Page 104 of 134 FirstFirst ... 45494100101102103104105106107108114 ... LastLast
Results 2,061 to 2,080 of 2668
    #2061
    guys, paano tangalin yung hu unit... planning to put a digital tv tuner box kasi, kailangan ko yung input for the video in and audio in
    diy ko lang
    #2062
    ^ You have to remove the side bezel. If memory is right, clock and lower dash has to come out first, need to drop the glove box for better access.
    *Oj, ive read some post here(doc otep if im not mistsken) philhino is somewhere at osmena/ssh, they have ac parts and install them for a fee..
    *jon, what kind of sound " lagatok" or " whirring". If its lagutok, id check for worn stab links and hub bearings. Had similar noise and it was the bearing.
    *tank: doesn't have camber alignment. Had my upper control arm hub-mount filed to make the adjustment. This was discussed already, just backread some pages.
    Nov 2014
    #2063
    Sir 12vdc, sir do you know any shop that can do the job uneven tire wear on our APV? this would be very helpful cos i really dont know much about this kind of situations...I'm from Quezon City thank you sir....
    #2064
    boss apv 2 walang clock and di na stock radio nakalagay kasi upgraded version from casa. bezel- yung carbon fiber sa sides?
    May 2012
    #2065
    Yes sir yung carbon side...kapain po yung pinababa ng carbon side meron yung maliit na butas fit dun yung negative na screw tas idiin mo yung screw aangat na Yon.ingat lang baka mag crack.walang knot/s yan.
    Nov 2014
    #2066
    Hello again, Sir I have a Suzuki APV ga the basic one...sir i would like to ask if we can install aftermarket tachometer for our APV? I would also like to know what shop? Im from Quezon City...thank you sir....have a nice day...
    #2067
    Quote Originally Posted by jyg1995 View Post
    maraming salamat boss jyg
    Oct 2011
    #2068
    Good evening fellow apvians :-)
    * sir 12vdc and sir straker and sir jyg1995: thanks po sa inputs nyo po.. well good thing at hindi na po ko umabot s punto na kelangan magpalit ng cylinder head.. :-) but sad too say i've lost it.. maybe for good tho..
    Recently visited some college mate somewhere in q.c, I saw a 2010 model 2012 acquired black apv ga type II selling for only 150k (The selling price is quite tempting) I tried making querries and found out that the van isnt running and the owner told me (chinese) that he took advice from his mechanic and told him that there's problem in the cyl. Head. Caused by poor maintenance leading to breakage of timing belt.. I was planning to buy it as pangharabas so I did canvassing already for some parts.. well sadly someone bought it on that day.. well hindi nga siguro para sakin yun :-)
    Anyways, any ideas mga master kung saan makakabili ng spoiler ng apv natin?? mine was 2010 ga type II.. white one thanks for inputs.. ride safe..
    May 2012
    #2069
    ΔΔΔBack read ka sir,Page 148.
    Jun 2014
    #2070
    Hey guys,
    any way we can improve the FC of our APV? 5km/liter talaga pag pure city drive.
    Although when i went 100Km north of Cebu it went up to 8.3/liter so ok lang.
    I have Type II A/T 45,900km odo reading
    Had my emission test the other day, sabi ng suki tester ko normal daw:
    here's the reading:
    CO2 10.08%
    CO 0.04%
    HC 98 ppm
    O2 7.63%
    Lambda 1.50
    AFR 21.89
    this was taken at idle, normal operating temperature.
    any thoughts on this? please share.
    Thanks!
    Mar 2007
    #2071
    Quote Originally Posted by TANK-T21 View Post
    Walang tacho ang basic? I thought it was a standand instrument for all APVs.
    There are lots of aftermarker tacho's around Banawe. Seek, ask, and you shall find.
    Mar 2007
    #2072
    Quote Originally Posted by archnemesis View Post
    Front spoiler, I would assume? Personally you shouldn't buy it. If up against floods or need to run over island, you need all the ground clearance you can get.
    I had a Carryboy catalog with first-gen APV accessories. The front nudge bars were ***y you should go after those, if they exist here, and for newer models. Good hunting!
