Page 63 of 66 FirstFirst ... 13535960616263646566 LastLast
Results 1,241 to 1,260 of 1303
    #1241
    Quote Originally Posted by shauskie View Post
    "Final announcement; EB for this year will be held on October 06, 2013 (Sunday) at Shell - Macapagal ave (lane going to MOA) in Pasay City. We're looking forward to meet all of you, especially the newbies.
    See you all there!!!!!! smile.gif "
    as quoted...by Macgyver143200..
    you may visit vcp website for other infos..Thanks.
    Vanette Club of the Philippines
    Bro.,- ano'ng oras ito?
    TIA!
    I will try my best to be there!!!
    21.2K:tomato:
    #1242
    TIA!
    21.2K:tomato:
    oo nga pala bro di nakalagay time...sorry..hehe..9am-3pm..para maga rin makauwi..di pa madilim..at may time pa simba yung iba sa hapon at pahinga..
    see you bro..uwi ako ng 3pm na.
    #1243
    I will most probably be there around 2PM....
    Simba kami at Mall-ing(lunch) ng mga bata in the morning/noontime....
    21.3K:loopy:
    Sep 2013
    #1244
    welcome to tsikot bro polo bormate.
    Thanks sir shauskie.
    Update on my ride. Nagawa na yung AC niya, nireplace yung compressor, everything pinalitan except lang yung aux fan. Malamig naman siya, pero mahina yung buga ng hangin sa harap compared sa likod. I'll be going back to Ceejay's on Saturday para sa follow up. Tumaas yung idling niya pag naka-off yung AC, so kailangan i-adjust. Pwede ko ba ito i-DIY? Hindi kasi ako maalam sa sasakyan. :p Tapos tumaas yung temp hanggang kalahati nung gauge nung dinala ko yung van from Ceejays hanggang southmall after ko makuha, so ngayon worried ako sa overheating.
    #1245
    Quote Originally Posted by Polo Bormate View Post
    nice bro..ayos malamig na babay vanette mo..
    you may also visit the vanette club of the Philippines site for more information and tips..
    #1246
    nice to see you again bro cvt sa eb natin...kinis pa rin ni vanette mo..saludo ako sa pag alaga mo..
    next time ulit..
    #1247
    Hi guys kaka join ko lang sa group. Nakuha ko kasi yung vanette ng erpats ko after he passed away a year ago. And i've been trying to restore the vehicle for the past few months. Medyo sentimental narin eh.
    Tanong ko lang mga sir kung san makakahanap ng weather stripping para dun sa sliding windows sa likod?
    Tyaka medyo sumasakit na ulo ko sa AC.. napalitan ko na yung compressor, refill frion, lipat narin yung 2nd condenser and added another fan para sa overheat, pero di parin ganun kalamig yung AC. Had the air filter replaced and planning on having it cleaned rin. Meron pa ba akong di nagagawa mga sir?salamat po!!!
    Aug 2012
    #1248
    mga bossing bago lng po ako dto..share ko lng po yung nabili ko 1995 vanette b4 xmas..my prob lng po masyado daw po matagtag..pina check po ng bayaw ko yung mga shocks ok nmn daw po..ang problema daw po eh yung sa molye or muwelye naka deretso na daw po kasi at malapit na sa gulong,aaminin ko po wala ako alam sa sasakyan dko din po alam kung ano rason at bakit nag ka ganoon yun muwelye..merun po ba kayo alam kung saan ko pwede i pa repair yun?or kung saan pwede makabili nun..at kung magkano aabutin ng materyales at labor..
    Sep 2013
    #1249
    Quote Originally Posted by darwinbalmoris View Post
    Wear and tear kaya ganyan. May nabibili naman niyan na per piece if I'm not mistaken. Dalawa yan na magkapatong tapos may center bolt sa gitna. Kung butas na yung gitna, ibig sabihin naputol na yung center bolt.
    #1250
    Quote Originally Posted by markaim23 View Post
    If you are from the south Metro, then CeeJay's at Zapote-Alabang Road, near Perpetual University/Hospital should be a good shop to check your AC....
    Jun 2010
    #1251
    Hello po!
    Ano po kaya ang problema kapag ung RPM ay tumataas by itself when on neutral at kapag naka neutral tapos tinapakan mo ung gas tumataas pa rin ung RPM even after ma-depress ung gas (from 800 umaabot ng 1500-2000rpm). 2x na po nangyari Ito sa vanette namin, after driving for about 4-5hrs. Although while driving, normal lng ung pag increase ng RPM kapag naka kambyo and bumababa din ung RPM ng normal.
