Page 29 of 66 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 1303
    #561
    double post...sorry..
    Jun 2010
    #562
    bakit yung clutch fan ko kahit long travel na ingay parin? dapat siguro mag lagay ako thermostat? kasi ang bagal ng makina humatak pag bagsak ang temp. ng 1/4....mahal kasi ng compressor hehehe
    kanina sobrang init parang fan aircon ko
    #563
    *aijie - hmmm..may kakaiba sa van mo a...pa backjob mo kaya muna sa pinagpagawan mo..
    #564
    bro cvt..this is my carb...
    before o/h...madumi.
    katay..
    and after o/h..
    link..
    http://share.ovi.com/media/shauskie....e.10008?sort=0
    #565
    Quote Originally Posted by aijie28 View Post
    Ibalik mo sa Ceejay's iyan bro... Back job.....
    10.7K:naughty:
    #566
    Quote Originally Posted by shauskie View Post
    b
    link..
    Thanks bro.
    Accessible ba iyang adjustment screw at may kailangan bang special tool to access it?
    Will look at it tonight... Thanks a lot again, bro.
    10.7K:naughty:
    Aug 2006
    #567
    wow, dami ko nalalaman dito sa thread...*shauskie, thanks sa pix...try ko mag-backread sa buong thread, baka may mapulot pa ako'ng other informative guides.... *all, goodmorning ulit...
    Jun 2010
    #568
    vanette gurus,
    gud am mga sirs.....well ayos na carb ko....may menor na ulit and ayos na idling ng engine...di na nag stall ang engine pag biglaan ang tapak sa gas pedal...problem is napansin ko medyo hirap ang hatak ng makina pag hi speed na more than 80kph....replaced everything na nga maybe there is something that i over look na kailangan paayos.....new tune up new change oil adjust na tappets (wrong spelling) not sure of the terms hehehe but still not happy with my ride. well first diagnosis after repairing the carbs was tukod daw clutch ko since i replaced it with new ones since mataas ang rev at walang hatak pag 3rd gear up...adjusted it at sagad na adjustment and wala na tukod but at high speed medyo mabagal ang reaction ng car at parang hirap na siya well for a 2.0 ltr engine kailangan chicken feed lang siyang mag 100kph. one point said that i might have a low gear na differential kaya daw mabagal w/c i dont believe since i see vanettes out there sa hway na hataw naman..also cant pinpoint the problem since my consumption is averaging 6.5 to 7 km./ltr which i am ok na with it.
    also, the a/c system is ok na....replaced the compressor with orig surplus compressor na pang vanette din...problem is laging lumuluwag ang belts kaya di ko magamit ng matagalan dahil sobra ingay.....3rd time to replace the belts..una lumuwag ang belt then adjust kaso humaba na so i replaced it with a shorter one kaso naputol agad...sabi sobra sikip daw kaya balik ako sa orig na belt size kaso na stretch ulit to the point na di na kaya i adjust so pang 3rd na ito na lumuwag....what would be the causing this problem...help naman...pinatanggal ko pa naman ang tint at akala ko perfect na a/c ko....what would be the orig a/c belt size ng vanette ba...di kaya pulley naman pero pantay naman pag sinilip namin ng mekaniko...hay still mga 3 steps behind to perfect my ride...hirap talaga
    Jul 2010
    #569
    *rjburgos: bumili ka pala ng orig na aircon compressor. hanep. yung sa akin nasira recently yung compressor. kinailangan palitan yung magnetic(not sure what this is) dahil grounded daw yung compressor. I asked Nisway kung magkano yung compressor and muntik ako mahulog sa upuan. 32k! Kaya remedyo na muna yung compressor although di ko alam kung tatagal. May sinabing replacement part mga 16k. anyone tried this before and sulit nga ba?
    Grounded din daw yung auxiliary fan kaya nagpalit din. Recommended din sa akin na palitan daw yung fan belt at adjuster pulley(tama ba to?). Nagtaka lang ako kung bakit naging grounded yung aircon compressor at aux fan samantalang ok naman siya. anybody has thoughts on this?
    Jul 2010
    #570
    Quote Originally Posted by d2lak View Post
    Ako kapapalit ko lang ng compressor sa aircon kasi meron ng leak . I bought a brand new compressor for P16k including the installation. Lagi kasi dati nauubos ang freon and na trace namin na sa compressor na siya nagle-leak.
    Jun 2010
    #571
    baka mag palit din ako compressor ang hina ng lamig pag tanghali
    bukas alignment naman ng 4gulong ok na ba yung 1500php alighnment and camber?
    pwede na tayo mag EB wala na mom and dad ko umuwi na sa japan
    #572
    Saan ka ba nagpapa-align/camber bro? Subukan mo sa Minerva sa WestGate Alabang o sa Servitek sa tapat ng Toyota Alabang.... If I remember correctly, mas mababa yata ng kaunti sa kanila...
    10.7K:naughty:
    #573
    Di ba front wheel alignment lang ang ginagawa sa van natin? di kasama na ang likod naka fix yun..
    *aijie
    try mo din sa customer cradle okey din don. what exactly did they do with your wheel?
