Page 41 of 86 FirstFirst ... 3137383940414243444551 ... LastLast
Results 801 to 820 of 1708
    If the hole for the window type is existing then by all means install a window type A/C if not I'd rather have split type. Plus also consider the over all aesthetic.
    Window type really sticking out like a sore thumb on a house's facade.
    #802
    Most designers will spare the frontage. Here's an oddity....I know of very respected & sought-after ones who usually recommend split over window for clients, but do the reverse in their own homes & not coz of budget.....Go figure.[emoji4]
    It doesn't matter if it's located at the Front, on the sides or in the back window type is not pleasing to the eyes.
    #804
    Some go form over function. Some, function over form....& there are those who go for balance.[emoji4]
    The horror stories we are hearing about split type ac can easily be prevented my proper installation.
    #806
    Plus proper specs & planning. Strategic accessible pipe chases, when spaces allow, can help both prevention & maintenance. We can only share available options, sound advices, expertise & experience. Owners will always have the last say.[emoji4]
    Aug 2017
    #807
    Interested in getting window-type inverters for our rooms. Is it economical to do so if room is just 17.5x13.5 feet? The other room is smaller at 15 x 12 feet. (Sorry, not sure how to convert).
    Looking at the Kolin inverter. Any other suggestions based on experience? Thanks!
    Sent from my EVA-L19 using Tapatalk
    Dec 2017
    #808
    Quote Originally Posted by willownavarro View Post
    Rule of thumb I follow is that for every 13-15 square meters is 1 hp. This includes losses from frequent opening of doors.
    #809
    Are window type inverter aircons noisy? Like the non inverter window aircons?
    Dec 2017
    #810
    The noise you hear is coming from the compressor. Since an inverter type can vary its RPM, it is generally quiet. Still, the "noise" is there.
    Jan 2009
    #811
    The noise from window-type A/Cs are really not a big deal. Just a few nights with it, you'll find that the drone acts as white noise and can actually help you sleep. I experienced this the first time we switched from a window-type to a split. Took me a couple of nights to adjust to the silence.
    Humans are very adaptable. The noise from a window A/C is just superficial and will "go away" in time. That is, your brain will learn to ignore it eventually.
    Mar 2004
    #812
    There are ways to design a building well that incorporates window type aircons ...
    #813
    Do consider brands, usage, savings, comparative purchase costs between conventional units & inverters prior to deciding. Inverters are proven to cut around 40% of energy consumption, yes, but It might go against reason if the usage is seldom or short. Savings can be much or lil & recovery, short or loooong...depending on usage.
    Inverters are like modern cars.....laden w/ more complex circuitry & have more parts that may be prone to dying than conventional.... Always check the model's reviews & reliability feedback. Some do prematurely die prior to cost diff recovery.
    Only thing I see is putting decorative metal cage to act as protection for intruder as well as cover the exposed part. But still doesn't as good a esthetically compare to installing split type.
    Dec 2017
    #815
    Yes, you'll get used to it. The sound it makes will be like a lullaby. I remember many years ago, I was sleeping besides a boiler literally! I can't imagine how I was able to adapt but I did.
    Just to reiterate, *travajante, inverter type will "cost less" if "used more". In other words, if you'll be using the air conditioner seldomly then you should stay away from inverter types​.
    #816
    Totally agree w these 2 gents, oj & archer.[emoji4]
    Nov 2017
    #817
    Less 10 decibel
    Jan 2016
    #818
    I made some quick computations based on lazada price of condura 1.5 hp * P20k and 1.5 hp inverter * P39k, if i use it for 8 hours daily, at P10/kwh, it will take 2 years and 4 months to recover the price difference assuming 30% savings. Will 1.5hp be enough for a 20 sqm room?
    #819
    1.5hp is, sir.
    Jan 2016
    #820
    Thanks Sir Travajante
Split Type Aircon: Which is best?
