Results 41 to 50 of 65
September 2nd, 2013 06:38 PM #41
using belkin N150 ADSL2. been using for 3 years na. router is on the 3rd floor. pag sa ground floor na mahina na signal. range is probably around 50-60feet
September 2nd, 2013 10:00 PM #42
Pag two floors ang bahay ano dapat yung router na gamitin?
Gusto ko kasi yung malakas pa din signal kahit nasa itaas ako or nasa ibaba.Kaya naka modem pa din ako ngayon kase iniisip ko baka mahina ang router eh.
Thanks.
- Jun 2013
- 120
September 2nd, 2013 10:46 PM #44
Kelangan talaga per floor ang Wi-Fi AP. Ang issue kasi dyan is not the router but the gadgets. Normally mahina ang power ng mga gadgets. Kahit napakalakas ang router kung mahina naman ang gadget, wala din.
This thing is one neat Wi-Fi indoor installation. Mura lang.
UniFi | Ubiquiti Networks, Inc.
September 2nd, 2013 11:21 PM #45
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 3rd, 2013 02:16 AM #46all of the above suggestions work. or you can also try this Edimax EW-7438RPn N300 Universal Wi-Fi Extender | VillMan Computers
I used it in my parents house. They now have coverage on both floors. No need for cat 5 wiring. I think you can link up to 4 units if you have a mansion.
September 3rd, 2013 04:44 PM #47
One can also opt to buy Routers with dual band [it probably means two radios (2.4 and 5GHz)] & removable antennae. SMA cable is all you need to extend the range. One can also upgrade the antenna to higher dBi for wider coverage.
Gigabit wireless (WiFi - AC) is now available.
September 4th, 2013 09:15 AM #48
So bibili ako ng router then extension pa nung router para malakas pa din kahit nasa itaas ako tama ba sir?
September 4th, 2013 10:17 AM #49
marami kang option:
a) pa cable ka sa second floor, tapos yung connection mo sa ibaba maghihiwalay, isa papuntang wifi router sa ground floor and isa papunta sa second floor.
b) buy a wifi extender, or another router that you will utilize as an access point. yung second floor access point mo directly communicates with the router sa ground floor. pero again, depende ito sa lakas ng bato ng signal mo ng router sa ground floor.
c) buy a stronger router, na nakalagay sa ground floor lang.
if i am to choose, i'll chose option b. pero extender option, hindi access point option.
September 4th, 2013 10:28 AM #50
No, a single dual band WIFi-N should do the trick I know because my Dual band wifi N can reach three compounds (some cousins like the free wifi).
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