    Jun 2010
    #574
    Quote Originally Posted by Vanette747 View Post
    yup nagpalit ako pero surplus lang....i saw na maayos pa got it * 4,500.00 but i think there is a problem with the alignment ng pulleys kaya laging lumuluwag ang belt ko i already had three changes ng belt.
    well you can try asking at tropical at kabihasnan paranaque along quirino avenue...a/c parts dealer siya and i think nasa 12k or 10k brand new compressor na pang vanette.
    but kung magnetic pulley lang ang sira that is repairable basta maayos pa bomba ng compressor. it happened sa pajero ko yan dahil nasira bearing kaya nag grounded ang magnetic pulley brought the unit at evangelista and na repair naman ang magnetic pulley around 2-3k lang depends sa parts. kya sigure suggest nila to change the pulleys kasi di naka align kaya pag tagal masisira ang magnetic at clutch ng compressor i think ha not a guru here but base only on my experience sa dati repair ng ibang car ko.
    try first sa mga a/c shops sa pasay dalhin mo din ang van mo para ma diagnosis nila, 2nd opinion ba.
    Jun 2010
    #575
    sir...nagpalit ako compressor pero surplus...got it at 4,500 sa pasay. well yung a/c magnetic ng pajero ko ganyan din ang sira pero na repair naman and up to now maayos naman. repairable naman ang clutch/magnetic ng compressor basta maayos ang bomba ng compressor. well kaya siguro kailangan palitan ang adjustment pulley mo ay siguro di na naka align since binago ang pulley....pa check mo kung naka align ang belt mo kasi pag hindi masisira ang bearing ng compressor at grounded again yan...i'm going to have my pulley sa a/c checked again at baka di masyadong naka align since lagi ako nagpapalit ng belt pang 3rd ko na within 2 weeks....hay hirap mag patino ng vanette. but so far restoring it is kinda fun since luv ko na vanette natin...past problem of my carbs have been finished already and suwabe na at tahimik na makina...just a little tuning since pag hi speed takbo ko around 90 kph up medyo ramdam ko na hirap ng kaunti...one step at a time talaga magpatino ng kotse.
    Jun 2010
    #576
    10.7K:naughty:
    well 1500 for alignment sobra mahal naman....just had mine last week alignment for 350 lang for 4 wheels. wag mo agad pa camber they always say that na kailangan camber but alignment lang ayos na...may kalog ba ang manibela at malakas at di pantay kain ng gulong mo kaya kailangan i camber....try first aligning it muna then pag wa epek then camber na...at 1500 puede mo na palitan 2 shocks sa harap...800 yata isang shocks kyb at pasay.
    #577
    Originally Posted by yapoy86
    malapit sa throttle cable..medyo kailangan mo tangalin yung takip ng battery and yung small cover sa side na may 3 screws.. dun mo masisilip yung throttle adjustment screw (may spring yun na Philips screw) then yung philips screw na gagamitin mo pang adjust dapat mahaba and you will insert sa may side ng battery para maabot yung idling adjustment.. sipatin mo lang maigi at pag na shoot mo yung screw adjust mo na lang sa tama...
    also dont be confused with the Air Fuel Ratio adjustment screw...kasi baka yun ang ma adjust mo lalakas sa fuel yan
    Hindi ko masilip ang mga adjustment screws,- from the battery compartment. At tsaka in my ride,- mukhang fixed ang "small cover" na sinasabi niya at may butas lang ito para sa throttle cable et al.... No good view of the carb... Gusto ko sanang ibaba ang idling ko from almost 1000 to about 750.....
    10.7K:naughty:
    Jun 2010
    #578
    kainis ang tagal from 8:30am to 5:00pm ako nag hintay tapos di pa pantay steering wheel kakainis talaga ang tanga ng gumagawa nag palit ako seal sa may brake kasi nung pag tanggal ng piston brake pag balik biglang tumagas bayad ko 1900 lahat sobrang tagal pa bumili ng parts nung pinaayos ko yung camber nag palit din ng turnilyo kasi maikli tapos 2turnilyo na lost thread nya dahil dun sa ginagamit nyang pang tanggal ng gulong parang barena
    mag rereklamo ako pag di naayos van ko bukas or if ever na masira ginawa nya lalo na pag naupod gulong ko...
    add ko lang muntik pang bumagsak ung ginagawa nyang L300 sa molye kasi nilagay ung patungan buti nalang tinulungan ko yung may ari na alalayan yung sasakyan nya kung di namin naalalayan yun boom basag siguro ang differential nun...
    comment ko lang sa shop na ito mahina ang gumagawa at walang alam masyado ok sila sa machine kasi laser yung alignment and camber...
    dapat pala sa JP wheels nalang ako pumunta kasi kilala ako dun..
    Jun 2010
    #579
    ang pangalan po pala ng shop is[SIZE="2"]RSJ TRADING[/SIZE]
    located at corner naga rd. pulang lupa LPC
    ito yung sa receipt:
    alignment 300
    camber 800
    calipper kit 350
    labor(brake overhaul) 250
    lognut 150
    slume type? 60
    all in all=1910
    i dont know if ok ang presyo pero di magaling ang gumagawa sa computer dapat diba 0.0 ang nakalagay?
    #580
    saklap naman kinalabasan ng trinabaho sa ride mo..kahit gaano ka-hitech ng equipment sayang pag hindi marunong ang gagamit..bat naman lumuwa piston ng caliper mo? pinabaklas mo din ba? magka-camber lang naman di ba..dapat dun ka na lang sa dati mong kilala na marunong..ako pinasusukat ko lang..pacheck lang ako kasi libre naman e..then ako na magaadjust..dami ka na pa backjob ah..
Nissan Vanette [Merged threads]
