Page 78 of 86 FirstFirst ... 2868747576777879808182 ... LastLast
Results 1,541 to 1,560 of 1708
    #1541
    i wish the owner would chime in and assure us,
    "guys, i read your concerns and theories. i assure you, lumamig ang aircon namin nung kinabit namin yang venting aid na yan."
    With that fix, its not exactly engineering.
    Obviously the condenser fan has to work extra. More work means higher power consumption. MTBF for the fan is lower by a higher margin.
    Aug 2004
    #1543
    Baka nagreklamo ang kapitbahay hehe
    Sabi nung installer ko may mga cases daw ng away dahil nakatutok ang condenser fan sa bintana ng kabilang bahay [emoji1787]
    Sent from my SM-A605G using Tapatalk
    Feb 2019
    #1544
    It looks to me like the deflector is not only useless but also impedes air flow compared to none. If the deflector wasn't there, won't air also escape sideways aside from upwards?
    Nope the air will flow directly into the wall and then bounce back probably some air would go sideways that's why deflector is installed to make way for the air to go upwards.
    Feb 2019
    #1545
    That's not efficient. No other location?
    Im not sure with the owner but probably there will be other options for condensing unit location but farther than this one.
    Jun 2015
    #1546
    Has anyone here tried those "fin combs" sold online? It's supposedly for straightening those fragile aluminum fins. I'm not sure if it's going to be effective or cause more problems.
    I noticed one of our ACs have several bent fins which I think causes quick build up of that white gunk that eventually clogs the drain.
    #1547
    i haven't tried it myself, but it seems logical to...
    try an ordinary suklay whose teeth are "appropriately spaced".
    they are probably cheaper and easier to get.
    Apr 2012
    #1548
    What's the difference sa Standard na Inverter AC vs sa full DC inverter?
    Sent from my SM-A507FN using Tapatalk
    basic inverter ac only have the compressor working on dc, while its other components like blower fan, outdoor fan are ac.
    full dc means all major components are dc,
    Sep 2010
    #1550
    & full dc means it would be more expensive but it consumes less electricity?
    Feb 2019
    #1551
    So far the cheapest split type i inquired is TCL Gold less than 30K including installation for 1.5hp unit.
    Aug 2021
    #1552
    Thanks for this. Checking TCL reviews now.[emoji846]
    Sent from my SM-A315G using Tapatalk
    #1553
    Quote Originally Posted by QUEZ View Post
    Daikin, you'll never go wrong with.
    Aug 2004
    #1554
    Yung suking cleaner ko also sells Daikin and TCL. Told him I was interested in a TCL and he said ok naman daw but he still advised me to wait for the end of year Daikin sale.
    Jun 2015
    #1555
    Ano possible reason pag mabilis ang buildup ng gunk (yung parang jelly na biofilm)? Feeling ko hindi sa drain dahil parang wala namang bara.
    Sent from my PL2_sprout using Tsikot Forums mobile app
    Jun 2015
    #1556
    +1
    No fancy features - not even an LED display for the temperature - but definitely solid.
    Mas mahal yun meron wifi control. Not sure about the pricing differences.
    Full dc means it can throttle down low in the evening. If you're just one person making 80w of heat. That's what's theoretically the lowest wattage. But there are other heat sources like walls and maybe other live human beings.
    Apr 2012
    #1558
    I got another Haier DC inverter. Was choosing between this and Midea.
    But Midea solds fast. Got the Haier 1HP for 22k only.
    Unlike my first purchase na nasa 24k pa sya
    Jun 2015
    #1559
    Free install? Minsan kasi mura ang unit pero not free ang install. Meron naman 30k pero free install. Although sa tingin ko yung 30k na price factored in na yung "free" installation.
    Apr 2012
    #1560
    Yep free install na
Split Type Aircon: Which is best?
