Page 159 of 171 FirstFirst ... 59109149155156157158159160161162163169 ... LastLast
Results 3,161 to 3,180 of 3407
    May 2018
    #3161
    Oil change lang kelangan mo. In Motor Image, you have the option to use the Motul oil (600 per liter) or the Shell oil (400 per liter). You can also bring your own oil (just follow the specs on the manual) but Motor Image charges 50 pesos per liter corkage fee.
    Kung yun lang 1250 singil sa iyo, then oks na oks yan. Libre then yung oil at oil filter mo.
    Got it! Appreciate your help again Boss Egan! [emoji106][emoji106]
    Dec 2014
    #3162
    safe ba magpagas sa mga total phoenix and other small brand gas stations?
    #3163
    Quote Originally Posted by Richard Yap View Post
    Safe naman, sir. Long time user ako ng SeaOil Extreme97 before I moved to UniOil due to S&R discount.
    By the way, Total is one of the top 10 petroleum companies in the world, even bigger than Chevron. Medyo di nga lang malawak network nila dito sa 'Pinas.
    Dec 2014
    #3164
    thanks bro
    Nov 2017
    #3165
    Interesting fact from the video: the Forester is very popular among American lesbians [emoji2380]
    SUBARU FORESTER - Everything You Need to Know | Up to Speed - YouTube
    Apr 2015
    #3166
    Hey guys, im planning to buy a second hand 2010 ft. Is it worth buying considering the age of the car? Im going to use it as a sub for my daily (hyundai accent crdi). I know its a huge difference considering their FC. Please enlighten me. You can also share your FC if you still own a 2010 model. Oh btw, the car is selling for 385k
    Thank you!
    #3167
    Quote Originally Posted by mamayheals View Post
    Thank you!
    2010 Fozzie for 385k? Mura yun. Yung 2.0L NA or the 2.5L turbo? Is it in running condition? No issues whatsoever?
    If it is in good running condition, it will drive better than your Accent CRDi.
    Jan 2018
    #3168
    Thank you!
    It is worth considering definitely. But as usual, you need to check the condition of the car and what you need to have fixed/replaced.
    May 2018
    #3169
    Sirs, need your help po.
    Nirefill ko kasi ng tap water yung coolant kasi pawala na. Hindi ko alam bakit hindi nirefill last pms ko 2 mos ago.
    Should I drain it po or wait until my next pms? 7mos pa lang po si Fozzie.
    Salamat po..
    #3170
    Quote Originally Posted by tsik_r2d2 View Post
    Salamat po..
    You'll be fine. Just don't use tap next time. Best to keep a bottle of OE coolant or distilled water ( Wilkins or Absolute, not the vodka[emoji4]) for top up.
    I would never let the dealership top coolant or windshield fluid up....DIY it. I've seen dealerships add tap countless times.[emoji20]
    May 2018
    #3171
    Haha.. noted on the Absolut Vodka Sir Travajante..[emoji1]
    Thanks po sa reply sir.. worried lang talaga ako lalo na't first time to own.. I read na it will cause rust and corrosion.
    I am thinking pa naman of going to MI on monday for a coolant flush. [emoji28]
    #3172
    Anytime, sir! I'm a bit OC, too. Tap has minerals that could cake w/ heat & time.
    I'm guessing you dint top up much. Don't you lose sleep over it.[emoji4]
    May 2018
    #3173
    To be honest sir mga 1L nalagay ko. [emoji28]
    Planning of buying a concentrated coolant para at least maneutralize ko. May advise po ba kayo na brand? Non turbo po ako.
    Appreciate your help Sir Trav!
    #3174
    Grab what Subaru puts for the next top up. Note that different coolant brands come in different colors.
    Mar 2004
    #3175
    Be careful, use ONLY Subaru Long Life Coolant ... There are alternatives but you have to be well informed about different types of coolants and their composition ... Incompatible coolant type MIGHT damage some metals in the engine ...
    Dec 2014
    #3176
    is there any way na mapapalit ang suspension ng forester with a suspension ng mga fortuner, montero type?
    #3177
    The Forester is built on a unibody frame like a car unlike those PPVs which are built on a ladder frame like a pickup. The suspension setup is different between them.
    You can stiffen or raise the suspension of a Forester with the proper use of springs and shocks or coilovers. Besides, why would you make the Forester ride like a PPV? One of the great advantages of CUVs is how it drives compared to pickup-platform vehicles and how its suspension is tuned makes that difference.
    Dec 2014
    #3178
    mas type ko kasi yung ppv na suspension yung tipong rough road di mo mafefeel
    #3179
    The Forester has good ground clearance, as good as most PPVs. If you want to make the Forester be much better off-road, then you can upgrade the shocks and springs, lift the body a bit, and change to off-road tires.
    It will still handle better on twists and turns compared to those ladder frame vehicles.
    Dec 2014
    #3180
    if ever anong marerecommend mo na shop to do this? and how much would it cost?
Subaru Forester
