Page 25 of 76 FirstFirst ... 152122232425262728293575 ... LastLast
Results 481 to 500 of 1510
    Apr 2008
    #481
    Thanks for the info. San kaya may mas murang RE001 Adrenalin malapit sa pasig?
    Jan 2009
    #482
    Try Neuton NT5000. I got mine 2 months ago at OK naman. I can compare it with Achilles na made in Indonesia ren. Taas ng treadwear at maganda ang traction.
    Dec 2009
    #483
    help nman po..ok po b ikabit 17 mags at ano size ng goma pede sa lxi dmension body..stndrd po taas ng kotse..thnks po
    #484
    mga sirs, which is better for the size of 185/55/15, bridgestone re030 or yokohama c.drive? need to change my tyres... hindi aligned naunang mapudpod yung labas sa front wheels... badtrip will have it aligned na rin after buying the new tyres.
    Dec 2007
    #485
    Quote Originally Posted by Bubbachuck View Post
    If you don't mind a bit of traveling, you can get RE001s at Bridgestone's huge shop at The Fort. They should have them in your size. HTHs
    Not sure how much they're selling for over there though.
    Dec 2007
    #486
    i did and i am satisfied with it. I got it for 2,900 each last february at DKC. size is 195/55/15. all tires in the car are DRB Toyo
    Interesting, thanks for this. I'm having problems looking for a complete set of Toyo's Proxes T1Rs in that size.
    Maybe the DRBs are their quasi-replacement as the T1Rs are sort of long in the tooth by now.
    #487
    If you want you can inquire Toyo Proxes T1Rs at Blumentrit T. Mapua.
    #488
    Mga sir patulong nman po. Sentra Super Saloon '92 po ride nmin.
    185/70/14 po ung naka-kabit ngaun, pero papalitan na kc manipis na.
    Patulong nman po kung anong model dpat kunin, ie. Turanza **.
    Bridgestone po sana hanap ko na pasok sa 3k per tire. Habol ko po is quality, durability at medyo matagal pa bago palitan ulit :D
    Thanks in advance!
    Dec 2008
    #489
    Pls help. Is it ok if i will use 13" 175 tire instead of 205? wala po kc available na 205. Pls advise. Thanks a lot in advance.
    Dec 2009
    #490
    michelin agilis or good year DS sport? for vans..
    Jan 2009
    #491
    makisingit na rin po ako. tanong ko po kung magkano normally ang yokohama 185/65r14? need to buy two for my nissan exalta. sumabog yung isa kong gulong at lumabas yung wire. salamat po.
    Oct 2009
    #492
    Planning to buy Michelin 235/70 r15 for crosswind...
    Ano ang pinaka latest na year manufactured ang gulong na ito? mostly nakita ko 2007... may update ba kayo? thanxs a lot!
    #493
    Quote Originally Posted by karlos View Post
    Around 2,800 +/- last quote sa kin for my old civic.
    *gameloader
    Goodyear's quality has steadily declined over the years IMO. The last good ones I've used were NCT3's. Michelin is a premium brand, thus the premium price. Goodyears are overpriced.
    Jan 2010
    #494
    sir newbie is here...
    tanong ko lang sir bakit yung sa advie ko na pirelli chrono ay 195R14C lng tapos yung sa iba my "/" sign sya? tulad ng 185/65R14C...
    ano b pagkaiba nito sir?
    Dec 2007
    #495
    Quote Originally Posted by nvidi.turion View Post
    Both are truck tires or light-duty commercial tires - denoted by the C at the end. Usually vans have this equipped. I remember our old Kia Pregio had 195R14C tires too.
    The second tire spec (185/65R14C) is more conventional because car tires use almost the same system.
    "185" is the tread width in millimeters. The "65" is the aspect ratio - the height of the sidewall as a percentage of the tread width. In this case, the sidewall height is 65% of 185mm - do the math.
    I have no idea why some tires have the aspect ratio removed from their specs.
    Jan 2010
    #496
    Quote Originally Posted by Type 100 View Post
    ah, ok sir tnx...
    sa akin kasi sir 195R14C lang...
    Jun 2006
    #497
    Quote Originally Posted by marquez View Post
    Dont get those tires. Tires have a usefull life of around 4 to 5 years. Best to buy the newest tires you can.
    May 2009
    #498
    anyone knows kung magkano sa blumentritt, banawe or evang ang yoko A drive 205/65/r15 pudpod na kasi yun s306 ko sa rear so 2 pcs ang need ko dito kasi sa batangas area ang range is the cheapest is 3.4K/pc at highest is 3.6k...painform naman po kung may recent lang bumili para pagluwas ko sa manila pwede ko sadyain kung significant yung difference..thanks
    #499
    ah, ok sir tnx...
    Usually tires like that have an aspect ratio of 80-85%. Ok ba yung Chrono ng Pirelli? How's the grip & mileage?
    Jan 2010
    #500
    ok nman sir... medyo matigas lang ang gulong kahit pisilin mo, compared sa ibang gulong... sa grip sir ok nman sya
The Best Brand of Tires
