Page 27 of 30 FirstFirst ... 172324252627282930 LastLast
Results 261 to 270 of 296
    Dec 2011
    #261
    Quote Originally Posted by Redwiz View Post
    Mga idol ask lng san po preferred nyo mag pa refill/repair ng shocks and how much usually, for toyota celica '04 po w/ super struts... Thanks po
    Cruven, P 850 per.
    Cruven, P 850 per.
    Aug 2012
    #262
    Paano po ba malalaman kung talagang kailangan ng palitan yung shocks?
    Hindi kasi ako sure kung palitin na talaga yung shocks ko. Hindi na kasi sya nag cocompress kapag uneven yung roads tapos parang umaangat yung gulong sa kalsada na parang bato sa tigas yung pakiramdam. Naka maxspeed lowering springs kasi ako dati kaya feeling ko yun yung reason kung bakit nagkaganito yung shocks ko ngayon. Dapat pala ata magpapalit ka din ng shocks kapag nag lowering springs ka.
    Jun 2015
    #263
    Good evening sirs,
    It's my first time here and I need advise po how much Toyota genuine parts and where I can buy below items.. My car need the following:
    Need to replace right away:
    2pcs Front shocks
    2pcs Rear shocks
    2pcs Stab clamp bushing
    2 front and 2 rear brakes
    2pcs Tie rod
    2pcs Rack end
    2 Front Wheel bearing
    2 Rear bearing
    My Car is 2004 RAV4. 1.8 M/T. And how much would it cost me for the labor to have all these replaced. And ano po replacement parts? Sorry I don't have any idea about these things. My friend used to help me but he moved to US na so I feel so lost. Appreciate all your good recommendations. Thank you.
    Apr 2015
    #264
    Let me guess, this was either suggested by casa or by a reputable wheel alignment shop. What was your complaint that led them to suggest that those parts need replacement? My suggestion is to have someone knowledgeable accompany you when having your car fixed. You can always make new friends
    Jun 2015
    #265
    Hi Sir Beeftapa!
    It's from the mechanic. A friend of a friend. I guess it's needed since my car is 10 years old already.
    Actually sir my car is in their shop now. Had bigger problem. Timing belt broke and had my engine repaired. I was clueless since I had it checked before and the guy said it was chain or something and it doesn't need replacement. It was stupid of me to believe him. Until it gave in. Now it cost me so much. I'm at 60k bill now for the engine overhauling and some part replacements. No idea yet what are those. Hasn't received itemized list. The parts I'm inquiring here are additional pa po na for replacement daw. So I decided to ask around how much ba talaga kc Ito po quote sakin for the shocks alone:
    If original parts
    Front shocks 9950 per pc
    Rear shocks 4300 per pc.
    If replacement jap parts
    Front shocks 4950 per pc
    Rear shocks 3800 per pc
    Labor: replace 4 shocks: 2000
    The other parts no quote yet that's why I'm asking po pra may idea Lang. I'm guessing with everything It will cost me 100k for original parts. And that's big money. But safety is important so if cost is really this much then no choice but to spend that much. Just inquiring to know if okay din replacement parts pra makatipid ng konti. Salamat po!
    #266
    If you have the budget and safety/peace of mind is prime concern then nothing beats going original. My advise is, replace only what is needed. Those bearings and suspension parts dont expire simultaneously. Unlike the engine, they do have symptoms before total failure.
    Apr 2015
    #267
    Hmm... why not just replace the timing belt when it is the one broken? If work hasn't been done yet, I suggest to have a second opinion in other mechanics and bring someone with at least some knowledge. To answer your question, Yes jap replacement parts are fine, as long as they are not surplus. Always ask for the parts receipt, and normally they come with a few months warranty.
    To be honest, there is a chance that your mechanic is not trustworthy. And if safety is your concern, you can sell your car instead of having it repaired for that much and just use it as a dp for a new one.
    Jun 2015
    #268
    [QUOTE=beeftapa;2560510]Hmm... why not just replace the timing belt when it is the one broken? If work hasn't been done yet, I suggest to have a second opinion in other mechanics and bring someone with at least some knowledge.
    Honestly, I don't know anyone close who knows car well. I've limited male friends. I've only one female sibling. Parents are from the province. No relatives here. But thank you for the suggestion, I'll ask friends to can recommend someone who knows car to help me check next weekend.
    With the broken timing belt he said the engine got damaged because I forced driving it still. It took about a month before I was able to have it checked because I went out of the country. Some oil leaked and damaged the spark plugs, etc. Initially he said we might need a new engine. But after evaluation he told me it can be fixed. When I've asked him where we at now at the cost he told me is its at 60k already. Been waiting for the detailed list but none sent yet. The awkward thing is he the bf of my friend so it's quite hard to demand if you know what i mean.
    I really have no idea about parts and repairs. All I know is to drive and gas up. Bring it for change oil, alignment, car wash, had the break pad changed.. Those minor sort. Due for 100k mileage maintenance and boom! Timing belt broke and engine destroyed.
    #269
    You don't have to know lots about maintenance but atleast read the manual and follow the PMS schedule then your car should last longer. neglecting the engine often comes with a hefty price and with a dead engine your car is useless.
    Timing belt replacement is stipulated on the manuel.if T-belt snaps then there would be major damages(if its an interfering engine) like valves colliding the piston. There are also MAW might as well replace parts along with the T-belt replacement that includes pulleys, tensioner bearings, oil seals, and water pump. Take a 2nd opinion from reputable shops.
    Jun 2015
    #270
    Well some lessons are learned the hard (and expensive) way.. No point regretting now. Yep it got to 60k because of that. So I'm trying to save on other parts that needs replacement. I'd Iike to have it in good running condition that's why lots of parts will be replaced. Just need advise where to source out the parts and if the mechanic is charging me fairly. Thank you for the advise sir.
shock absorber replacement