    Aug 2009
    #2073
    hi guys, just some info , i have a BNEW Gen 1 APV Carry, been to PHIL-AIR for A/C Quote, charging me 38K for the front cabin and 50 if dual AC, SUZUKI dealer in makati is charging 30k for the front cabin AC, bakit ata mas mura sa CASA parang imposible naman :D , checked out local shops also charging 30-35K using bnew parts, Condenser lang ang Surplus
    Evangelista Shops:
    BNEW compressor 14-16k
    BNEw Evaporator(laminated type) - 4500-5k
    Bnew EXp Valve- 1400-1600
    Hoses and fittings - 2500
    bnew Drier - 800
    AUX Fan - 1200
    Belt - 400
    labor and freon - 4000
    warranty 6 months
    Oct 2014
    #2074
    Hello sirs, about 3days na may squeaking sound sa rear door ng apv ga ko. 15 months pa lang tapos meron ng ganito. Ask ko lang kung anung remedyo ang gagawin ko para totally mawala. Salamat.
    #2075
    apv club members and owner never experienced any squeaking sound(those who bought it brand new and 2nd hand) mostly pag 2nd hand the problem is on the engine and tranny- not well maintained by the previous owner.
    i understand your dilemma, if your vehicle is still brand new, have it checked, suzuki service and warranty claims is a smooth a silk(i guess this depends on the casa) try to claim the warranty.
    if it's not brand new, and if the pms is not religiously followed... warranty would be void.
    Oct 2014
    #2076
    Quote Originally Posted by victorevolution View Post
    Brand new pagkabili ko sir, nag back thread ako page 174 may nakita akong nag post regarding sa squeaking sound, walang klarong sagot actually di naman siya nagtanong. Sinabi lang nyang downside ng apv is squeaking sound sa rear door. Baka kasi may naka experience ng dinadanas ng apv ko ngayon. Salamat.
    Jul 2014
    #2077
    Ganito rin nangyari sa akin 2 days after nauwi ko unit ko (GA) nag-SQUEAK yung right front door. Nawala nung nilagyan ko ng WD40 ang hinges pero bumalik din kinabukasan, dinala ko sa casa in-adjust nila hinges saka nawala tunog.
    Mar 2007
    #2078
    Quote Originally Posted by danding View Post
    *keno - magkamukha apv natin. black lang tint ko. second hand din pero mas luma sa akin 2005 model. hehehe
    ang repairs ko lang so far eh minors lang naman. ganyan talaga sa segunda mano sir. kung minsan tsambahan lang.
    1. 2 loose thread stud bolt and nut.
    2. brake pads.
    3. change air cleaner.
    4. change 3 pcs wiper blade.
    5. change stabilizer link ( right and left) <- kasalanan ko hehehe. meron pala humps eh malakas ulan (BLAG!) nayupi tuloy.
    ngayon ok na lahat. so far so good. naglagay nako headreast monitor and change headunit with indash monitor.
    planning to buy separates/amplifier/subwoofer sa makati. saan ba maganda bilihan na malapit lang sa ayala?
    boss, san ka nakabili ng stabilizer link?
    thanks!
    Aug 2009
    #2079
    good day mga sir, what is the ave fuel consumption ng APV gen 1? thanks
    I have a Bnew APV Carry FB type with dual AC, 500 KM on the ODO reading
    haven't established my AVE FC yet pero initially naka 2 full tank na siya on a 500km run
    Nov 2014
    #2080
    Mga batikan na sa APV kelangan ko po ng tulong niyo. Nagpaplano po kasi kaming bumili ng sasakyan (fiirst car namen) at namataan namin tong APV. mas mura kasi siya kumpara sa Avanza ng kalaban at mas malakas pa ang makina. Eh nasa 600k lang po ang budget namin kaya hindi po kaya yung top of the line na APV II ba yun. Ayun po. Ito po yung tanong ko:
    Ano po ba ang maganda sa APV kumpara sa Avanza at malakas po ba ito sa gasolina? Ano po fuel consumption?
    Hindi ko maintindihan din yung sa sinasabi nung mas mahal na version ng APV GA na dual aircon. Medyo malaki kasi difference niya compared dun sa tig 575k na GA. Ano po ba ibig sabihin nun?
    Hindi po ba mabilis magkadiperensya?
    Madali ba makahanap ng parts kung sakali pong ipapagawa sa labas after ng warranty?
    Okay naman po ba sa akyatan? ex. aakyat ng baguio tapos puno with bagahe.
    Panget po ba yung APV GA kumpara sa APV II? Yun lang po kasi ang kaya eh. Paki state na din po ng differences nung dalawa.
    Salamat po sa sasagot. Makakatulong po ito sa pagdidisisyon namin. Sa ngayon kasi medyo 40-40 po ang laban ng Avanza at APV sa aming mga isip. Yung 20 mag-commute na lang daw. hehe.
    M/T nga po pala ang balak namin kasi mas matakaw daw ang A/T. Totoo po ba yun? Pakikorek na lang po kung mali. )
Suzuki APV [Merged Threads]
