Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jun 2006
    ANo dapat gawin kapag ayaw gumalaw ng needle sa odometer? Ok naman sya nung gamit ko kotse pero nung pauwi na ako ay ayaw na gumalaw ng needle...ano problem dito?
    May 2007
    Quote Originally Posted by jonski View Post
    Odometer needle......or speedometer?
    Jun 2006
    Speedometer cable / whatever links the tranny and speedo?
    Jun 2006
    Quote Originally Posted by v6dreamer View Post
    speedometer
    May 2007
    If all the other gauges work and that is the only gauge that is not working then most likely suspect a bad speed sensor or maybe a loose connection at the speed sensor.
    Your Speed Sensor should be where your right axle shaft goes into your transaxle. The tranny has 2 sensors input & output 1 or both may be bad. You may have to replace both.
    siguro bro sabihin mo muna kung ano ang year/model info ng ride mo.
    pag sensor type, pwedeng sensor or wiring or yung actual instrument cluster
    pag manual type, pwedeng cable o yung gear
    Aug 2006
    Pag honda 92 to 2000 model, facing the engine nasa left side below the throtlle body.
    Pag toyota naman, facing the engine right side below the throttle body.
    both are attach sa tranny
    HTH
    magkano aabutin sa sensor?
    Ano kayang problema kapag iyong digital odometer display Ng kotse hindi agad namamatay after I -deactivate Ang ignition? Siguro mga 20-30 seconds pa bago mawala iyong display?
    Mirage Pala iyong car.
    Jan 2009
    Dati ba hindi ganyan?
    Minsan design ng sasakyan na may delay-off. Yung Innova ko, naiiwan naka-display yung odometer pag patay ng susi. Seconds lang din.
    Hindi ko alam bro eh. Hindi Kasi sa akin iyong auto.
    Pero according to my utol Hindi Naman daw ganyan daw. But he's not 100% sure though.
    Jan 2009
    As long as namamatay after a few seconds, that's normal. It's a feature on many cars.
    Seems like it's normal. You can use that period to reset the service interval warning light.
    https://www.youtube.com/watch?v=SQCILo-Q4qs
    Nov 2019
    Buti nga yung dashboard lang. Yung sa Ford Everest 2011 (not sure if same pa rin sa latest model nila), after mo ma off yung susi, naka ON pa rin sasakyan kahit nasa labas kana ng car. Mag OFF lang yung andar after 30s ata or less than a minute ba yun.
    Built in turbo timer
    Nov 2019
    Turbo timer yung feature na yan sa Everest?
    Sana default feature yan sa mga naka turbo na sasakyan.
    Quote Originally Posted by carxynogen View Post
    I remember first time I saw a 996 Turbo at the paddock area of BRC. When the engine was hot the fans stayed on for a few minutes after turning the car off.
    Nov 2019
    Kaya nga boss, if turbo timer feature talaga yang naobserve ko sa Everest, Im hoping default feature sana to sa lahat ng naka turbo na sasakyan.
    OK lang if tayo lang ang gumagamit ng sasakyan, hintayin talaga mag cool off before turning off engine from long drive.
    If si misis yung nag drive, automatic off agad kahit from long drive.
    Jan 2009
    ...if turbo timer feature talaga yang naobserve ko sa Everest, Im hoping default feature sana to sa lahat ng naka turbo na sasakyan...
    Ford kasi... it needs a lot of TLC. ;)
    Kidding aside, I don't know if other turbo vehicles have that feature that only triggers when it's really hot. My Toyota turbodiesels likely don't have the feature (nor does it need it), it seems.
0dometer problem
