Results 241 to 250 of 296
- Nov 2009
- 3,509
April 26th, 2014 10:20 PM #241Springs and torsion bars(if equipped) carry the weight of the car, not unless the strut mounting gave in which is very unlikely because connected sya sa control arms or chassis and held by several bolts. If you can crawl underneath, its easy to spot which parts are faulty or needs retirement.
- Nov 2014
- 4
November 4th, 2014 05:09 AM #242Good day po sa lahat... Newbies pa lang po dito sa tsikot...patulong po sana sa info parà sa adjustable lowering COILOVER..Kung pwede po kabitan ang Honda civic vti vtec year 2000?kung pwede po kabitan magkano po kaya magagastos?papalitan din po ba ang shock?Maraming salamat po....
Posted via Tsikot
- Oct 2014
- 341
November 4th, 2014 09:41 PM #243Mga sir, sumasayad sa humps yung mazda 3 ko kapag 3 sakay sa likod. So palitin na po ang shocks neto tama? Do I need to replace also the coil spring?
- Jul 2013
- 2,450
November 4th, 2014 10:07 PM #244
- Oct 2014
- 341
November 4th, 2014 11:05 PM #245sir hindi naman sya bouncy. Pero pag may mga sakay sa likod malapit na sumayad sa fender yung gulong pero di naman lowered. Then kapag my humps nga sumasayad. Pag ako lang sakay or 2 kami hindi naman.
November 5th, 2014 08:07 AM #246
- Oct 2014
- 341
- Aug 2014
- 391
November 6th, 2014 10:17 PM #248
- Apr 2013
- 236
November 7th, 2014 02:13 AM #249Better visual inspection pa din ng shocks. Pag may tagas na, palitin na.
- 54,290
November 7th, 2014 03:19 AM #250some cars (like late 90s sentras) are known for bottoming out with heavy rear seat loads.. some cars (like bug-eye civics) have lower bottom clearance than other cars..
i do not know if replacing shocks at the rear, can significantly increase the ride height and minimize bottoming out...
mebbe TS get lifters, or limit rear passenger weight...
and before i consider changing my suspension because the tires rub against the body, i ask myself first... am i using the factory spec tires and rims? is it possible, the previous owner replaced the wheels with larger diameter ones?Last edited by dr. d; November 7th, 2014 at 03:23 AM.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
