Palit around 50k kms, pero once sinagad ko hanggang 80k, halos kalbo na at pinamigay ko na lang. Aba nagulat ako ng makita ko na ikinabit sa isang civic na napadaan sa waltermart, kumpleto apat na gulong!![]()
Any sidewall damage, it's an instant tire replacement. (including running on flat) Hence it's quite beneficial to find out if the tires you're buying has sidewall impact tech/enhancement of some kind...
sayang yung makapal pa na tires kung papalitan na agad after 4 years * 35,000 km only. For me, I'll buy 1 pair muna for the front, then after 2 years, buy another pair for the front, yung 2 year old na tires, sa rear na sya ilagay. Then after 3 years, buy 1 pair ulit for the front, yung 3 year old na tire ilagay sa rear, and so on.
Tire Tech Information - Tire Aging – Part #1The British Rubber Manufacturers Association (BRMA) recommended practice, issued June, 2001, states, "BRMA members strongly recommend that unused tyres should not be put into service if they are over six years old and that all tyres should be replaced ten years from the date of their manufacture." .......
More recently, the Japan Automobile Tire Manufacturers Association (JATMA) recommended practice, issued May, 2005, states, "Customers are encouraged to have their vehicle tires promptly inspected after five years of use to determine if the tires can continue to be used (recommends spare tires be inspected as well). Furthermore, even when the tires look usable, it is recommended that all tires (including spare tires) that were made more than ten years ago be replaced with new tires. Additionally, because in some cases automobile makers--based on the characteristics of the relevant vehicle--stipulate in the owner's manual the timing of tire inspection and replacement. Please read and confirm the content of the owner's manual." ......
Our experience has been that when properly stored and cared for, most street tires have a useful life in service of between six to ten years. And while part of that time is spent as the tire travels from the manufacturing plant to the manufacturer's distribution center, to the retailer and to you, the remainder is the time it spends on your vehicle.
Up...
Read the whole thread, walang nagbanggit na nagpapalit sila pag na-vulcanize na and tyre.
Hindi ba sya factor?
tread depth indicator or when the tire is noisy... yan lng ang reason for ko...
^ kadalasan sa mobile dahil sa auto complete tapos hindi na binabalikan
Sent from my ASUS ZenFone 4 using Tapatalk
male pala spilling ko. pasentia na. 🤡🤡🤡
Yung 2 gulong ko ilang beses n na-vulcanize.
last na nabutas naitakbo pa ni misis kaya nagkabitak.
Pinalitan ko na dalawa. 5 yrs and 40k pa lang natakbo.
Rear pareho sinalpak and ung dating spare is spare p rin hanggang ngayon.
My personal rule kung di kaya magpalit ng 4...
2 muna and lagay sa harap... Luma sa likod.
Sent from Zenfone 3 on Tsikot mobile app
I try to rotate my tires regularly so that they will all need replacing at the same time. If I need to replace only 2, I put them up front, just personal preference. I find that they scrub in faster up front. But I drive as though it were a new car with brakes that haven't been broken in.
If I suspect I may have misalignment up front I put them in the rear.
