Results 901 to 910 of 2721
July 17th, 2013 07:21 PM #901
If cabin temp goes above aircon temp setting engine will restart. From the long list of conditions (IIRC that list was posted here somewhere) if the aircon temp is not the lowest or highest i-stop won't activate anyway.
Some owners in AU posted that some units may have been released with a normal battery instead of the required Q85 so their i-stop didn't work. A battery replacement was recommended.
July 17th, 2013 07:37 PM #902
Reasons why a specific battery for i-stop system is necessary
When a vehicle equipped with i-stop system stops at a red light, engine is stopped for fuel economy improvement. When the vehicle starts to drive again, the engine restarts. So, battery discharging and charging are repeated in a short period of time.
Also, during i-stop operation, as electric power for air conditioning and audio systems etc. is supplied from the battery only, discharging occurs more than on vehicles without i-stop system.
If a battery other than the specifically designed for i-stop is used instead, its lifecycle may be reduced or it may disable i-stop function.
http://www.rx8club.com/attachments/g...top-system-pdf
July 17th, 2013 07:37 PM #903
July 17th, 2013 07:45 PM #904
2) Reasons why a specific battery for i-stop system is necessary
If a battery other than the specifically designed for i-stop is used instead, its lifecycle may be reduced or it may disable i-stop function.Last edited by Densker; July 17th, 2013 at 07:53 PM.
- Mar 2009
- 823
July 17th, 2013 09:19 PM #905
July 17th, 2013 09:42 PM #906
I've tried the i-Stop on the Mz6. It's actually rather foolproof and not intrusive. It was smart enough to know when I was in stop and go traffic and when I was really stopped because of a red light, and it only turned the engine off during the latter. Aircon also remained on despite the engine being off, though it was much weaker (similar to when you turn your aircon on with a conventional car placed in ACC mode).
- Jun 2010
- 452
July 17th, 2013 10:12 PM #907Sabi sa akin ng Service Advisor, Motolite daw is developing a localized version already. Hopefully by the time your batteries expire or run out, nakalabas na yung Motolite for i-stop.
July 17th, 2013 10:31 PM #908
nasabi din sa akin ito pero walang definite date. kaka-order lang daw ng motolite ng Mazda 6 para pag aralan ang battery
ganun daw ginawa ng BMW dito, motolite ang supplier ng battery nila sa mga sasakyan na may istop (meron palang ganun sa BMW PH ngayon)
Pero chisimis lang sa akin ito ha? hahaha
- Jun 2010
- 452
July 17th, 2013 10:35 PM #909Haha meron na rin naman tech nga na ganyan yung mga euro brands dito. I mean even peugeot has it in some of their models, but the question still is, saan ang battery? Haha.
Does that mean na exclusively supplied lang kay bmw yung mga hinawa ng motolite for istop tech? Bawal ilabas pa sa market? Kung meron na si bmw then di na pala kelangan magdevelop ni motolite kasi andyan na.
July 18th, 2013 09:24 AM #910
Alam ko Peugeot has it din. AFAIK Mazda lang ang first "mainstream" brand na naglabas neto kaya ngayon lang napansin. The Euro brand owners kasi iwan lang sa casa usually tapos blank check lang
Senators suggest window hours in odd-even system on Edsa rehab Senators urge window hours in...
SC (temporarily) stops NCAP
