Results 201 to 210 of 309
March 20th, 2009 05:55 PM #201
March 20th, 2009 05:59 PM #202
kung magpapaputol ka ng springs huwag masyadong sobra kahit isang round lang pwede na kung baga semi para may play pa din ang springs at saka hindi masyado matagtag
March 20th, 2009 06:01 PM #203
March 20th, 2009 06:08 PM #204
March 20th, 2009 06:13 PM #205
Actually lowering a car's suspension should be fine IF done properly. Unfortunately there are simply too many people who are willing to take the short cut for that "lowered look".
A properly lowered car should handle as well or even better than an unlowered car due to stiffer suspension and lowered CG.
Do it wrong by either cutting or heating the springs and you can find your car either hitting the bump stops or going "boing-boing-boing" over the smallest imperfection on the road. Not to mention, potential early failure of the shocks and suspension bushings.
March 20th, 2009 06:17 PM #206
sir kung sa van ba safe ba mag pa cut ng spring kahit 1 round lang?
btw share ko lang yung pregio and L3 fb ko na naka cut ng spring 1 round lang for 6 mo wala pa naman nasisira kahit laging puno ang sakay?
sa L3 medyo nakakaramdam ako ng konting tagtag hmm pero sa pregio parang walang nangyari halos half inch lang naman ang ibinaba?
ano po masasabi nyo baduy po ba ?
March 20th, 2009 06:18 PM #207
btw sa totoo lang expiriment din yan may naka handa na din ako spring 8 rounds or sapin na makapal sa spring kung gusto ko man ibalik sa stock height
March 20th, 2009 06:19 PM #208
question din kung may torsion bar naman at ilolowered like ng lite ace revo mb100 ect nakaka sama ba ito?
March 21st, 2009 01:18 AM #209
kakapalit ko lang ng apat na stock springs kanina ng lancer pizza ko. pinutulan ng 1 1/2 ikot yung harap kasi sobrang taass parang nakatingala na. mga 5 fingers fender gap pa din naman. makakasama po ba yun?
March 21st, 2009 09:06 AM #210
This was a common practice in the mid to late nineties, for those with a limited a budget. You can tell which vehicle on the road had their spring "cut" by the way the vehicle's body is wobbling or bouncing around violently.
Turbo timer yung feature na yan sa Everest? Sana default feature yan sa mga naka turbo na sasakyan.
0dometer problem
