Originally Posted by
travajante
Hehe....there will always be pros & cons. There are less noisy window units, though.
If splits are desired, here are some tips:
-Find the shortest route from room unit to the condensing for max efficiency. The condensing unit must be on a well-ventilated area & accessible to service. Though all-weather, delay rust by sticking on a sheet of extra rain protection, like polycarb or acrylic.
-Insist on larger PPR drains beyond an inch in diameter with the least bends & distance to larger plumbing. P-traps are best installed on joint drains to prevent odor contamination. Common leaks are from clogging. Water & dirt will gel.
-Install room units on perimeter walls to avoid routing lines thru ceiling. If ceiling routing is unavoidable, lay the properly insulated tubes & pipes on a sloped gutter tray all the way to the exterior outlet. This will handle condensation drips. Leaks & electricals can be a nightmare to sort.
-Avoid cassettes when you can. Drain is by pump, not gravity. And, ceilings will tend to have blow marks & finger prints from service.
-For easiest trouble shoots & swaps, opt for exposed lines over embedment. Just cover the unsightly w/ removable plastic or aluminum C-sections.
True, proper installs, attention to detail, following standards & using reliable brands can give trouble-free split enjoyment for a long time. Taking measures to address known contraindications are just ounces of prevention that will outweigh the pounds of cure.
