Page 2 of 2 FirstFirst 12
Results 21 to 40 of 65
    Oct 2011
    eh sir 'G' lang un linsys router mo mabagal talaga yan.
    i use DLink DIR-655 ... no problems so far
    ano ba simtomas ng naghihingalo na wifir router? mukhang ito na ata problema sa bahay eh
    a. pwedeng intermettent connection, tapos puno ang ilaw, or walang ilaw.
    b. DHCP (if you are using this, results in slower internet connection)
    c. sobrang bagal ng connection. pero check mo din kung sa telco mo ito bu plugging your modem directly into your PC or laptop.
    d. ayaw kang papasukin maski tama yung WEP or WPA password mo.
    e. humina ang signal o may dead spots ka na.
    f. walang signal pero based sa mga LEDs, ok naman.
    madami pa eh.
    bakit nagfafail ang router?
    primary cause is mainit.... lalo na sa routers na walang patayan. of course, pang SOHO routers lang ito dahil most enterprise routers have their own exhaust fans.
    I just use the free PLDT router. We never turn it off
    I am experiencing intermittent connection Parating page cannot be displayed then I have to reset all the time
    Aug 2009
    im using this for 3 years now wala pa ring palya.check niyo rin specs ng router to have maximum performance and if you can install third party firmwware (tomato ddwrt openwrt etc.)..BTW i use OPENWRT on my router (Mjpeg HDcam,DLNA,Openvpn)
    CPU Atheros AR9132 rev 2 (0xb9)
    CPU Speed 400 MHz
    Flash ROM 32 MB
    RAM 64 MB
    Radio 2.4 GHz
    WLAN Support B/G/N
    WLAN Max Speed 300 mbps
    Antenna Location 2x fixed external
    Switch 4x GigE + 1 WAN
    USB 1x USB 2.0
    Jun 2013
    Quote Originally Posted by kinyo View Post
    magkano yung ganito sir? malakas ba range nya? yung akin kasi d-link dir-600 mahina range e
    ^ medyo mahal bili ko, P4k+ ata yun, sa mall kasi nabili
    kumpara sa dating router namin DI-524, mas maganda range nya (but its not a good comparison kasi magkaibang class sila) ... better penetration sa concrete walls
    Oct 2011
    iba iba pa ba ang penetration capabilities ng different brands of routers given same specs?
    ^ afaik, penetration capability is largely dependent on the rf circuit of the router, its power transmitted and sensitivity of antenna (for reception) for the operating frequency ... the info is not usually disclosed by manufacturers ... two routers may have same specs (e.g. N300) but they may use different rf circuit, hence differing penetration performance
    Oct 2011
    Tingin ko sir baka isa lang ung rf circuit supplier nila.
    Wifi N has better penetration than Wifi G for the same wall density.
    Aug 2003
    update lang, on a whim i decided to flash DD-WRT onto my Linksys WRT-320N...so far it has paid off, no resets since configuration
    Saved me a couple of bucks...which i will be needing for some flood damage :p
    Jun 2013
    I recommend Asus N66U. Been using this router for a year now and so far stable,fast with frequent firmware updates. Do a search for reviews online.
    Sent from my iPad using Tapatalk - now Free
please recommend a Wifi router
