Results 251 to 260 of 1303
- May 2009
- 3
May 9th, 2010 10:02 PM #251hi mga sir,
Good day! ask ko lang po. we have nissan vanette 98 model, ang tagal na sa amin pero ok parin siya. plano ko po kase palitan yung mags ng 17" tapos wide track yung gulong. ok lang po ba?
thank you very much po.
May 10th, 2010 03:02 PM #252
If you are from South Metro Manila or near the area,- then Ceejay's along Zapote-Alabang Road, near University of Perpetual Help, provides excellent service for our A/C. They were the ones who converted our compressor (from freon to R134a). And who relocated our second condenser to prevent overheating....
The husband and wife owners (Joel and Cora), together with the other workers are very friendly, accommodating and experts in what they're doing....
9808:goodluck:
- May 2009
- 3
May 11th, 2010 11:28 AM #253hi mga sir,
May 12th, 2010 09:00 PM #254
Katorse ang ating stock na gulong.... For as long as hindi tatama sa wheel well,- tingin ko okay lang... However, kung wide track,- nakausli iyan.... Might not look good. Your call, bro....
9808:goodluck:
May 12th, 2010 09:04 PM #255
I do not have any manual for our ride. However, the fuse box is located underneath (actually to the left of the base of the steering wheel column). There are markings in the fuse box which should assist you in identifying which fuse is for which item... Check it out....
9808:goodluck:
- May 2009
- 3
May 18th, 2010 05:52 PM #256thank you very much sir for the respons.
last question sir may alam po ba kayo na shop na ok pag gawaan. kase sir
yung vanette ko po 1year from now na overhaul yung radiator at nababa na rin
yung compressor. pero pag trapik medyo tumataas parin temperature, meron po ba kayo
alam na shop na ok siya reliable at sure na maayos.
thank you po ulit. God Bless.
May 19th, 2010 08:08 AM #257
As I said in the previous post, Ceejay's along Zapote-Alabang Road here in Las Pinas, is an excellent shop for A/Cs. They're the ones who repositioned my second condenser which was originally placed in front of the radiator and added an auxiliary fan on it. This solved my high temperature problem....
Again, here are 2 more possible culprits/solutions to your high temperature problem, other than the one I described above.
1. Worn-out clutch fan. Might need to repack.
2. Place an auxiliary fan in front of the radiator, with a thermoswitch on your block or a manual switch to turn it on or off.
9909:gotcha:
- Sep 2006
- 106
May 26th, 2010 07:39 PM #258Ano ba ang brand at model ng orig aircon ng Nissan Vanette natin?
At kung alam din ninyo, saan kaya ako pwede makabili at magpakabit nun?
Nun nabili ko kasi ang Vanette ko, hindi na orig aircon eh.
Isip ko lang kung ibalik ko kaya sa orig.
Thanks.
- Sep 2006
- 106
May 26th, 2010 07:48 PM #259Kung top-up lang, madaling makita, nasa ilalim din ng driver seat.
Bili ka lang ng transmission fluid. Last brand na nabili ko eh from Shell.
Pero kung magpapalit ka talaga, like flushing ba yang plan mo, I suggest ipagawa mo na lang yan sa mga gas stations na may service center, tulad ng Shell o Petron o Caltex.
- Sep 2006
- 106
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
