Results 251 to 260 of 296
- Aug 2012
- 2,767
November 7th, 2014 09:25 AM #251The basic function of a shock absorber is to keep the vehicles tires in contact with the road. The shock absorber regulates the movement of the spring ensuring a smooth and more importantly safe ride. Even with new tires and new brakes, unless all shock absorbers are in good working order vehicle safety is compromised because of reduced wheel contact with the road.
With springs but faulty shock absorbers, the vehicle is able to absorb bumps, but the undampened suspension means that the vehicle continues to bounce and causes the tires to leave the road.
Check out this animation video. Top car has no or faulty shock absorber. Bottom car has good shock absorber.
http://www.kyb.com.ph/images/what.swf
November 7th, 2014 10:42 AM #252
I have a 2000 Corolla GLi that still does the lower animation. Been observing this when taking humps, it would do the 1 bounce, a little overshoot then settle.
However, lately it's been bottoming when I have 5 pax inside, where before it wouldn't. Could it be that the springs has become softer and needs replacement. Odo is 205K Km already. I last changed the struts, shock mount, ball joint, dust covers and lower spring insulator at 120K Km from OEM to KYB Excel G and replacement parts.
There is also noise on the front when it actuates when driving over humps as I drive off in the morning. A few more humps later, wala na. No noise sa rear.
I don't see any leaks on the struts also, but my bump stop/dust covers are already damaged. Palit na rin ng front struts?
I'm thinking to change all the struts, springs, bump stop/dust cover and shock mounts and inspect/replace worn out ball joint, tie rod, rack ends and stab links.
How are the spring rates of the replacement springs compared to stock. Nagdadalawang isip ako baka magiba ang ride height/tayo and ride.
November 8th, 2014 01:02 PM #253
November 8th, 2014 03:09 PM #254
guys, anong magandang shock absorber brand for L300FB (front and back)?
monroe ok ba?
November 10th, 2014 05:16 PM #256
Pinalitan ko na yung front struts. Same springs lang pinagamit ko. shock boot din sinabay na.
Patay na nga yung driver side struts. hindi na bumabalik pag kinompress. Yung pass side, bumabalik pa pero mabagal na. Wala namang fluid leaks pareho.
Noticeably improved ang bounce travel nya at hindi na nag nonosedive under braking.
Dati kahit one bounce lang sya, malaki yung down and up motion. Ngayon konti na lang.
Mas stable din sa highway speed.
November 11th, 2014 12:37 AM #257
Mga pap's may naka try na ba sainyo ng titan shock absorber? TIA..
- Jun 2009
- 98
April 13th, 2015 02:27 PM #258Hi I have 2005 Innova, may leak yung left shocks ko... anu po bang mga murang options ko. i called Cruven 2500 daw and repair nila per shock... i am planning to sell the car pero i want to have it fixed muna before i sell. thanks!
April 13th, 2015 02:55 PM #259
Yung mga gas charged shocks lang ang nag-eextend by itself pag cinompress. Koni shocks for example, don't. Akala ko nung una sira pero ganun pala talaga pag emulsion type non gas charged shock. Most OEM shocks are low pressure gas charged.
*frost2
Mahal yun, maybe if your shocks are expensive ones like Bilstein, Koni it might be worth it. If you're selling it anyway you could check out KYB, they might be around the same price.
*frost2
- May 2015
- 4
May 13th, 2015 05:07 PM #260Mga idol ask lng san po preferred nyo mag pa refill/repair ng shocks and how much usually, for toyota celica '04 po w/ super struts... Thanks po
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
