Usually the mechanics compensate through the rack end for camber alignment issues. May lock nut yun to prevent it from coming loose and making the steering from being misaligned. Maybe the nut is stripped or could it be the mechanic forgot to tighten the nut?
Good day mga sir.
Di pa ko makacreate ng new thread kaya dito na lang ako magtatanong, related issue naman.
Yong corolla ko po kasi kulang yong turn radius niya pag right turn, left okay lang (or sobra?).
Pag lumiliko tuloy ako kanan, bitin na, need ko umatras unlike before.
Napa-align ko na wheel ko, computerized, so okay alignment.
Any recommendation to check mga boss?
i can't seem to download the video.
but i guess, the rack has to be centered first, before the alignment is performed.
I still have my problem. Although lessened na. Changed all bushings and suspension related parts but still, nandyan pa rin. Ano kaya next ipatingin?
Hindi sir, before rack change, okay yong right turn, means mas less na turn niya ngayon as before. Anyway checheck ko muna, sana may ibang cause, like may bracket or something labg na mali nailagay kaya may tumatama. If wala, check ko yong rack limiter na nasa video, baka meron nga nakalagay sakin. thanks sir.
Yup first owner. Never been into an accident. Naging ganito na siya nung nagpalit ako ng lower arm bushings left and right. Hmmmm
Genuine kia bushings. The whole arm costs an arm and leg. Baka ndi maayos sayang lang pera. There might be something that is causing this. Disc brakes and calipers were already checked. So hindi siya issue sa brakes.
There is something loose when you apply the brakes, it changes the steering angle or the suspension shifts. But im already running out of ideas kung alin sa ilalim ang need pang tingnan
Fasten your seatbelt! Or else...Driven To Thrill!
