Page 21 of 76 FirstFirst ... 111718192021222324253171 ... LastLast
Results 401 to 420 of 1510
    #401
    Quote Originally Posted by fermontalban View Post
    Is there a big difference between 195/60/15 and 195/65/15? A difference that you can really feel in actual road conditions? Can you tell the difference between the two when you are riding the car?
    mas maliit sidewall ng 60 series kaysa sa 65. not much din naman siguro yung comfort issue since minus 5% lang po difference. why not have 205/55/15 kesa sa 195/60/15? check din kung may rubbing issue.
    Feb 2009
    #402
    Just a price set I got (*based on a 195/60/r14 tires)
    Bridgestone Turanza AR10 - 2,650
    Bridgestone Turanza GR80 - 2,850
    Goodyear Ducaro GA - 2,650
    Goodyear F1 - 2,750
    Goodyear Assurance - 2,845
    Goodyear NCT5 - 2,975
    #403
    65 series, tends to sway more and a bit bouncy and thicker sidewall.
    May 2007
    #404
    Quote Originally Posted by pcuerpo View Post
    i really have no idea with tire brands. anybody can help me which tire would provide me good threadwear and comfort and di maingay. i'm looking for 205/50/16 tires. choices so far are Toyo DRB, Bridgestone Adrenalin, Goodyear Eagle F1 (haven't asked kung meron specs that i'm looking for), and Yokohoma S-Drive. anything else you can recommend that would suit what i'm looking for?
    the goodyear f1 might suit your needs, it provides comfort, grip and a high treadwear (280). the yoko s-drive has a higher treadwear of 300 but the f1's provide more comfort and grip. these are the tires i've tried so far. can't comment on the other choices.
    Dec 2007
    #405
    Quote Originally Posted by s_quilicot View Post
    Sang dealer ka nakakuha bro?
    Armstrong Enterprises/Tyre Rack along Ortigas Ave. (Greenhills side), practically at the corner of EDSA. They're the official distributor.
    You have to call them beforehand to check for stocks. If they don't, they have to transport the tires from their Bicutan warehouse, but they get there a day after. 7234904
    BTW I was a longtime Bridgestone user. Nothing wrong with their tires, it's just that the RE001 Adrenalin doesn't come in my size. I would have gotten that had they offered it in 205/45R16.
    Dec 2007
    #406
    Quote Originally Posted by delltek04 View Post
    Goodyear F1 - 2,750
    The GR-80 I highly recommend. I had those for 4-5 years. Good grip, comfy and pretty hushed. No treadwear rating, but they were surprisingly hard-wearing given the (ab)use I gave them. I sold off my old SX8 City and they were still in good condition.
    Just make sure the rubber is still new, as it's been sold since 2003. If it's old stock, walk away and look for a fresher batch.
    #407
    bridgestones are good. falkens also. mura pa
    Aug 2004
    #408
    any reviews sa Firenza tires?
    i'm planning to get their 215/45r17.
    #409
    any rewiews sa falken? magkano 215/45r17?
    #410
    firenza are copies of yokohamas na made in china. owned by singaporeans. 3500 ata per pc sa dkc yun 225/50 r17. pero longterm durability di ko alam. falkens are made in japan by ohtsu tires. they also make dunlops. ive had a set of ziex 512 falkens for about 4 years na. ok sya tahimik and matagal makalbo and makapit din treadwear 360 traction and temp A. newer ones are ziex 912, 329. 3600 per tire ang 329 sa miller in west ave pero rim 16
    #411
    Quote Originally Posted by jaymd View Post
    price was 4 years ago or till now?
    #412
    Quote Originally Posted by Type 100 View Post
    Thanks bro.
    #413
    Quote Originally Posted by aejhayl17 View Post
    those are current prices the falkens cost 2300 4 years ago
    #414
    anybody tried Toyo DRB already? these seem new, even in other forums, wala pako nababasa about this.
    Sep 2009
    #415
    For my current ride I've had 4 different tires already.
    First was Falken Ziex 205/55/16 followed by Yokohama ES 100 tires 205/50/16,then Michelin Pilot Preceda at 205/50/16 and my current tires Goodyear F1 205/55/16.
    Best for me are the Goodyear F1's,great traction on either wet or dry surfaces ang tagal pa maupod. Michelin is the worst for me,had an air pocket on the sidewall with barely 5 months of use (regular daily driving) but the distributor insisted that warranty does not cover such occurrences (even shipped the tires to Tiara-Distributor, for physical inspection of the damaged tire).
    HTH
    Nov 2007
    #416
    good day sirs!
    Tanong ko lang po kung ok lang mag mix ng mga tires kasi nahihirapan ako maghanap ng Kumho 185/70R13.
    Dec 2007
    #417
    Quote Originally Posted by Kirsten's Dad View Post
    HTH
    Nung may Galant pa kami, gusto namin mag-Michelin kaso sabi daw sa kuya ko, hindi angkop sa Pilipinas ang mga Michelin. Baka ganun talaga kaya agad nasira ang Michelin mo, sir.
    #418
    Just want to ask most of the tires now a days are steel belted radial . I have a dunlop tire on my pick-up .What the problem is sometimes they have bubbles on the side and on the four tires i bought the thread were still good but it blown out .And you can see the steel in it . I talked to one of the supervisor of dunlopl tire why they are not making a nylon instead of steel belted radial .He say nylon tires are heavy duty meaning to say it takes time for most of car owner to replace the tire.
    What do you think of this.
    Feb 2005
    #419
    i did and i am satisfied with it. I got it for 2,900 each last february at DKC. size is 195/55/15. all tires in the car are DRB Toyo
    #420
    I got a TOYO i 600 F-8 on my pick -up . Its already 10 years and still okay.
The Best Brand of Tires
