Page 29 of 30 FirstFirst ... 19252627282930 LastLast
Results 281 to 290 of 296
    Jun 2005
    #281
    Kung mag cruven ka din naman, sa main branch ka na nila pagawa sa crame.
    Dont get me wrong. Lagi ako nagpapagawa sa cruven pero sobra sablay yung cruven fairview.
    Either cruven makati or crame na lang ako.
    Sep 2014
    #282
    Quote Originally Posted by RavGirl View Post
    Good evening sirs,
    It's my first time here and I need advise po how much Toyota genuine parts and where I can buy below items.. My car need the following:
    Need to replace right away:
    2pcs Front shocks
    2pcs Rear shocks
    2pcs Stab clamp bushing
    2 front and 2 rear brakes
    2pcs Tie rod
    2pcs Rack end
    2 Front Wheel bearing
    2 Rear bearing
    My Car is 2004 RAV4. 1.8 M/T. And how much would it cost me for the labor to have all these replaced. And ano po replacement parts? Sorry I don't have any idea about these things. My friend used to help me but he moved to US na so I feel so lost. Appreciate all your good recommendations. Thank you.
    Dapat sinana na din upper and lower balljoint as well as stab links. Complete suspension overhaul na to hehe
    Im just curious pano kaya takbo neto sa kalsada, malamang sa last 5 years sira na mga eto
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    #283
    errr... what tires are you using now, po?
    is it possible, them tires are simply too big for the car, kaya sumasayad?
    sabi nga sa akin noong nagpavulcanize ako dapat daw 55 series, kasi 60 yung gamit ko ngayon. pero kasi dati di naman masyadong sumasayad, ngayon lang madalas
    #284
    Quote Originally Posted by sirkosero View Post
    noted sir. madami nga rin ako nabasa na negative reviews though may mga positive reviews din. nabigyan ako ng quote na umabot sa 23k. refill ng shocks, replacment ng mga rear bushing, engine support, rack end at tie rod, plus brake pads. reasonable ba ito? or mas mura kung sa iba ako bibili ng parts labor na lang sa kanila?
    Jun 2005
    #285
    Dati nagpaquote ako sa fairview branch, inabot ng 30k ang quote. Pati power steering may sira daw so plus plus pa.
    Dinala ko sa zee (kapatjd ng owner ng cruven).
    8k lang for everything. Wala naman sira yung power steering
    Wag ka magpaparefill.ng shocks. Always go for replacement shocks. Madali masira yung repaired and refilled shocks nila.
    Buy the shocks and other parts yourself. Sobra laki matitipid mo.
    Maganda injection ng joints ng cruven and zee.
    Stay clear of fairview branch.
    #286
    canvass muna nga ako ng parts eh, tapos punta ako sa kakilala kong mekaniko pa check ko sa kanya lahat ng tinuro ng cruven kung palitin na nga ba kasi kung ako lang, yung rack end lang nakita kong sira na talaga maliban doon sa langitngit ng gulong sa likod na ewan ko kung shocks nga ba o makukuha sa bushing lang. thanks, sa reply sir!
    #287
    ok ba iyong cruven sa sucat?
    what do you mean by injection points bro?
    Aug 2016
    #288
    ask for your recomendations guys, san shop kaya for replacement shocks ng bmw 320i 2006? thanks
    Jun 2005
    #289
    Experience nila utol, ayos naman sa sucat. Never tried it there though. Layo eh. Makati branch ako lagi. Kilala ko na din mekaniko eh.
    Yung injection nila ng joints is parang refurb ng worn out joints. Nilalagyan nila ng bagong plastic sa loob ng joint para sumikip uli.
    Based on experience, mas matagal masira than the 555 replacement na nabibili ko dati. Tapos may 1 year warranty naman kaya okay na din.
    #290
    ^ bale lumalabas ba na mas mura kapag nag injection ng joints vs 555 replacement parts ang gamitin?
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
shock absorber replacement
