Results 81 to 90 of 93
January 15th, 2019 04:59 AM #81
- Jan 2019
- 8
January 15th, 2019 10:47 AM #82I am looking din po to get my car an alignment after I lowered it and the shop I went to denied me cause my car was too low. I drive a Lancer Ex 2010 and would like to know a shop that will accommodate my car Bulacan or Q.C. better po.
My front bumper is approx 10-20cm off the ground.
Thank you sana matulungan ninyo me last time i got my Wheel Alignment 6 months ago pa po please baka may alam kayo let me know.
Thank you so much & God bless
January 16th, 2019 06:44 PM #83
Recap ko lang guys.
Replaced already the following.
1. Upper suspension arm both sides
2. Lower suspension arm bushings both sides *
3. Rear and front stabilizer links both sides
4. Tie rod end both sides
5. Sprock seat assembly front both sides
6. Ball joint assembly both sides
Other job done:
1. Overhaul front brake calipers
2. Replaced brake master assembly
Casa recommendation ito lahat but I bought my parts online.
Still, may problema ako. Car drives straight.
But upon braking, steering wheel turns counter clockwise. While the front end of my car goes right if you keep the steering wheel straight (only if pipigilan mo yung manibela going counter clockwise) kakanan yung car.
But if you let the steering wheel turn counter clockwise while braking, the car drives straight. Hindi siya kakanan.
Pahelp sana pinpoint anong maaring problema. Naging ganito siya nung nagpa change ako ng lower suspension arm bushing. Hence the asterisk.
And by the way, if I engage 4wd low, put it into drive while stepping on the brakes (car not moving) , steering wheel moves counter clockwise. MEANING may something loose sa suspension?
Very well maintained yung car. 110k mileage na. No major breakdowns. Only suspension or steering issues.
Sent from my iPhone using TapatalkLast edited by suysuy; January 16th, 2019 at 06:50 PM.
January 16th, 2019 07:40 PM #85
Di pa ako nakabalik for alignment eh. Dati kasi nung nagpa align ako after a few weeks namimisalign ulit yung car ko (kelangan 11 oclock position yung steering wheel para straight yung takbo) Late na rin nakita basag na yung mga bushings kaya pinapalitan na lahat.
Gusto ko sana muna mawala yung kabig issue during braking before ako magpa align kasi okay naman yung takbo nya if hindi nagpreno. Brakes are okay. Maybe may isang part lang ng suspension ang maluwang hence the symptoms. Matagal2x na tong problema ko.
January 16th, 2019 09:54 PM #86
- 52,700
January 16th, 2019 11:40 PM #87
January 17th, 2019 12:44 PM #88
17 January 2019 - YouTube
Ito yung sinasabi ko. Just to demonstrate my steering issue. Yung nasa video naka stop ako nyan tapos naka 4wd low. So natural yung front axle may power. So while naka full brake then pag lagay mo sa drive, pansin niyo yung steering wheel ko pa counter clockwise. May maluwang sa harap. Ano kaya sa tingin niyo?
January 17th, 2019 01:45 PM #89
with all the parts replaced, mali yun diagnosis. hydraulic steering ata to?
January 17th, 2019 01:50 PM #90
