Results 3,131 to 3,140 of 3407
- Jun 2018
- 10
October 2nd, 2018 01:11 PM #3131I need your opinions. Sobrang mainit ba talaga yung engine bay area after driving? I usually drive for an hour at a time pero I noticed after parking na the heat radiates from the engine. Feel ko lang masyadong mainit. Minsan, pag umuulan nagmimist pa small part ng windshield near the engine bay. Any thoughts on this? Engine coolant level is normal and radiators were replaced last year. (2010 Subaru forester NA)
October 2nd, 2018 01:35 PM #3132
when idling and ac off... is the radiator fan going on for a half a minute then off again(until it reaches a temp) then on again. it cycles...
your symptom is of a not properly bled coolant... air pockets perhaps..
- Mar 2018
- 62
October 3rd, 2018 10:30 AM #3133*Injustice21
This sounds right -- when last time na flush/napalitan coolant? Nag-eexpire din kasi ito, and kapag ganyan imbis na liquid most of the time nag-papalit na yan from vapor to liquid -- then eventualy parang tubig nalang sya hindi na effective yuh eth. or prop. glycol, unti unti na yan mauubos/sisingaw.
Compare mo din difference ng coolant level ng reserve kapag malamig sa umaga and nasa operating temp. Dpat tumataas-baba, kapag operating-temp dpat mas mataas kesa yun level nya pag umaga at completely cool -- dpat higop-buga ginagawa ng radiator sa reserve to maintain pressure habang nagiiba temp and dito rin dpat na-eeliminate air pockets.
- Jun 2018
- 10
October 7th, 2018 10:17 AM #3134Thanks Sirs Don900 and StockEngine. Will check these when I get home. I'll also have it checked at Fusion R since my brakes and spark plugs are due for replacement na rin.
October 7th, 2018 05:16 PM #3135
Looking to buy 2013 Forester XT turbo.
High maintenance po ba?
What is the recommended gas type, can I use Regular unleaded?
October 7th, 2018 05:34 PM #3136
If your used to cars with 2.0L engines or bigger, maintenance cost would be about the same. CVTF and gear oil change every 40k km actual mileage.
Fuel requirement is 95RON to 98RON due to its turbo engine. Blaze 100RON can be used but not recommended as fuel-air mixture might come out too rich.
- Jan 2018
- 844
October 7th, 2018 08:42 PM #3137
October 7th, 2018 10:07 PM #3138
December 4th, 2018 01:59 PM #3139
Was able to claim warranty on the steering wheel chipping/peeling.
- Jul 2015
- 9,583
Any review sa Koby Tire sealant? Effective ba sa gulong kotse or pang motor lang? Thanks
Liquid tire sealant
