Page 79 of 86 FirstFirst ... 2969757677787980818283 ... LastLast
Results 1,561 to 1,580 of 1708
    #1561
    +1
    No fancy features - not even an LED display for the temperature - but definitely solid.
    Sent from my PL2_sprout using Tsikot Forums mobile app
    Think Toyota.[emoji4]
    #1562
    Ano possible reason pag mabilis ang buildup ng gunk (yung parang jelly na biofilm)? Feeling ko hindi sa drain dahil parang wala namang bara.
    Normally sa WT, sa tubig yan na naipon sa base na di nagdi- drain.
    Check mo kung tumutulo.
    Jun 2015
    #1563
    I-monitor ko na nga lang. Kakapalinis ko lang kanina e. Binombahan din ang drain pipe. Obserbahan ko kung nade-drain nga ba nang maayos. Pero normally hindi naman totally nawawalan ng tubig ang drain pan di ba?
    #1564
    Normally kailangan nakatilt toward the back para tuloy tuloy ang pagdrip at di maipon sa pan.
    Kasi may option yan na may cap yung drain para makatulong to cool down the condenser, but the negative effect yung biofilm build up.
    Apr 2012
    #1565
    Any reviews with TCL aircon?
    Sent from my SM-A507FN using Tapatalk
    Mar 2004
    #1566
    If people read the installation manuals of window type airconditioners ... there's a maximum tilt angle limit ...
    #1567
    Ilan kailangan na clearance sa sides ng window type aircon? ok lang ba mga 1 foot na concrete per side and 2 feet sa back?
    Quote Originally Posted by manager View Post
    no obstruction sa likod.. that thing wil just overheat.
    #1569
    i think you just described an enclosed space.
    if the air in there does not actively move in significant volume,
    your aircon will overheat.
    Feb 2019
    #1570
    Have our aircon cleaned earlier as it is not enough to cool the entire room probably because of the high ambient temperature outside.
    Feb 2012
    #1571
    +1
    For me I swear on my LG 1.0HP split aircon performance after almost a year of use.
    I find the main unit display quite useful and very convenient.
    I can see in what mode I am, the current or set temp, and various other info.
    Although I can also see them sa display ng remote, you do get a positive indication everytime you press a button.
    Saka when not holding the remote, one glance sa overhead display makikita mo na kaagad yung status.
    I also have a Daikin 1.5HP split aircon naman in the other room.
    And yun nga, wala siyang status display aside from an LED indicator.
    While setting up the unit aasa ka lang sa very faint beep and blinking LED as acknowledgment of your button press.
    Pakiramdam ko rin mas madali makalamig ng kwarto si LG, probably due to the dual inverter compressor.
    Mas malaki kwarto ni Daikin pero that's why 1.5HP capacity ang kinuha ko para sa kanya.
    Reliability is one reason I initially went with the Daikin, although napasubo na lang din ako.
    Sa initial kwenta kasi ng hipag ko eh wala pang 40k pero a little over 30k lang.
    After installation, saka lang na-realize mali ang kwenta and I need to shell additional 10k pa pala.
    Otherwise, I wouldn't have went on with the transaction due to budget limitations.
    Kaya for my 2nd unit naghanap na ako ng mas mura then research na lang about reputation of the brand and model.
    So far the LG is working great nga pero since mag-one year pa lang long term reliability remains to be seen.
    #1572
    how about carrier full inverter? mas tipid daw sa kuryente, nasa 15.1 EER. sa robinsons appliance, offer sa akin eh 42k 1HP. 3 yrs warranty sa unit and 5 yrs sa compressor, free installation.
    #1573
    Quote Originally Posted by Tha_Mann View Post
    Carrier is a Midea rebranded, better get Daikin.
    #1574
    Daikin kami sa office and sa bahay. Super tipid sa kuryente and reliable. Cost wise it was even cheaper than Panasonic when we got our units. I can DM you our contractor if you'd like.
    #1575
    One of our 4yrs old split type Daikin recently naubusan ng freon due to leak. So medyo hindi maganda pag install dun sa isang unit namin. But so far so good, basta continuous ang 6mo interval cleaning.
    Sent from my SM-S906E
    #1576
    Nakalagay sa website nila na may 3 years PCB warranty ang Daikin D-Smart series (except the pretentious D-Smart Prince).
    AUX has 5 years warranty for the unit including the PCB + 10 years for the compressor.
    Most everybody else ay 1 yr unit, 5 years sa compressor.
    Oct 2007
    #1577
    Is AUX a new player in the Philippine market? Ganda ng warranty pero still I prefer na mas matibay and no issues with shorter warranty kumpara sa mahabang warranty and may issues. I'm not saying that its not reliable, no experience with the brand, just my point of view. he he he
    #1578
    Quote Originally Posted by iandvo View Post
    So far ayos naman ang feedback pati na yung TCL.
    If branded go with Daikin.
    #1579
    thanks for the inputs.
    I've read somewhere nga na yung inside parts ng Carrier eh Midea.
    nice. ygpm bro.
    Which one is better - panasonic or mitsubishi? 2.5HP and 1.5HP split type.
Split Type Aircon: Which is best?
