Page 51 of 86 FirstFirst ... 4147484950515253545561 ... LastLast
Results 1,001 to 1,020 of 1708
    Is there a gadget for measuring a specific appliance's electric consumption? I hope it's cheap if there is, I like to buy one.
    seach: kill a watt
    Jan 2016
    #1002
    thanks, watt meter pala tawag dun, dami sa lazada for 1k
    #1003
    most appliances indicate the gadget's wattage consumption (220V 3.0A, or something like that) in the manual or on a paper, plastic or metal sticker on the appliance itself.
    Jan 2009
    #1004
    Particularly for wattage and amperage, those are usually the stated maximum that the appliance will ever require. They're meant to help contractors and electricians design the proper circuit for it (correct-rated wires, switches, plugs, and breakers).
    A watt-meter or power meter is still necessary if you need to gather realtime power consumption. As stated above, there's tons of them on Lazada.
    DO NOT use it to measure the output of a non-sine wave UPS. My old one popped, sizzled, and died after just a couple of minutes while measuring the output from a cheap UPS.
    #1005
    how does one know, which is safe to use, and which is not?
    Aug 2018
    #1006
    Condura split type 1.5 hp. Biglang tumulo.. ano kaya solution?
    Quote Originally Posted by Phayazho View Post
    cleaning the evaporator and filter..
    Aug 2018
    #1008
    Sir, thank you for the info. Pero kakalinis lang po nito, pero hndi ako sure kung pati yung evaporator niya. Filter ok naman malinis po.
    Kung kakalinis lang baka hinde napasok mabuti yun Drain pan doon sa Drain hose.
    Aug 2018
    #1010
    Ipapackeck ko din. Baka naiisip ko na baka lang masiran yung aircon. Salamat po.
    Sent from my D6503 using Tapatalk
    with our tropical weather, humidity is high, baka nga yun drain clogged.
    #1012
    Bantayan mo pag binalikan, pag kinalikot yan umpisa na problema.
    Aug 2018
    #1013
    Iniisip ko nga din yan. Pero nakikita naman ng father ko habang nililinis. Sana naman hndi kinalikot. Ty sa info.
    Tulo lang problema wala naman ibang gagalawin diyan Either clogged nga yun Drain or hinde na mabait mabuti yun Drain pan sa Drain hose, or nawala sa pitch yun A/C
    #1015
    oo kasi nakakainis diba? ang tino tino tapos abala..... lalo na kapag merong mga pwede matuluan sa ilalim.
    Aug 2018
    #1016
    Sobrang hassle. Yung tipong maririnig mong may tumutulo mga bandang 1 am. Ipapacheck ko na lang sa service center nila. Para mekaniko na nila yung mag aayos.
    Jun 2008
    #1017
    Happy with my Kolin 2HP Window Type with remote
    it's been almost 20 years time to replace it ayaw na lumamig and the technician said it's not worth the risk to repair it
    Jan 2008
    #1018
    After 8 years bumigay na un main board at receiver ng carrier xpower. 9k ang naubos. Tinakot pa ko ng ac technician na nakontak ko. Mga 15k daw cost ng board. Kaya tumawag ako mismo sa carrier.
    Nasira after magbrown out tapos nagkaron ng kuryente ulit.
    Sent from my Redmi Note 5 using Tapatalk
    Quote Originally Posted by kkreuk18 View Post
    parang input stage lng.. normally the logic circuit is waiting for the low voltage dc supply from the input stage.
    Jan 2008
    #1020
    May nabasa ako na mejo mahina nga daw ang carrier pag nagkaron ng power surge
Split Type Aircon: Which is best?
