Page 3 of 13 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 124
    #21
    Kapag metro manila lang ginagamit ko hanggang kalbo na, pag mag out of town time to change na. Un idang set ko ng yoko noon bakat na un parang alambre nya kaya nagpalit na aq
    Mar 2012
    #22
    Palit around 50k kms, pero once sinagad ko hanggang 80k, halos kalbo na at pinamigay ko na lang. Aba nagulat ako ng makita ko na ikinabit sa isang civic na napadaan sa waltermart, kumpleto apat na gulong!
    Dec 2009
    #23
    Quote Originally Posted by maki mi View Post
    Yung goodyear duraplus ko 50k din pinalitan ko na medyo manipis na din
    #24
    sayang yung makapal pa na tires kung papalitan na agad after 4 years * 35,000 km only. For me, I'll buy 1 pair muna for the front, then after 2 years, buy another pair for the front, yung 2 year old na tires, sa rear na sya ilagay. Then after 3 years, buy 1 pair ulit for the front, yung 3 year old na tire ilagay sa rear, and so on.
    Apr 2012
    #25
    Quote Originally Posted by admiral88 View Post
    Tires have a lifespan i think 4 or 5 years from date manufactured na naka indicate sa side wall. Kaya kahit makapal pa palit na yan.
    Mar 2012
    #26
    The British Rubber Manufacturers Association (BRMA) recommended practice, issued June, 2001, states, "BRMA members strongly recommend that unused tyres should not be put into service if they are over six years old and that all tyres should be replaced ten years from the date of their manufacture." .......
    More recently, the Japan Automobile Tire Manufacturers Association (JATMA) recommended practice, issued May, 2005, states, "Customers are encouraged to have their vehicle tires promptly inspected after five years of use to determine if the tires can continue to be used (recommends spare tires be inspected as well). Furthermore, even when the tires look usable, it is recommended that all tires (including spare tires) that were made more than ten years ago be replaced with new tires. Additionally, because in some cases automobile makers--based on the characteristics of the relevant vehicle--stipulate in the owner's manual the timing of tire inspection and replacement. Please read and confirm the content of the owner's manual." ......
    Our experience has been that when properly stored and cared for, most street tires have a useful life in service of between six to ten years. And while part of that time is spent as the tire travels from the manufacturing plant to the manufacturer's distribution center, to the retailer and to you, the remainder is the time it spends on your vehicle.
    Tire Tech Information - Tire Aging – Part #1
    Sep 2014
    #27
    Up...
    Read the whole thread, walang nagbanggit na nagpapalit sila pag na-vulcanize na and tyre.
    Hindi ba sya factor?
    tread depth indicator or when the tire is noisy... yan lng ang reason for ko...
    #29
    Quote Originally Posted by Jepster View Post
    Up...
    unless the damage is 'severe", the tyre may still be used after "vulcanizing".
    Feb 2014
    #30
    all my tires have undergone vulcanization...
    at the factory where they use heat pressure sulphur etc to turn latex into tires, condoms, etc
    this silly pinoy term has to stop, so yes i know why you used quotes there
When Do You Replace Tires?
