Results 71 to 80 of 401
September 28th, 2009 09:27 AM #71
September 28th, 2009 09:42 AM #72
Water is normal. No problem. The stronger smell might be your catalytic converter drying off.
- The hum of the engine is much louder during idle. It would idle just fine then "shake" a bit.
- Wala naman error according dun sa displays (those that display warning lights sa may speedometer e.g. oil, engine, etc)
- aircon, lights, keyless entry works just fine.
Also, would it be safe to drive it na to the detailing place? And tama ba na ipainterior detail ko muna before taking it sa casa? The floodwater stinks and Im worried na baka matagalan pa pag claim sa insurance.
please
September 28th, 2009 11:17 AM #73
Nice link. Thanks for sharing. Ako rin inabot ng baha hanggang dashboard ang aking 97 mitsu.
Meron kaya sa inyo ang may alam paano tanggalin ang ECU ng 97 galant? Natanggal ko na ang isa. Yung isa (A/T ECU siguro) medyo mahirap abutin tsaka parang di common ang fasteners.
Also sabi ng neighbor kong mekaniko, ibabad ko daw sa lighter fluid ang ECU, tama ba yon?
Advice din po how to dry my the instrument panel. Tinanggal ko na and i noticed that yung mga bulbs ay pinasok din ng tubig.
Thanks.
- Sep 2007
- 68
September 28th, 2009 01:26 PM #74Ghosthunter: thanks sir. di ko kasi nakita tong thread na ito.
Sir bakit ibababad sa lighter fluid? ano explantion?
Better buy siguro a hair dryer to dry out the electronics and never put PUT POWER ON IT unless you want to be short circuit.. or any anti-rust solution na pwede gamitin at safe sa electronics.
Let's just hope and pray na yung bagong bago ay hindi na magtuloy. dami na kawawang Pilipino na start from the scratch.
September 28th, 2009 02:22 PM #75
September 28th, 2009 02:51 PM #76
- Sep 2009
- 3
September 28th, 2009 03:35 PM #77
- Sep 2009
- 3
September 28th, 2009 03:47 PM #79
Precautions
1. Tow your car on a safe place.
a. Home / Garage
b. Mechanic’s Place
b. Dry and Safe location
2. Don’t Attempt to start your car. Why?
a. Flooded Fuel Tank
b. Electrical Short Circuit
c. Water in oil
d. Might increase damage (shorted computer box if your car is EFI)
Some DIY Tips for Gasoline Car.
ENGINE
1. Drain Oil – to make sure that there are no water inside the engine.
2. Drain Fuel Tanks – Check if it is filled also by mud. You need to pull this down for through cleaning.
3. Drain Transmission Fluid
4. Drain Radiator Fluid
5. Computer Box – commonly found in your car’s kick Panel. Remove Computer box and try to dry. Some of computer boxes are sealed. Dry the contacts.
6. Brake fluids
7. Check Fuel Lines under your car
8. Non ECU car. (carb type) Clean distributor
9. Replace/Clean Spark plugs.
10. Check engine belts,replace them because it might also be deteriorated by mud.
Check all the fluids of your car. You have to remove them, clean its container and replace them.
For Diesel engines.
1. Diesel Engines doesn’t have computer boxes. That’s the advantage. Just replace the fluids. Clean or replace fuel pump. You can also drain the fuel pump by just pumping it and using a 10mm wrench to drain the water inside the fuel pump. (Again double check if it has its ECU, you might have an ABS ECU.)
ALARM SYSTEM
1. Disable or Remove Alarm System, there is a possibility that you willreplace your alarm after the unwanted incident.
INTERIOR
1. Remove Seats, and Carpet. Dry those first before installing it back in.
2. Pullout your dashboard as mud will accumulate here because it may accumulate rustin the future.
3. Removedoor sidings and clean the walls inside the doors.
4. Removespare tire and drain water
ELECTRICAL
1. Most of your car electronics will be the problem. Remove all electrical accessoriesfrom car audio to electrical car gauges.
2. You have to check the battery of your car if it can still charge. Most probably a battery replacement is also needed. Try to bring it first to your nearest battery outlet and have it checked.
3. Alternator - this is your car’s charging system.. Sensitive to water because it has electrical components on it. If your battery is already good.. Once car is running check if battery is charging. Bring it to a radiator shop or use a multi tester and check if it is charging.. common measurement should be 13.6 or14.4 volts.
4. Lighting System – Remove Tail Lights and Head lights to drain Water. Check bulbs and wiring.
5. Windows– Remove door sidings, clean door internals, apply grease to hinges and motors.
6. Other motors – Wipers etc. Try to dry and lube them after.
7. Electrical Fuses – Remove all electrical fuses. Remove and clean them. Dry the connections.
8. Gauges– remove bulb from your gauges/panels. Clean them.
DON'T START THE CAR UNTIL COMPLETELY DRY
BREAKING SYSTEM
1. Cars with ABS. Check your car model of you also have ABS, if you have an ABS, thisis another headache. Locate your ABS ECU (ECU – computer box), it might has itsown computer box or also built-in to your engine’s ECU (computer box)
2. Check Break lines underneath the car
3. Drain Break Fluid
4. Check hand break
AIRCONDITIONING SYSTEM - have it checked and cleaned by the pro's, mud will kill your evaporator and other components.
CHECK YOUR CAR’S MANUAL AND SEE WHAT TO LUBE, a WD40 is great for electrical motors and other electrical components.
Hope this helps if you’re going to DIY, but the best way is just bring your car to your trusted mechanic. This might also help as a check list... If you have suggestions or Q’s just message me here.
For interior detailing. Go to a reputable detailing shops near your place. ingat lang po sa mapagsamantala baka mag take advantage sila pero di naman nila alam ang ginagawa. basta lang kumita. Ingat sa lahat!
- Sep 2009
- 3
September 28th, 2009 06:54 PM #80That's a good checklist you provided there. However, we don't know anything about car repairs so right now we are depending on the mechanic who's working on our 4-year old mitsubishi adventure now which got completely submerged in floodwater last saturday. We wanted to bring it to diamond motors but said we have to wait for a few days because there are still several cars waiting in line plus they estimated that we might spend a 100k more or less. Instead of that, we decided to have it fixed na lang by one of the mechanics referred to us by some people we know. We'll have the interiors detailed after the mechanic finishes the repair. Do you think this is ok? Do you think that since our car has been flooded, its engine would not be running as efficiently as before thus would require frequent repairs and check-ups? thanks...
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
