Results 31 to 40 of 93
- 52,727
August 15th, 2018 10:51 AM #31
- Apr 2009
- 429
August 15th, 2018 09:59 PM #32the whole entire OEM A-arm assembly is the best route but expensive. If your A-arm is also with a Shaft Link Kit, better replace it as well especially if you've been using your Sorento on rough roads..
Check also the your Stab Links, Stabilizer bar bushings, etc. You have to change them too if they have seen better days...
September 25th, 2018 11:35 AM #33
Got my original bushings from korea. Replaced old bushings already. But there’s a new problem.
Car drives straight. But upon braking, steering wheel slightly turns to the left (11 oclock position) and the car pulls to the right in proportion to the steering wheel movement to the left.
WHAT COULD BE WRONG?
- Jan 2008
- 4,726
September 25th, 2018 12:04 PM #34
September 25th, 2018 12:09 PM #35
- Apr 2009
- 429
September 25th, 2018 12:10 PM #36It could be that your front brake calipers are sticking up and needs servicing (cleaning and replacement of caliper rubber brake seals, etc) if still feasible. Otherwise, If the caliper piston &/or cylinder are severely pitted, you have to change the whole assembly... Time to change your brake fluid too
September 25th, 2018 12:23 PM #37
- Jan 2008
- 4,726
September 25th, 2018 12:26 PM #38
September 25th, 2018 12:43 PM #39
Update: under full braking force, left front wheel locks up instantly while the right does not.
- Jan 2008
- 4,726
New Car Sales in 2023 by Major Brand Japan’s 223 New Car Sales Rise for First Time in Five...
Car Sales Data (2023)
