Page 101 of 134 FirstFirst ... 5191979899100101102103104105111 ... LastLast
Results 2,001 to 2,020 of 2668
    Jun 2011
    #2001
    Thanks sir dito ako sa may bandang sgt rivera qc naka hanap. Yung sa LTO need ko ba ngayon siya or sa next year na sa pagpapa rehistro ko? 2012-2014 kase itong apv ko so sa 2015 pa ako magpapa rehistro.
    Posted via Tsikot Mobile App
    #2002
    Pwede now na para may mapakita ka receipt incase flagdown ka. Or pwede mo i-delay kung hindi ka naman madalas sa expressway/ prov roads since dyan lang naman madalas may nanghuhuli.
    Jun 2011
    #2003
    Actually kaya ako nagpalagay babiyahe kase ako nextweek sa cagayan.
    Jul 2006
    #2004
    For Suzuki, global models have standard modulation protocol. Most non-global doesn't support(some toyotas are also like that).
    it's just disappointing that a standard obd ii reader doesn't work on our apv's. having to see the fuel consumption, air/fuel ratio and other sensors can be a big help.
    Jun 2011
    #2005
    imageuploadedbytsikot-forums1410653191.069199.jpg got the rail already installed.
    Jun 2011
    #2006
    imageuploadedbytsikot-forums1410653251.411169.jpg aerorack muna for the mean time, kung talagang palagi ko siya ggamitin, palitan ko ng heavy duty na since may rail na naman.
    Mar 2007
    #2007
    Quote Originally Posted by [JaNuS] View Post
    Maybe Suzuki doesn't want to share its proprietary protocol. Is this protocol applies to all their model?
    The ODB dongle (Vgate) is plugged on my Escape. The downer is it doesn't read the fuel level, I have to set it manually.
    If I get my Ford serviced at Speedyfix, I'll ask Mig to test his Scangauge.
    #2008
    Scanguage doesnt read those sensors (fuel, oil gauge). OBD2 is more on emission control (fuel+air delivery, cam position, coolant temperature, air volume, atm pressure,boost, and everything happening inside the engine)
    You have to manually set the size of the tank and fuel-type for the scanguage to compute FC.
    Not so accurate just like those built-in the dash.. Mas accurate pa rin yung manual procedure.
    Jun 2011
    #2009
    Hello,
    Sorry kung palagi ako marami tanong, gusto ko lang malaman magkano ba yearly registration nitong APV natin. Next year pa naman ang sa akin gusto ko lang malaman ng mas maaga. Salamat.
    Mar 2007
    #2010
    Quote Originally Posted by JonJon Villegas View Post
    Hello,
    2300+ sa LTO Pasig. Hindi pa kasali ang emission, insurance, etc.
    Since I had her with a new set of tires, luv ko siyang I-drive
    One advantage I had with my APV, kaya kong sumingit sa traffic. A feat I can't do with the Escape, or other rides.
    #2011
    of all our current rides (7 in all) only the suzuki apv gave me almost no headache(almost kasi dealer lang ang nagbigay ng headache tulad ng pang gagasgas sa loob ng auto)
    but in fairness though our apv is 3 years old, it only clocked at less than 30k on the odo.
    not that fast but can attain good enough speeds, nimble that you can glide to traffic with ease (in our suv s'... despite the raw power you can only stay in one lane since it's way to big -in stop and go traffic- heck i can only use it's raw power pag di traffic sa skyway)
    Jun 2011
    #2012
    Im in alcala cagayan now, wow my fc 14km/l. Full tank at 38liters then already traveled 350kms hindi pa ubos at marami pa gas pero ayoko mawalan ng gasolina sa hindi ko kabisadong lugar. Kaya nagpa gas ulit ako to full tank again, nasa 24 liters naikarga ka balik full tank ulit. It means 350/24=14.... Tama po diba?
    Loaded pa ako with 6 adults including me plus 3 kids. At punong puno ng gamit yung sa likoran, then sa roof rack may wheelchair pa.
    #2013
    Good day to everyone!
    May gusto lang ako itanong about sa camber ng APV naten. Ano ba madalas kumabig sa APV nyo? Kaliwa o Kanan?
    Yung APV namin kasi almost 5 months ko na pinaayos yung camber & alignment.. pero this month medyo nararamdaman ko nanaman kumakabig sa kanan. May dapat na kaya ako palitan?
    2nd, my odometer hits 60K Km.. okay na ba yung mag basic PMS na ako or lahatin ko na? Any tips and guides? Thanks!
    Jun 2014
    #2014
    Hello fellow APV owners!
    my unit is finally fixed thanks to Suzuki Cebu NOrth! replaced the piston rings and valve seals (genuine SGP). turns out it was pooling oil in the valve cover baffle due to sludge. so the oil gets sucked into the pcv valve. had to replace the valve cover too.
    Now it runs fine and no smoke.
    Question: what fuel do you use? some say that Petron unleaded is better because its 93 octane. would appreciate your thoughts on this.
    I'm also looking for OEM 2 din stereo for our APV, the one that has USB and aux in. my 2008 model still has the tape deck you can text me at 09223213082. i'm in Cebu, by the way so we'll just have to ship it here.
    thanks in advance!
    Jun 2014
    #2015
    Quote Originally Posted by Eman Dela Cruz View Post
    Hi Eman,
    as far as I know they have a list of things they need to check every PMS depending on the mileage. usually kasama lahat ng fluids and probably brake pads. yung saakin nag palit ako ng shock mount bushing on my 45K PMS kasi may alog na, then they aligned it (not included sa PMS) butmy camber was ok.
    hope this helps
    #2016
    *apvboy, plano ko kasi sa Shell Service ipagawa or ipa-PMS. Ako nalang mag pprovide ng Brake Pads, Oil Filter, Spark Plugs, Belts kung kailangan. Yung engine oil and transmission oil sila na ata mag provide since may package/promo.
    Kelan ba pwede palitan yung Clutch disc? Every shift ko kasi ngayon napansin ko medyo may onting kadyot.. Not so sure kung epekto lang ng hindi pa na tune-up at maintenance, or may bara kung saan man..
    Jun 2014
    #2017
    check na din differential oil if ok pa.
    Clutch disc usually if it starts sliding na. sometimes sa engine or transmission support lang ang problema pag may play na. better pa diagnose sa mechanic bro para sigurado. Good luck bro.
    #2018
    Thanks for reminding. Yun pala kulang ko differential oil. Ipa-check ko nalang yung clutch disc, hindi pa naman sya nag-sslide so sana okay pa.
    About sa unleaded gasoline naman na question nyo sir, Shell FuelSave unleaded gamit ko after ko mag pa tune-up last April 2014.. So far okay, at malaki talaga FC ko di tulad dati na kung saan saan akong Gasoline station. Hirap pa naman linisin yung tanke at fuel filter..
    Anyway, sino na kaya nakasubok dito sa Pinas na ganito ang APV? 9 seater type.
    Since hindi ko masyado nagagamit yung likod at nagiging compartment nalang balak ko gawin ganyan..
    Apr 2010
    #2019
    magandang gabi team apv! anybody free for a grand eb? im targetting a saturday or sunday afternoon at jt's ihaw ihaw at home depot for free parking and good priced food.
    May 2012
    #2020
    Ayos yan sir Eman kaso nakakahilo pag ganyan,by the way you are asking for 60k PMS? Wala na po ba sainyo yung user manual nyo?
Suzuki APV [Merged Threads]