    Sabi nung mekaniko na pinagtanungan ko possible daw na accelerator cable or ung idle up nung carb.
    Meron na po ba naka danas ng ganito sa vanette nyo? Thanks in advance!
    Jun 2006
    #1252
    mga kavanette help naman
    just need to fix some concern with my 98 vanette
    1. Idle is low around 500 rpm kahit mainit na makina sometimes 700 then pag naka aircon naman 1200 pag nagcutoff aircon down to 500 rpm. pero napansin ko pag nakaircon at idle rpm is 1200 pag ioff ko manually yung aircon bababa sa 500 then pag on ko uli 900 na yung rpm which is supposed to be the normal. anu gagawin? san magaling magcheck ng carb natin if ever. Bacoor o makati area ko.
    2. nagbabawas ng tubig ang radiator. daily i fill at least 1 glass of water. wala naman ako tagas na nakikita. and nagtataka ako kasi di naman nababawasan ang water reservoir sa may battery area.
    3. tune up... san po magaling magtune up ng vanette natin parteng bacoor imus las pinas or makati area thanks
    #1253
    Quote Originally Posted by csmastah View Post
    Hello po!
    pwede rin po yang suspetya ng mekaniko nyo..tama rin po yun..
    para po ma verify nyo ganto po gawin nyo..
    -pagmataas na ulit yung rpm, tyr nyo tapakan yung gas pedal then bigla nyong irelease..parang pitik nyo lang..pag bumalik sa 800 kung saan yan yung true idle nyo ibig sabihin pwedeng naiipit nga ang accel cable nyo or pwede ring may play na yung throttle shaft ng primary ng carb nyo kaya tumatagilid ito at naiistuck ng bahagya kaya niiwang mataas ang idle nyo..
    good luck sir...
    #1254
    Quote Originally Posted by tokist View Post
    1. - pwede pong maganit na yung throttle shaft nyo sa primary..yung 500 rpm po is yan yung maaaring setting ng idle nyo..dahil medyo maganit minsan naiiwan sa 700 rpm yung idle nyo after nyo tapakan yung gas pedal..at pag on ng ac kasabay nya yung idle up vacuum activated actuator...siguradong sumobra ang adjustment nito kaya umaabot ng 1200 rpm nyo..at pag minsan nag on ulit ac nyo is hanggang 900 na lang kasi nga malamang maganit na yung throttle shaft..mabigat para sa vacuum activated actuator itulak yung shaft...dahil dyan is pabagobago ang idle nyo sir..pwede nyo linisin yan then try to re-adjust ng idle with and without ac. marami pa pong pwedeng cause yan..ilang lang po ito sa pwede nyong ikonsider na info para makorek yang idle problem nyo..
    2. -pwede pong defective na ang radiator cap nyo..malambot na yung spring loaded na valve sa rad cap na magpeprevent na lumabas yung mga coolant papuntang reservoir under normal operation...kaya malamang is napupunta sa reservoir yung ibang tubig from radiator at ito yung dahilan kaya lagging puno yung reservoir nyo..or baka sira na yung goma nito sa rad cap for proper sealing..pag singaw na po yung rad cap di na rin mahihigop ng rad yung tubig sa reservoir pabalik under cold situation like overnight sitting ng engine..papuno lang sya ng papuno..try to replace the rad cap.
    3. - antay po tayo ng suggestion ng iba..ala po ako idea ditto..hehehe..DIY po kasi sakin..
    good luck sir..
    Jun 2010
    #1255
    good luck sir...
    TYVM for the reply sir...
    Gagawin ko po ung sinabi nyo kapag nag-loko na naman ung RPM. So far po, last na byahe ko is 10hrs na walang patayan ung makina with AC, normal naman ung RPM although ung temp panandaliang tumaas more than half upon reaching my destination and during the time na pinapalamig lamig muna kaunti ung makina before switching it off.
    #1256
    walang ano man po sir..keep posted po..
    #1257
    I had the same issue earlier and I just made an adjustment in the vacuum activator near the carburetor... I just did a hand adjustment... There is a provision in the cabin cover for that....
    #1258
    Up ko lang to roll call our Vanette lovers....
    Kailan ba ang ating next EB, mga bros?....
    “Familiarity breeds awe”
    23.4K:nerves:
    Jun 2013
    #1259
    keep safe mga kaVCP
    sana nga matuloy yun mid year EB natin
    #1260
    Ang tagal nga bro,- naghihintay rin ako para makapag-benchmark sa ibang mga ka-Vanette natin....
    23.8K:superhero:
Nissan Vanette [Merged threads]
