Page 5 of 5 FirstFirst 12345
Results 81 to 93 of 93
    #81
    pag oil change ko kalikutin ko yun hunter sa tyre shop maybe within 2 weeks. tignan ko yun library ng hunter for vios. for hyundai completo lahat. ako pa yun pumili.
    salamat bro [emoji106][emoji106]
    Jan 2019
    #82
    I am looking din po to get my car an alignment after I lowered it and the shop I went to denied me cause my car was too low. I drive a Lancer Ex 2010 and would like to know a shop that will accommodate my car Bulacan or Q.C. better po.
    My front bumper is approx 10-20cm off the ground.
    Thank you sana matulungan ninyo me last time i got my Wheel Alignment 6 months ago pa po please baka may alam kayo let me know.
    Thank you so much & God bless
    Mar 2007
    #83
    Recap ko lang guys.
    Replaced already the following.
    1. Upper suspension arm both sides
    2. Lower suspension arm bushings both sides *
    3. Rear and front stabilizer links both sides
    4. Tie rod end both sides
    5. Sprock seat assembly front both sides
    6. Ball joint assembly both sides
    Other job done:
    1. Overhaul front brake calipers
    2. Replaced brake master assembly
    Casa recommendation ito lahat but I bought my parts online.
    Still, may problema ako. Car drives straight.
    But upon braking, steering wheel turns counter clockwise. While the front end of my car goes right if you keep the steering wheel straight (only if pipigilan mo yung manibela going counter clockwise) kakanan yung car.
    But if you let the steering wheel turn counter clockwise while braking, the car drives straight. Hindi siya kakanan.
    Pahelp sana pinpoint anong maaring problema. Naging ganito siya nung nagpa change ako ng lower suspension arm bushing. Hence the asterisk.
    And by the way, if I engage 4wd low, put it into drive while stepping on the brakes (car not moving) , steering wheel moves counter clockwise. MEANING may something loose sa suspension?
    Very well maintained yung car. 110k mileage na. No major breakdowns. Only suspension or steering issues.
    suysuy
    hows the toe camber caster sa suspension shop?
    Mar 2007
    #85
    suysuy
    Di pa ako nakabalik for alignment eh. Dati kasi nung nagpa align ako after a few weeks namimisalign ulit yung car ko (kelangan 11 oclock position yung steering wheel para straight yung takbo) Late na rin nakita basag na yung mga bushings kaya pinapalitan na lahat.
    Gusto ko sana muna mawala yung kabig issue during braking before ako magpa align kasi okay naman yung takbo nya if hindi nagpreno. Brakes are okay. Maybe may isang part lang ng suspension ang maluwang hence the symptoms. Matagal2x na tong problema ko.
    Quote Originally Posted by suysuy View Post
    di advisable na steering unahin. suspension muna then steering.
    also nasikipan na ba lahat ng nuts bolts sa ilalim?
    im surprised 11am to center.. thats huge! wag ka na bumalik dyan sa shop na yan.
    #87
    Recap ko lang guys.
    Other job done:
    see if your tires are out of round (oblong na).
    cars with out of round tires can never be satisfactorily aligned.
    the aligning machine may indicate the proper numbers, but the car will wander, once it moves.
    Mar 2007
    #88
    17 January 2019 - YouTube
    Ito yung sinasabi ko. Just to demonstrate my steering issue. Yung nasa video naka stop ako nyan tapos naka 4wd low. So natural yung front axle may power. So while naka full brake then pag lagay mo sa drive, pansin niyo yung steering wheel ko pa counter clockwise. May maluwang sa harap. Ano kaya sa tingin niyo?
    with all the parts replaced, mali yun diagnosis. hydraulic steering ata to?
    #90
    Ang pagkaintindi ko sa part time 4wd dapat sa madudulas lang talaga na surfaces gamitin yung 4wd low. Even 4wd high should only be used on slippery surfaces. Nasisira sya sa regular asphalt/concrete. Di kaya nasira yung 4wd system?
    Mar 2007
    #91
    This is only for demonstration purposes
    Sent from my SM-A605G using Tapatalk
    #92
    Kapag pinasok mo sa casa yan lalo na kung warranty, sabihin sayo "paki balik po stock rims and tyres bago namin gawin"
    Mar 2019
    #93
    hi, can you recommend po any auto shop near kalayaan makati? tie rod replacement. tried google pero along buendia/vito cruz na yung pinakamalapit. kinakabahan kasi ako baka biglang magbreak na siya if ibabyahe ko pa ng medyo malayo. thanks!
Steering wheel alignment issue
