Quote Originally Posted by suysuy View Post
Recap ko lang guys.
Replaced already the following.
1. Upper suspension arm both sides
2. Lower suspension arm bushings both sides *
3. Rear and front stabilizer links both sides
4. Tie rod end both sides
5. Sprock seat assembly front both sides
6. Ball joint assembly both sides
Other job done:
1. Overhaul front brake calipers
2. Replaced brake master assembly
Casa recommendation ito lahat but I bought my parts online.
Still, may problema ako. Car drives straight.
But upon braking, steering wheel turns counter clockwise. While the front end of my car goes right if you keep the steering wheel straight (only if pipigilan mo yung manibela going counter clockwise) kakanan yung car.
But if you let the steering wheel turn counter clockwise while braking, the car drives straight. Hindi siya kakanan.
Pahelp sana pinpoint anong maaring problema. Naging ganito siya nung nagpa change ako ng lower suspension arm bushing. Hence the asterisk.
And by the way, if I engage 4wd low, put it into drive while stepping on the brakes (car not moving) , steering wheel moves counter clockwise. MEANING may something loose sa suspension?
Very well maintained yung car. 110k mileage na. No major breakdowns. Only suspension or steering issues.
see if your tires are out of round (oblong na).
cars with out of round tires can never be satisfactorily aligned.
the aligning machine may indicate the proper numbers, but the car will wander, once it moves.
