Results 3,971 to 3,980 of 5235
BANNED BANNED BANNED
- 3,790
August 16th, 2008 05:39 AM #3971normal yata yung maingay na tranny na yan because of that loose spring... nagkaganyan din yun sa akin... napapalit ako ng de-oras ng clutch lining pero bumalik pa rin... tapos ini-adjust nila ang clutch play...ayun nawala na.
duda ko tuloy na 1-2-3 lang ako sa pagkakapalit ng clutch lining dati... hindi pa yata palitin, sinabi lang nila na palitin.
August 16th, 2008 09:01 AM #3972
ganun ba... better if you could buy performance parts for ur dmax bai... havent experienced it yet sa ride ko naman and its 4 years old na but the mileage is still 29,000kms... hehehe... wla kc gamit... magplano kayo ni memphis to come here soon bringing your ride here... mag stndby2x ta dre for a weekend/... heheheh....
ur back home na bai??
- Jul 2008
- 28
August 16th, 2008 02:08 PM #3973hello D-maxers, Mga Sirs, i am from Cebu and hopefully magkarun na rin ako ng Dmax katulad nyo. Sabi ng Isuzu-Mandaue, darating daw yung unit ko two-weeks from now. Thank you so much sa Thread na to, ang laki ng tulong sa pag decide kung ano bibilhin.
August 16th, 2008 03:16 PM #3974
*wildthing, ganun ba, makapal pa talaga yung lining ko, thanks for info at di ko lang muna papalitan ito.
*jarhead bai onboard pa ako ngayon, di bale pasyalan ka rin namin ni memphis dyan, di ka na ba babalik sa states? performance lining di ko alam ang type eh.
*romel.krypton welcome sa forum bai, congrats sa darating mong dmax, i'm also from cebu, mandaue, kita ta puhon..
- 3,790
August 17th, 2008 10:18 AM #3975^^yun lining kong original was "nearly" original thickness pa nung nakalas... itinabi ko na lang para kung papudpud ko yung nakakabit, ibabalik ko na lang ulit.
- Aug 2008
- 6
August 17th, 2008 07:50 PM #3976guys guys, thanks so much for helping me decide, ive been reading so many threads about isuzu Dmax. now i bought a white one 4X2
LS series 4jj1 engine. it rides perfectly goin to batangas an back. thanks again so much for all your threads.
August 18th, 2008 04:39 AM #3977
Hydrogen generators do not work so save your money. It has been discussed on the forum many times.
The Dmax truck depending on what nozzle size you want to run with the water/alcohol injection and on how much percentage of mix you want to run you can gain 25hp to 50hp through your rpm range.
We back our claims with dyno proof. The Isuzu engines pick up a significant amount of power because they are pretty inefficient especially the under sized turbo.
If you can't increase hp without adding fuel then you cannot get better economy period. More power at a lower rpm is where you get better fuel economy. Water injection with just strait tap water will give you a easy 20hp on that engine with no changes. That's something the scam HHO generators cannot do. If those devices worked would it not be easier just to get a tank of hydrogen and mount it in the trunk and route it to the intake with a regulator???? That's pure hydrogen and it still will not give you the huge claims of power and economy.
Dmax install. A simple crosswind dropped 6 seconds off it's 0-100kph times so you be the judge on the gains.
August 18th, 2008 06:14 AM #3978
here comes dvldoc,,
and hey the above dmax set-up looks very familiar to me,,hehehe
thanks dvldoc
- 3,790
August 18th, 2008 09:00 AM #3979thanks devildoc... but I am more interested on the improvement in getting more kilometers per liter of fuel and not really much on HP gains.
in my experience, i am fairly satisfied already with the stock dmax HP. i am not racing my dmax but if i need the speed, the stock power is more than enough for me already.
do you have evaluation done on devils own on how much kilometers does it run per liter of fuel + liter of water/alcohol mix perhaps?
tia
Tsikot Member Rank 2
- Apr 2008
- 1,557
August 19th, 2008 05:02 AM #3980*romel.krypton and rasta: Congratulations sirs, on your new trucks. You both have made the right decisions in purchasing that truck. My truck has been with me for more than 2 weeks and it has already traveled more than 2300 kms, so far my only issue is it's too bouncy. But I guess I am already immune with it.hehe There are few squeaking sounds but they come and go and it really doesn't bother me that much. With its fuel consumption, I could travel almost 900 kms with 1 full tank with an average speed of 80 to 100 and sometimes 120.
Recently revealed at MIAS, this is the Changan Nevo Q05. Slightly smaller than a BYD Sealion 6...
Changan Nevo Q05 - PHEV Crossover for 1.2M
