Page 12 of 131 FirstFirst ... 289101112131415162262112 ... LastLast
Results 111 to 120 of 1303
    #111
    Quote Originally Posted by shumaker66 View Post
    gud am sir.gawin mo sa vannet mo,check mo ung fuel filter under the battery casing,medyo mahirap tangalin un nasa ilalaim kc ng battery.un lng ang sira ng vannet mo.ive got vannet for 10 yrs kc.thanks angd ingats
    I agree that this may probably be causing it. Mukhang natso-choke ang paglabas ng gasolina.....
    8303:dishwash:
    #112
    Quote Originally Posted by cc81352 View Post
    nasira ata ung power window motor ko sa driver side; ayaw na gumana; any idea kung saan makakahanap to (surplus) and kung magkano? thx
    Try at Evangelista bro.... Medyo malapit ito sa iyo....
    8303:dishwash:
    #113
    Just found out this morning that Caltex now offers only Gold (pure gasoline) and E10 Silver... Nawala na ang Silver (pure gasoline)....
    Anyway, Gold naman ang pinakakarga ko sa Vanette....
    8303:dishwash:
    Nov 2006
    #114
    galing ako ilocos kanina, so bago kami nag-byahe pina-check ko pang-ilalim ng van andami na daw papalitan...rack end, bushing, tire rod etc etc. quote nila sa kin is 22k (parts and labor!), mga sir ganito ba talaga ang presyuhan ngayon?
    #115
    Where did you have it checked and what parts are you using? If its OEM parts then it can be plausible but if you're using replacement parts, go for a second opinion. You'll also save more by canvassing for parts on your own; try going to Youngbros in Banawe, JAISI near E.Rod/Araneta intersection, Advance in Pasay - Taft, etc...
    Nov 2006
    #116
    Norkis ung shop (Ilocos Sur); pero i doubt kung OEM parts ilalagay, kaya sabi ko sa manila ko na lang pa-check. sa byahe di ko naman ramdam ung mga sira na sinasabi nila; pero para safe lang ill have it check na lang sa weekend.
    youngbros din parts ko sa sentra, mas mura nga dito kesa sa yen or nisparts
    #117
    Bro. shauskie,- any update on your ride?
    (OT: Grabe pala ang traffic sa may Coastal Road, approaching Talaba, Bacoor. Last Sunday, we were there and we were not moving for 30-40minutes)..... No problem with my Vanette. Cool lang siya...... )
    8303:dishwash:
    #118
    8303:dishwash:
    cvt, sa ngayon ok na ulit yung vanette ko. it's been two weeks now of observation and verification...confirmed ko na rin yung culprit. i got different case of trouble. nasa ignition system yung problema and it was induced by mechanical failure of distributor. yung unstable movement ng tachometer is caused by worn out breaker plate bearing, kaya pabagobago ang idle speed and until mamatay na sya sometimes on idling..then yung biglang namamatay while cruising is dahil sa offset pala yung alignment ng rotor sa distributor cap contacts. yung misalignment ay dahil sa nagpalit ako ng arm ng vacuum advancer dati pa..mga 3 year ago na because nasira na yung una pa..leaky na yung canister..ibang vacuum canister yung pinalit ko kaya pinahinangan ko lang ng ibang arm..medyo napahaba kya na-offset yung rotation ng breaker plate. since na bago yung rotor and cap before, nakakatalon pa yung high voltage between contacts and nung mapudpod na, lumaki na yung gap..this now resulted to misfiring and stalling...when i repaired the old distributor, i got good response so last saturday bumili na ako ng surplus sa banawe...so ngayon stable na ulit yung van. sa ngayon xcs gamit ko na fuel...E10 is bad for local parts..yung pickup screen nung bago kong fuel pump e na-deformed at natanggal sa pump dahil lumuwag..buti binunot ko ulit yung pump for checking kya nakita ko..ikinabit ko ulit yung lumang original..anyway mga vanette owners, salamat sa mga inputs and tips about troubleshooting, great help satin lahat to.. safe driving to all.
    #119
    If you're in Banawe, a shop that can do the repairs is Wheelers Suspension Haus.
    Try checking also with the Nissan CASA like Mantrade if they have any old stock Vanette parts. There are times they put old stock up on sale.
    #120
    ^^^ I am glad you're able to "tame" your Vanette bro. shauskie....
    8404:duel:
Nissan Vanette [Merged threads]
