akin at nasa Between full and low na siya, mga nasa 1 inch na lang yung coolant niya. Or sa casa ko na lang din palagyan, how much kaya damage pag youn lang?
Posted via Tsikot Mobile App
Prestone Ready Mix coolant sir,sa Ace meron.make sure na ready mix talaga sya Para Hindi kana mahirapan mag mix ng coolant and distilled water. Pero based sa manual between full and empty talaga sya Pero pag normal operating temp na umaangat.ganyan din yung unit namin.
Sa Blade meron tag 90 pesos lang ready mixed na. Oo nga pala mga sirs, apv ga ko clocked 10980km. Urgent na ba talagang ibalik to sa casa? late na kasi dati kong change oil around 6k na before. Any advise?
Salamat.
If you used mineral oil to your last PMS,kailangan na,since every 5k or 3 mos whichever comes first ang OCI ng mineral,kung outside casa ka mag papa PMS make sure that the oil that you are going to use had comply to what Suzuki requires.
Opssss. kailangan na din pala talaga. Mag 11k na pasok na din sa 5k interval.
May naka-100,000 kms na ba sa inyo? My matic Type II APV has logged in 99,800+ so far. Ano na naging problema ninyo? Sa akin, it never gave me a headache. Nagpalit lang ng Auxiliary fan other than that never ako nagkaproblema. Once in a while the stock stereo turns on by itself. Makina, suspension so far in top condition pa rin.
Sir ikaw yung nag post recently sa FC? 2010 tas yan na mileage mo?
Ano difference ng ignition coil and fuel filter problem for suzuki apv?walang hatak and pugak pugak,nalinis na fuel filter ganun pa rin.please advice.Thanks
two mechanics said ang prob ng apv ko ay fuel filter.yun na nga kaya?not coil ignition?kailangan pa ba mag pa diagnose sa casa?i want to make sure kasi ang mahal ng fuel filter around 18k Thanks
If you know someone who also own an APV try to borrow his Ignition Coil and High tension wires pag umayos yun yung sira,yun yung nasa gilid ng valve cover mga black na malalaking wire.parehas naman na medyo mahal yan.
magandang tanghali po
help po mga masters
may idea po ba kayo ng pricing ng mga ff parts ng 2010 apv ga 1.6?
-brand new cylinder head assembly (oem)
-surplus cylinder head assembly
at kung saan po may malapit na mapagbibilhan ng brand new oem at surplus parts ng apv ga somewhere nearby paranaque area??
maraming salamat po sa makakatulong.. Godbless
Zuk Macapagal 5561575. Parang mahirap humanap ng non oem, try mo sa wrecker or links banawe.
HI , i got a BNEW APV high side yesterday chose the Base Model w/o AC, any suggestions to where i can have the AC system installed? Casa is Charging 30k , my location is makati area , no problem po if the reco shop is not within the vicinity,
thanks in advance
[QUOTE=OJ213;2421800]HI , i got a BNEW APV high side yesterday chose the Base Model w/o AC, any suggestions to where i can have the AC system installed? Casa is Charging 30k , my location is makati area , no problem po if the reco shop is not within the vicinity,/QUOTE]
OJ213,
Try checking out Denso aircon shops. Wish they could give you a good deal.
Archnemesis what happened with your APV? 4years Parang and your looking for a cylinder head replacement?
Greeting's guys...I also too has a suzuki apv ga....thank goodness i found this thread anyway, i would like to ask about the uneven tire wear of our apv ga basic model...search google, ask friends, ask mechanics but they cant really tell me whats going on why my tires has uneven tire wear? i had my apv align almost every change oil i thouht that it might fix the problem but it did not....can you help me guys about this uncommon problem of the apv....did we find any solution? please please help....thanks guys hope to see on the road someday....give me a beep i'll fly with you....lol....thanks again...![]()
Hello po mga master, ano kaya problem sa steering ko may tunog pagliliko lalo na kung galing ako sa pagkakapark. Parang walang steering fluid ang tunog. Yung fluid naman niya punong puno wala naman leak.
