Results 811 to 820 of 1687
April 2nd, 2018 11:12 AM #811
The noise from window-type A/Cs are really not a big deal. Just a few nights with it, you'll find that the drone acts as white noise and can actually help you sleep. I experienced this the first time we switched from a window-type to a split. Took me a couple of nights to adjust to the silence.
Humans are very adaptable. The noise from a window A/C is just superficial and will "go away" in time. That is, your brain will learn to ignore it eventually.
April 2nd, 2018 11:15 AM #812
There are ways to design a building well that incorporates window type aircons ...
April 2nd, 2018 11:23 AM #813
Do consider brands, usage, savings, comparative purchase costs between conventional units & inverters prior to deciding. Inverters are proven to cut around 40% of energy consumption, yes, but It might go against reason if the usage is seldom or short. Savings can be much or lil & recovery, short or loooong...depending on usage.
Inverters are like modern cars.....laden w/ more complex circuitry & have more parts that may be prone to dying than conventional.... Always check the model's reviews & reliability feedback. Some do prematurely die prior to cost diff recovery.
April 2nd, 2018 11:24 AM #814
April 2nd, 2018 12:50 PM #815
Yes, you'll get used to it. The sound it makes will be like a lullaby. I remember many years ago, I was sleeping besides a boiler literally! I can't imagine how I was able to adapt but I did.
Just to reiterate, *travajante, inverter type will "cost less" if "used more". In other words, if you'll be using the air conditioner seldomly then you should stay away from inverter types.
April 2nd, 2018 12:59 PM #816
- Nov 2017
- 1,748
April 2nd, 2018 01:38 PM #817
April 2nd, 2018 03:56 PM #818
I made some quick computations based on lazada price of condura 1.5 hp * P20k and 1.5 hp inverter * P39k, if i use it for 8 hours daily, at P10/kwh, it will take 2 years and 4 months to recover the price difference assuming 30% savings. Will 1.5hp be enough for a 20 sqm room?
April 2nd, 2018 04:20 PM #819
